POV-Ray : Newsgroups : povray.off-topic : Doomed? Server Time
2 Jul 2026 18:57:45 EDT (-0400)
  Doomed? (Message 18 to 27 of 57)
Subject: Re: Doomed?
Date: 21 Sep 2008 12:33:32
Message: <48d6775c$1@news.povray.org>
Darren New wrote:
> But yeah, it's a big and complex tool. It'll take a day or two to learn
> how it works.
Tell me about it! I just discovered that adding a breakpoint doesn't
actually do anything - you have to add a breakpoint *and* turn it on. o_O
WTF? I ask you...!
http://blog.orphi.me.uk/
Subject: Re: Doomed? Yep!
Date: 21 Sep 2008 13:51:24
Message: <op.uhuejxic7bxctx@e6600>
On Sun, 21 Sep 2008 18:28:44 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
> you can use the keywords "and", "or" and "not" in place of symbols.
Don't. Not all compilers support this, and very few programmers are
accustomed to it.
> However, Visual C++ doesn't seem to like it.
This one in particular does not by default.
You can make it support it by checking the option "Disable language
extensions" which you probably should anyway.
FE
Date: 21 Sep 2008 14:01:53
Message: <48d68c11$1@news.povray.org>
> accustomed to it.
According to the tutorial, "if your compiler does not support this, it
is not a standards-compliant C++ compiler". (I'm only saying what the
tutorial says; I have no idea if that's correct or not.)
I keep trying to sort out in my head which combination of symbols mean
bitwise operations and which ones mean logical operations. Using names
makes the difference clear. (To me anyway.) Of course, none of this
helps with trying to read other people's code.
(Now Haskell also uses symbols for both. However, in Haskell, if you try
to perform logical operations on numbers, you get a type error, and vice
versa. Unfortunately C++ inherits C's braindead "hey, if you can
represent it as an unstructured bit pattern, it's an int, right?"
mentallity.)
Uh-huh. Yeah, I'll be doing that. I'd like to write code that will
compile everywhere. ;-)
Who'd have thought? An M$ product bending the standard slightly...
</sarcasm>
Date: 21 Sep 2008 14:03:21
Message: <48d68c69@news.povray.org>
Orchid XP v8 schrieb:
>> learn how it works.
> WTF? I ask you...!
Huh? Might depend on how you add the breakpoint, but if you just click
on the grey bar left of your sourcecode, an (active) breakpoint is added
to that line. How did you add an incactive breakpoint?
Manuel
Date: 21 Sep 2008 14:16:31
Message: <48d68f7f$1@news.povray.org>
>> WTF? I ask you...!
I clicked on the big shiny button that says "toggle breakpoint". It
looks like a big grey square, and sure enough, when you click it, a big
grey square appears at that line of the source code. Only by accident
did I discover that you have to click on this breakpoint to make a big
red dot appear on it, and *then* it will do something. (It is unclear to
me what the hell use an inactive breakpoint is, but still...)
Date: 21 Sep 2008 15:03:03
Message: <op.uhuhvcng7bxctx@e6600>
On Sun, 21 Sep 2008 20:02:00 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
There is currently as far as I know only one C++ compiler vendor that even
claims to implement the full standard.
The bitwise operators are all single character. There are also only four
of them. You get used to it.
> Using names makes the difference clear. (To me anyway.)
> Of course, none of this helps with trying to read other people's code.
Which is why it would be better in the long run to simply get used to the
symbols.
> mentallity.)
The bitwise operators in C & C++ only work on integers. However, there are
a few silent conversions to 'int' to be aware of.
> </sarcasm>
I hope you do not think GCC is standards-compliant by default either.
FE
Date: 21 Sep 2008 15:13:20
Message: <48d69cd0$1@news.povray.org>
Yeah, I guess so.
> the symbols.
It has a flavour.
>> try to perform logical operations on numbers, you get a type error,
>> and vice versa. Unfortunately C++ inherits C's braindead "hey, if you
>> can represent it as an unstructured bit pattern, it's an int, right?"
>> mentallity.)
> are a few silent conversions to 'int' to be aware of.
Indeed.
(The other thing is that in Haskell, the logical ops are always there,
while the bitwise ones are hidden away in some library and you have to
explicitly ask for them.)
>> </sarcasm>
I gather that GCC provides various extensions of its own too, yes. ;-)
Date: 21 Sep 2008 15:58:51
Message: <48d6a77b@news.povray.org>
> According to "Thinking in C++", you can use the keywords "and", "or" and
> "not" in place of symbols. GCC accepts this. However, Visual C++ doesn't
> seem to like it.
Ewww, someone got Visual Basic in my C++.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 21 Sep 2008 16:00:41
Message: <48d6a7e9$1@news.povray.org>
> I clicked on the big shiny button that says "toggle breakpoint". It looks
> like a big grey square, and sure enough, when you click it, a big grey
> square appears at that line of the source code. Only by accident did I
> discover that you have to click on this breakpoint to make a big red dot
> appear on it, and *then* it will do something. (It is unclear to me what
Odd. You can also just press F9 to make a breakpoint.
Inactive breakpoints are usually useful when you've added a complicated
condition to a breakpoint and you want to turn it off but get it back later.
 - Slime
Date: 21 Sep 2008 16:02:31
Message: <48d6a857$1@news.povray.org>
> Like if you go File > New > File... and then select "CPP File", it doesn't
> add it to the current project. (And opens the file browser in a random
> spot.) You must instead right-click on the "Source Files" node of the
> current project and select "Add item..." and select "CPP File", and *then*
> it automatically puts the file in the correct place, adds it to the
> project, and lets you compile and run it. Sheesh!
I haven't used the Express edition, but what I normally do is go to
Project -> Add New Item, which creates a file *and* adds it to the current
project.
 - Slime
