POV-Ray : Newsgroups : povray.off-topic : Can't screen-grab my own MPEG-I. Is this DRM? Server Time
7 Sep 2024 03:23:15 EDT (-0400)
  Can't screen-grab my own MPEG-I. Is this DRM? (Message 1 to 10 of 10)
Subject: Can't screen-grab my own MPEG-I. Is this DRM?
Date: 17 Sep 2008 21:35:00
Message: <web.48d1af5b4e31f5f434d207310@news.povray.org>
I have an MPEG-I that I made myself.  I wanted to screen grab a frame from it to
share with someone in a letter.  I was unable.
With several viewing applications, when I screen-grabbed the playing animation,
I ended up with a blank screen in that part of the window that was showing the
animation.
Q: Is this DRM, in the sense that someone made them set up movie players that
way, or is it an inevitable and unintended function of the way computers handle
moving vs. still images?
I had always assumed it was DRM when I couldn't screen grab a frame from a
store-bought DVD played on Windows XP; but I see it so often on all my linux
apps that I'm guessing it's just the technology.
Subject: Re: Can't screen-grab my own MPEG-I. Is this DRM?
Date: 17 Sep 2008 21:58:37
Message: <48d1b5cd$1@news.povray.org>
	Not DRM. I don't know the details, but it's a function of the video
driver. If the rendering is done via hardware, then the usual screenshot
won't work. If you have a software renderer, then it will.
	I think some good players have an option to take a screenshot - where
they ensure it'll get one even if you're using a hardware renderer.
If a mute swears, does his mother wash his hands with soap?
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 18 Sep 2008 04:03:20
Message: <48d20b48$1@news.povray.org>
Some thing with 3D computer games. Because the data doesn't exist in the
framebuffer but is composited in in hardware, copying the framebuffer to
a file won't capture that data.
Depending on the specifics, there *are* ways to do this though. Just the
standard screen capture won't do it, that's all.
Date: 18 Sep 2008 10:05:09
Message: <48d26015@news.povray.org>
  It's frame buffer optimization. Nothing to do with DRM. This feature has
existed for long before DRM was even an idea.
  The player (usually using DirectX, or in Linux by using the video driver)
is not drawing the video on your screen memory at all, but to a frame buffer.
A frame buffer is a separate chunk of RAM which has been mapped to the
video card by the memory bus.
  In the actual screen memory the pixels in the area where the video should
appear have a certain color. When the video card detects pixels of that
color inside that area, it will substitute them with the contents of the
frame buffer instead. (This allows even the screen to have a different
bit depth than the frame buffer, which allows eg. having your screen to
be in paletted 8-bit mode, while the video player is showing the video
in full color mode.)
  When you make a screen capture, you are simply capturing the screen memory,
and thus you are only get those specially-colored pixels. The screen capture
routine knows nothing of frame buffers.
  You can turn this frame buffer optimization off, after which the screen
capturing becomes possible. In Windows there is a setting somewhere which
you can use to set the level of video acceleration. Lower it until you can
screen-capture your video. (Obviously screen refreshes may become quite
sluggish.)
  If you are using mplayer in linux, simply play the video with -vo x11
and you'll be able to screen-capture it. (The x11 driver does not use
hardware acceleration.)
Date: 18 Sep 2008 13:18:29
Message: <48d28d65@news.povray.org>
"gregjohn" <pte### [at] yahoocom> wrote in message
news:web.48d1af5b4e31f5f434d207310@news.povray.org...
>it to
      Have you tried Fraps? Map a key in the screenshots section, open your
MPEG and hit pause quickly (or play it until just before your desired shot).
Then open Fraps, play your MPEG, and hit that key when you want. You can
also set it to take screens at timed intervals like every 30 seconds or 120
seconds, etc.
     This is the free version I'm talking about. This will give you a small
Fraps watermark at the top of the screen if recording a video of your MPEG,
but you don't get this with screenshots.
      ~Steve~
Date: 18 Sep 2008 13:50:26
Message: <48d294e2@news.povray.org>
> seconds, etc.
  Does it understand frame buffers and is it capable of capturing them?
Date: 18 Sep 2008 13:59:15
Message: <48d296f3$1@news.povray.org>
It's marketed as being for doing screen captures of games, which due to
their utilisation of your 3D hardware also don't usually capture
properly. But IDDQD...
http://blog.orphi.me.uk/
Date: 18 Sep 2008 14:03:02
Message: <48d297d6$1@news.povray.org>
news:48d294e2@news.povray.org...
>> your
>> shot).
>> 120
>> seconds, etc.
      Explain to me what a 'frame buffer' is, and I'll try to answer that.
       ~Steve~
>                                                          - Warp
Date: 18 Sep 2008 15:01:36
Message: <48d2a590@news.povray.org>
  I already did in another post in this thread.
Date: 18 Sep 2008 15:21:57
Message: <48d2aa55$1@news.povray.org>
news:48d2a590@news.povray.org...
>> that.
 Yep, I see it. Well, I don't think frame buffering comes into this with
Fraps. If you 'record' say, a vid of your own custom-made Crysis map, then
Fraps will record it as it happens within the game itself. If you have a
game that is stuttering on a low-end comp, Fraps will record that
stuttering, and vice-versa.
     No idea where frame buffering comes into this scenario.
      ~Steve~
>                                                          - Warp
