POV-Ray : Newsgroups : povray.off-topic : C++ questions Server Time
24 Jun 2026 17:48:18 EDT (-0400)
  C++ questions (Message 71 to 80 of 123)
Subject: Re: C++ questions
Date: 26 Sep 2008 17:17:59
Message: <48dd5187@news.povray.org>
Warp wrote:
>   Unless I'm completely mistaken, this is not something you can achieve
> in Java. (In Java you have to close files explicitly and catch all
> possible exceptions which might otherwise bypass that closing.)
You don't have to *catch* the exception, but you do need extra code. I don't
even remember how to open a file in Java, so here's some pseudo-code:
FileStream fs = /* open a file */;
try {
    fs.write("Hello\n");
    String data = getData(); //may throw exception
    fs.write(data);
} finally {
    fs.close();
Date: 26 Sep 2008 17:21:51
Message: <48dd526f$1@news.povray.org>
Nicolas Alvarez wrote:
> You can overload the comma operator!
Oh yeah - that too! :-S
> boost::assign does some nasty stuff with it, to let you add stuff to STL
> containers like this:
> std::vector<int> mylist;
> mylist += 1,2,3,4; // uses overloaded += and , operators
...da hell? That's just mental!
OOC, what the hell is this "boost" I keep hearing about?
http://blog.orphi.me.uk/
Date: 26 Sep 2008 17:25:37
Message: <op.uh3xszn77bxctx@e6600>
On Fri, 26 Sep 2008 23:21:57 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
www.boost.org
FE
Date: 26 Sep 2008 17:47:42
Message: <48dd587d@news.povray.org>
A set of advanced C++ libraries with varying levels of sanity.
Date: 26 Sep 2008 19:20:40
Message: <48dd6e48@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> >> Warp wrote:
> >>>   Isn't this usually handled with callback interfaces (in OO languages)
> >>> rather than function pointers?
> >> Only in languages that don't support pointers to member functions.
> >   C++ supports pointers to member functions, yet using callback interfaces
> > is a rather common idiom.
> How do you declare a pointer to a member function, then?  I thought you
> had to keep a pointer to the object and then somehow invoke the proper
> member function, but I don't know the syntax for that latter part?
  Obviously you need an object if you want to call a member function,
be it directly or through a member function pointer. (Member functions
always require an object, as they take one as "hidden" parameter. You
can't call a member function without an object.)
  Member function pointer syntax is rather complicated. If you have,
for example:
class A
 public:
    void foo(int i) { std::cout << "foo: " << i << std::endl; }
    void bar(int i) { std::cout << "bar: " << i << std::endl; }
then you can create a member pointer named functionPointer, and make it
point to 'foo' like this:
    void (A::*functionPointer)(int) = &A::foo;
  (With the next C++ standard things will get easier, as you will be able
to write simply: "auto functionPointer = &A::foo;")
  You can call it like this:
    A a;
    (a.*functionPointer)(5);
    A* aPtr = &a;
    (aPtr->*functionPointer)(10);
  Note that this will work even if foo() is a virtual function overridden
in a class derived from A, and 'aPtr' (while still being of type A*) was
actually pointing to an object of this derived class.
  Also note that 'functionPointer' is in no way tied precisely to the
foo() function. You can make it point to another member function with
the same signature:
    functionPointer = &A::bar;
    (a.*functionPointer)(5); // Now A::bar() is called
  Curiously, you can even make pointers to member variables. That's
obscure if anything.
Date: 26 Sep 2008 20:33:12
Message: <48dd7f48@news.povray.org>
>     A a;
Oh, I see. No, I was talking about one object/pointer/variable etc that
pointed to one instance's member function.
For example, in C#, if you have
   class A {
     public float abc;
     public int xyz(int pdq) { return (int) abc; }
     public static mno(int pdq) { return pdq*pdq; }
   int (*point)(int);
   A alpha = new A();
   alpha.abc = 23.75;
then you can do
   point = &(alpha.xyz);
   int x = (*point)(23);
   point = &(A.mno);
   int y = (*point)(75);
/* I might have the syntax mildly wrong, and I'm probably using
    too many parens, but ... */
So the member pointer actually carries around the reference to the
object, if it needs to. Or it can point to a static (non-member)
function. I think Python does the same thing.
> the same signature:
Yeah, but invoking it requires both the object and the pointer. *Now* I
remember what is going on there. It definitely makes it easier to make
data structures that deal with function pointers if you only care about
the types of arguments and results, and not which class of object is
implementing it. It does, obviously, add some overhead, of course. This
way, you can have (say) an array of pointers to member functions, all of
which are implemented by unrelated classes. I guess in C++ you could use
MI to deal with something like that, while C# wouldn't support it the
same way.
Date: 27 Sep 2008 04:17:45
Message: <48ddec29$1@news.povray.org>
> You're Californian?
> Wow... suddenly a whole lot of POV-Ray stuff makes way more sense... ;-)
Huh? I'm not sure I get it. =) I am not on the POV-Ray development team.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 27 Sep 2008 04:23:35
Message: <48dded87$1@news.povray.org>
> Copy...constructor...? x_x
> Heh. And I thought figurating out the difference between a const pointer
> and a pointer to a const was hard!
It seems like you're learning a lot of language features, one after another.
If I were you I'd slow down a bit, take what you know already, and find
something fun to do with it. Make a text based adventure game or something.
The key is to find a hook that keeps you interested, so you start to use the
language in a more real manner, and then you learn features as you find you
need (or want) them.
On the other hand, if your motivation is to master the intricacies of the
language, then do that. Just don't burn yourself out trying to learn one
thing after another. It's a lot like math - they don't teach fractions to
first graders because they need to spend time learning addition and
subtraction to fully master the concepts.
 - Slime
Date: 27 Sep 2008 04:41:45
Message: <48ddf1c9$1@news.povray.org>
That was kind of my plan. And it went as far as me writing two simple
C++ programs that actually work.
Now, however, all the programs I can think of that I'd like to write all
involve constructing dynamic data structures - and the tutorial I'm
following doesn't seem to cover that in much detail yet. In fact, it now
seems to have degenerated into more of a categorical reference manual
than a "tutorial"...
Date: 27 Sep 2008 04:45:29
Message: <48ddf2a9$1@news.povray.org>
Slime wrote:
>> You're Californian?
Californians have a reputation for being... uh... "unusual". Which would
certainly explain... for example... your nick is "slime"? o_O And also
some of the wacky things you've rendered over the years.
I'm jesting of course... just because the most interesting thing *I*
ever rendered was a 3D section of the cubic Mandelbrot set... :-(
