POV-Ray : Newsgroups : povray.off-topic : Doomed? Server Time
3 Jul 2026 01:10:24 EDT (-0400)
  Doomed? (Message 31 to 40 of 57)
Subject: Re: Doomed?
Date: 21 Sep 2008 17:53:34
Message: <48d6c25e@news.povray.org>
> Yeah, well, once you *know* that it's easy enough. ;-)
That's what we're here for =)
It's also worth looking through the menus for shortcuts to common operations
like compiling and executing.
> Wait - you can have conditional breakpoints?
Yeah. In the version I use at work, you just right click on the breakpoint
and select "condition". In previous versions it was in a submenu of the
right click menu. I wouldn't be surprised if this is one of the removed
features from the express edition. (If it's free, they had to take
*something* out.)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Sep 2008 18:09:10
Message: <48d6c606@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:48d6aa2d$1@news.povray.org...
Yup. Have had for a couple versions of visual studio. Very handy for when
you want to break on the 99th iteration of a 1..100 loop, or for when you're
sure a variable should have a value within a certain range at a certain
point, but very occasionally doesn't.
Subject: Re: Doomed? Yep!
Date: 21 Sep 2008 18:10:07
Message: <48d6c63f@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:48d6a77b@news.povray.org...
>> According to "Thinking in C++", you can use the keywords "and", "or" and
>> "not" in place of symbols. GCC accepts this. However, Visual C++ doesn't
>> seem to like it.
> Ewww, someone got Visual Basic in my C++.
RotFL
Date: 21 Sep 2008 18:12:53
Message: <48d6c6e4@news.povray.org>
Slime <fak### [at] emailaddress> wrote:
> I haven't used the Express edition, but what I normally do is go to
> Project -> Add New Item, which creates a file *and* adds it to the current
> project.
  I usually create a new source file with emacs and then select
Project -> Add existing item.
Date: 21 Sep 2008 18:16:19
Message: <48d6c7b3@news.povray.org>
Fredrik Eriksson <fe79}--at--{yahoo}--dot--{com> wrote:
> The bitwise operators are all single character. There are also only four
> of them. You get used to it.
  << and >> are bitwise operators, and are longer than a single character.
  Not to talk about ^=, |=, &=, <<= and >>=.
Date: 21 Sep 2008 18:19:04
Message: <48d6c858@news.povray.org>
> There is currently as far as I know only one C++ compiler vendor that even
> claims to implement the full standard.
  Does the count change if we disregard export templates?
Date: 21 Sep 2008 18:25:17
Message: <op.uhuq8ftk7bxctx@e6600>
> character.
True, though they have no logical counterparts.
Also true, but I would consider those a kind of compound operators.
FE
Date: 21 Sep 2008 18:32:17
Message: <op.uhurj2ve7bxctx@e6600>
>> even claims to implement the full standard.
I think it might, but "claims to implement the full standard" is not the
same as "claims to be fully standards-compliant" which of course is not
the same as "is fully standards-compliant".
Strictly speaking, it is impossible to be fully compliant to ISO
14882-1998 since the standard itself contains self-contradictions. I think
most (hopefully all) of those have been dealt with for the upcoming
revision of the standard though.
FE
Date: 21 Sep 2008 18:51:03
Message: <48d6cfd7@news.povray.org>
Slime wrote:
>> I clicked on the big shiny button that says "toggle breakpoint". It looks
>> like a big grey square, and sure enough, when you click it, a big grey
>> square appears at that line of the source code. Only by accident did I
>> discover that you have to click on this breakpoint to make a big red dot
>> appear on it, and *then* it will do something. (It is unclear to me what
>> the hell use an inactive breakpoint is, but still...)
> Odd. You can also just press F9 to make a breakpoint.
> Inactive breakpoints are usually useful when you've added a complicated
> condition to a breakpoint and you want to turn it off but get it back
> later.
But it's also "useful" to make the default an ACTIVE breakpoint!
Date: 21 Sep 2008 18:51:33
Message: <48d6cff4@news.povray.org>
>> later.
Or you can enable/disable them by hand while debugging.
