Invisible wrote:
> My understanding is that when you create variables, they start off
> containing junk unless you initialise them (or their types have
> constructors which initialise them to something specific). Is that correct?
I may be wrong, but I believe all variables declared outside of a
function have default values.
For Sale: Parachute. Only used once, never opened, small.
/ \/ \ u e e n / \/ a w a z
>>>>>>mue### [at] nawaz org<<<<<<
anl
More exactly, in C at least, any variables allocated statically start
with a default value of zero appropriate for their type. That includes
static variables allocated inside a function.
It would be interesting to see a quote from the C standard.
How about the C++ standard?
3.6.2 §1:
"The storage for objects with static storage duration (3.7.1) shall be
zero-initialized (8.5) before any other initialization takes place."
FE
http://atrey.karlin.mff.cuni.cz/projekty/vrr/doc/c99.pdf
Section 6.7.8, page 126 (or sheet 138). Check rule 10.
But come on, this has been the case since K&R First Edition. :-)
Yes, I seem to recall that it's true for static variables as well (in
C++ - not sure about C).
Atheism is a non-prophet organization.
anl
> (in C++ - not sure about C).
I hedged my bets, not knowing whether statically allocated instances of
a class with a constructor invoked the constructor. I'm pretty sure it
does, but I didn't feel like trying to google it up. :-) Maybe it
initializes to zero everything before it invokes the constructor or
something. (Which I would suspect, given that it's often the OS that
does that initialization as it allocates the pages.)
> More exactly, in C at least, any variables allocated statically start with
> a default value of zero appropriate for their type. That includes static
I was under the impression that global variables are initialized to zero,
but you can't trust local variables because the stack has whatever garbage
data was left on it from previously called functions.
- Slime
[ http://www.slimeland.com/ ]
> Does C++ check whether a pointer you're deferencing is zero? Or will it
> just segfault?
In practice it segfaults. Any time you think there's even a chance of this
happening, do
assert( ptr );
to catch it ahead of time. (This will assert that it is not 0, or NULL).
You'll save yourself some headaches.
- Slime
Man, I'm in the wrong time zone. You always get to answer the questions
first! =)
- Slime
> first! =)
Which timezone is that then?
Invisible wrote:
> (You knew there were going to be a few at some point...)
> I just want to make sure I've got this absolutely straight in my head.
> So... a reference is the same as a pointer, except that it has nicer
> syntax, and you cannot change where it points to?
> If I'm understanding this correctly, a "union" is like several structs
> with the same base address, and you can treat it was one struct or the
> other struct, and it's up to you to remember which which struct you're
> currently using it is. (I.e., the language itself provides no way to
> distinguish.)
> Here's a perverse question: can a union have member functions?
Yes.
Yes.
> Does C++ have a concept of a "null pointer" - i.e., a pointer that
> doesn't point to anything valid, and can be detected as such?
Yes.
> How does memory allocation work in C++? If a program fills the heap, do
> you have to explicitly *do* something to enlarge the heap, or does it
> grow automatically? Does it shrink back again after you release things,
> or do you have to request that manually?
Depends on the implementation.
John
Correct. I was also pointing out that they get initialized to the type's
version of zero, whatever that might be. (I.e., pointers may not have
all zero bits in them; they get initialized to null instead.) Rarely can
you see this difference. :-)
And variables that are static but not global also get initialized.
Actually it's possible to invoke the "default initialization" for any
type at any point in C++. For example if you do this:
int i = int();
the 'i' variable will be default-initialized with the "zero" value for
the type in question (which, in this case, is the integer 0).
One might ask what's the point. It's actually useful when you don't
know what the type actually is. This happens eg. with templates. You
could have, for example, this:
template<typename Type>
void foo()
Type i = Type(); // Default-initialize i, even if it's a basic type
Although mostly it's useful in situations where you want to create a
default-initialized temporary, for example in code like this:
someVector.push_back(Type());
That will work even if 'Type' is an int, a double or a pointer.
PST. (California.)
- Slime
> PST. (California.)
You're Californian?
Wow... suddenly a whole lot of POV-Ray stuff makes way more sense... ;-)
Copy...constructor...? x_x
Heh. And I thought figurating out the difference between a const pointer
and a pointer to a const was hard!
Pointers to members?
OK, maybe I should stop reading now. :-/
Usually you don't need copy constructors unless you have pointers as
member variables of your class and you explicitly allocate memory to
them with 'new'. But we don't do that, do we? ;)
If you want a quick crash course on copy constructing when the class
allocates memory explicitly, check this:
http://warp.povusers.org/c++test/
(There are actually a few other situations where a copy constructor is
mandatory for a class to work properly, but they are slightly advanced
stuff.)
You don't need them.
That's what I was pretty much hoping, yeah.
Looks like it would only be useful for some pretty obscure situations...
Heh. I get the impression that most of the stuff I'm reading about now
is stuff that "you won't normally need". ;-)
(E.g., apparently you can overload the "->" operator... GAH! >_< OK, I
am *so* not trying that out!)
Anyway, the main reason I haven't written a Third C++ Program yet is
that I'm trying to think of something I actually want to write that's
implementable without automatic memory management...
They are useful in certain situations, but those situations are so rare
and usually so advanced, that even very experienced C++ programmers basically
never need them.
I once created a command-line parameter interpreter which was used like
this (extremely simplified):
class MyCLI: public CommandLineInterpreter
void inputFile() { ... }
public:
MyCLI()
// registerCLParameter() is a function in the base class.
registerCLParameter("input", &inputFile);
Basically this meant that when the interpreter encountered the command-line
parameter "-input", it would call the 'inputFile()' method I defined above.
This uses method pointers.
(The actual implementation is quite complicated because there are some
issues about a base class calling a derived class method through a method
pointer, but with template magic it's possible to do this portably and
safely.)
It's not like you don't need copy constructors (and copy assignment).
It's just that a beginner doesn't usually need them. When you start needing
copy constructors, your code will be a bit more advanced.
You can overload almost any operator, including 'new' (it's considered
an operator in C++) and the prefix-&.
I think the only operator you can't overload is the dot operator.
Hmm, is that sentence correct? Everything is implementable without
automatic memory management. Perhaps you meant something else?-)
Well, yeah. And *I* am unlikely to be writing anything "advanced" any
time soon! ;-)
And .* (apparently).
Also, unlike Haskell, you apparently can't make up new operators of your
own, just overload the ones that already exist.
Well, yeah, but it's a touch harder to implement heap-allocated data in
such a way that your program doesn't leak like a sieve. ;-)
[I'm actually surprised that using std::vector doesn't do this already...]
Aren't C++ compilers already stressed enough? Think about all the problems
they would have with user-defined operators, with their own precedence
rules, ambiguous situations, etc... :P
You usually use the STL data containers for dynamically allocated
memory, and if what you need is to allocate a single object, you can
use a smart pointer (I posted in the other group an URL to one smart
pointer implementation I have made).
Doesn't do what?
Heh, yeah... I can see that. ;-)
> use a smart pointer.
Fair enough.
> Doesn't do what?
Leak like a sieve! ;-)
I've never actually seen a programming environment with manual memory
management *and* dynamically resizable collections. The two are usually
muturally exclusive.
Then again, I'm not really sure what the story is if you try to put
user-defined data types into a vector...
Useful for the "Smart Pointer" pattern. The autogen stuff for COM uses
these a lot.
~Mike
> > Doesn't do what?
The class constructors, assignment and destructor help in automatizing
the internal memory management of the vector.
You can write your own dynamic data container as a class in the exact
same way as std::vector and the other STL containers, which will be safe
and will automatically manage its memory.
And not only memory. There are also other resources which can be
automatically managed with classes. Consider this:
void foo()
std::ofstream os("outfile.txt");
os << "Hello\n";
bar();
os << "there.\n";
Note that nowhere is the file actually explicitly *closed*. However,
no open file handles are leaked because it gets closed automatically
because the std::ofstream class handles this resource.
This is even so even if the function is exited abnormally. For example,
assume that the bar() call throws an exception. If that happens, the
function will be exited immediately (before the "there.\n" string is
written to the file). This is "unexpected" and we didn't take that
possibility into account. However, it doesn't matter: The file will
still be closed and thus no resource leak happens.
Unless I'm completely mistaken, this is not something you can achieve
in Java. (In Java you have to close files explicitly and catch all
possible exceptions which might otherwise bypass that closing.)
Well, it's not like *all* resources in C++ are managed manually.
More precisely, stack-allocated objects are managed automatically. Which
is exactly the reason why automatic management heap-allocated objects
becomes possible through these stack-allocated objects.
If the user-defined type doesn't allocate memory in itself, or if it
does but manages it properly, there shouldn't be any problems.
> these a lot.
Also used with iterators. (An iterator is an object which behaves
like a pointer.)
But presumable you'd need to know what you're doing first. ;-)
Mmm, that's nice.
Actually, for reasons beyond my comprehension, if a Haskell program
halts abnormally, all files are closed, but not necessarily *flushed*.
Like, WTF? *Why?* Anyway, basically you have to write some code to catch
the exception and close the file before rethrowing it. It's an extra 3
lines of code, but you still have to remember to type them...
Indeed. I've not seen this in any other OO language.
Sounds good to me! ;-)
Really? They're useful all the time in C#. Like, every time you have a
callback function you register with the GUI, or every time in Java where
you'd have to create an anonymous inner class or something. Pointers to
members are the OO mechanism corresponding to closures.
You have a window representing an object. You want to be notified
whenever the mouse moves over the window. How do you tell the window
manager that?
The destructor will close the file when the GC collects the object, but
that might be several seconds later. And it might not run if you exit
the program before the GC runs, but that's true of C++ also. So it's not
quite as nicely deterministic, but it still happens eventually.
Because it's Haskell that flushes the buffers to the file, but it's the
OS that closes the file. If you run it on (say) an Amiga, it won't close
the files, either. Apparently Haskell isn't writing directly to the
files, but to Haskell-managed buffers. Same thing happens in C with stdio.
C# has the same issue. You can sort of work around it with the using
statement, which will call Dispose on an IDisposable object, which, in
turn, closes the file.
~Mike
Mike Raiford wrote:
>> but that might be several seconds later. And it might not run if you
>> exit the program before the GC runs, but that's true of C++ also. So
>> it's not quite as nicely deterministic, but it still happens eventually.
Yep. Of course, it's really not a problem in a system where the kernel
participates in the GC, like Singularity does.
And, really, memory is a huge percentage of the resources you manage, so
the small bit of "real" resources you have to handle manually is usually
not much of a problem. Indeed, only once did I have code sufficiently
convoluted and error-prone that I had a resource leak of this type in
Tcl. And even then, it's because I wrote the code poorly and instead of
(say) wrapping the allocation and use in a procedure call, I tried to
handle it all inline.
Yeah, but if the Haskell runtime has code to handle printing out a
human-readable error message on an unhandled exception, why can't it
also run some finalisers? This is pretty basic stuff!
http://blog.orphi.me.uk/
:: and ?: cannot be overloaded either.
FE
> manager that?
Isn't this usually handled with callback interfaces (in OO languages)
rather than function pointers?
That seems logical...
I bet you can't overload ";", can you? In Haskell, you can. >:-D
Speaking of which... apparently you can overload "()", thus creating an
object that looks like a function... How far-out is that? o_O
I'm almost tempted to try just to see if I can implement curried
functions with it in C++. You know, just to be totally perverse...
I don't know how it is today, but at least in the past the amount of
file handles one single program could keep open at the same time was
ridiculously limited (IIRC to a few dozens or so). If the program tried
to open more than that, it would fail.
If a program is constantly opening files, doing something to them, and
then closing them, a file handle leak (which would happen if it fails to
close them for some reason, eg. because of a bug or a suprising exception)
can cause the program to malfunction. And this might not be caught on
testing, if the testing fails to stress the program in the same way as
it happens in actual usage...
OTOH, I could imagine that if Java detects that a file cannot be opened
because of too many file handles being open, it could automatically try
to run the GC and then try again.
OTOH, file handles are just *one* possible resource which can leak.
Java can't be prepared for all of them.
It's true of C++ only if your stream has been allocated dynamically
(directly or indirectly). If it's stack-allocated then there's no way
its destructor won't be called.
(Ok, there is a way: If you call abort() the program is immediately
terminated without any stack unwinding, in which case no destructors
are called at all. However, abort() is such a harsh way of terminating
the program that it shouldn't happen in normal code.
Incidentally a failed assert() calls abort(), which is the reason why
assert() should only be used to catch programming errors, not to exit
the program normally.)
On Fri, 26 Sep 2008 19:44:56 +0200, Orchid XP v8 <voi### [at] dev null> wrote:
';' is not an operator. It is a statement terminator. It would make no
sense for a C++ program to redefine the meaning of ';'.
Can you overload/redefine '->' in Haskell? What about '()'?
FE
So-called functors are a common idiom in C++ template programming.
For example many STL data containers and algorithms accept functors
as parameters.
A functor is something which acts like a function. In other words, it
can be called like a function can be called, and it will return a value
like a function returns a value.
Obviously a regular function is a valid functor (and a common way to
pass functors to the STL).
Another way of creating a functor is, as you point out, to create a
struct or class which has the operator() overloaded. This way an instance
of that class can be used exactly like it was a function.
The advantage of the latter method is that the struct/class can have
member variables (and member functions) which the operator() can use.
This way you can have different values for those member variables for
different instances of the functor. (If I'm not completely mistaken,
this starts get closer to so-called closures.)
In the next C++ standard there will be a third type of functor: Lambda
functions.
C++ might not be the best language for that... ;)
; is not an operator in the first place.
Yes, I know that. ;-) I was just being silly...
No. But then, it means something different in Haskell anyway.
> What about '()'?
No.
But then, in Haskell, a function *is* a data value, so there's not so
much need...
Yeah, I know that. ;-) I'm just teasing.
> as parameters.
I see...
Yes, indeed. It looks like that means you could do something like write
a struct that contains a number, and make it into a functor that adds
that number when called. OTOH, if your function really had to be a
*function*, you'd have to write a seperate function for every value you
might want to add... which would be, uh, silly.
In Haskell, you can just say "map (*2)" and it'll work. It looks like
what you're describing enables you to achieve something very similar in C++.
(Presumably the *other* thing about a C++ functor is that it could
change some internal state each time you call it - say, to generate
unique IDs or something...?)
> functions.
Knowing what I now know about C++ (constructors, copy constructors,
assignment constructors, pointers, references, etc.), I suspect this is
going to be... uh... "interesting". :-}
I wonder what the scoping rules would be like?
Heh. It could probably work... but no, I'm sure it'll be pretty ugly.
;-) [Not to mention being abnormal C++ style.]
Wow, wait a sec...
http://www.research.att.com/~bs/whitespace98.pdf
WTF?! O_O
> Wow, wait a sec...
> WTF?! O_O
I think that paper is a joke.
