POV-Ray : Newsgroups : povray.off-topic : Simply CGI Server Time
9 Apr 2026 00:49:52 EDT (-0400)
  Simply CGI (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Simply CGI
Date: 12 Sep 2008 17:49:05
Message: <48cae3d1@news.povray.org>
Invisible wrote:
> I want to write a large, complex CGI program.
> However, I do *not* feel like installing and configuring Apache just so
> I can run my CGI program.
> Does *anybody* know of a nice, simple little program that will accept
> HTTP requests and pass them to my CGI program? All I really want is a
> tiny little program to parse the HTTP headers, feed them into my CGI
> program, and pass back the answers to the web browser. But I can't seem
> to find anything that will do that... All I can find is full-featured
> web servers that you have to install and configure. I just want a
> single-file executable... Anybody know of one?
In KDE, in any kioslaves-enabled application (like the Konqueror browser),
you can use cgi:/home/invisible/mycgiapp as a URL and it will just work :)
Date: 13 Sep 2008 05:27:15
Message: <48cb8773$1@news.povray.org>
Warp wrote:
>   Yeah. He wants a web server without installing a web server.
And I got one. Yay for me! :-)
http://blog.orphi.me.uk/
Date: 13 Sep 2008 06:38:45
Message: <48cb9835$1@news.povray.org>
Orchid XP v8 a écrit :
> Orchid XP v8 wrote:
>> 2. It seems to be able to run CGI *scripts*, but not compiled,
>> executable binary programs. I'm still frobbing the configuration file,
>> but it's not looking good...
> OK, *finally*...
> Create a small file called Foo.cgi that simply contains the line
>   #!Foo.exe
> and *at last* the server does what I want it to!
Apparently this server only checks the extensions of the files, so you
could just rename Foo.exe to Foo.cgi I suppose. Or better still, launch
shttpd with the appropriate option telling it that .exe are CGI files:
shttpd -cgi_ext "exe"
Seems to work on my linux box with any arbitrary extension...
Vincent
Date: 13 Sep 2008 07:06:57
Message: <48cb9ed1@news.povray.org>
>> OK, *finally*...
>>   #!Foo.exe
I tried that, but it doesn't work. If it's .cgi, it "checks the first
line of text to determine what interpretter to run".
Also tried that and it didn't work.
The hack above does, however, work.
Date: 13 Sep 2008 07:45:32
Message: <48cba7dc@news.povray.org>
  You got a web server and you didn't install it? How can that work?
Date: 13 Sep 2008 08:57:03
Message: <48cbb89f@news.povray.org>
>> Or better still, launch shttpd with the appropriate option telling it
OK, so that's one more reason for me to keep running Linux I guess,
where it works fine and starts instantaneously :-)
Maybe you should throw a note to the author though, perhaps the
behaviour on Windows is not what's intended...
Vincent
Date: 13 Sep 2008 08:58:17
Message: <48cbb8e9$1@news.povray.org>
You put the executable file in a directory, double-click it, and it
runs. Nothing to install, nothing to uninstall afterwards. And only a
few hundred KB too. Which is basically what I was looking for...
Date: 13 Sep 2008 09:01:21
Message: <48cbb9a1$1@news.povray.org>
So you've installed it. OTOH you haven't needed to configure it or your
system.
John
"Eppur si muove" - Galileo Galilei
Date: 13 Sep 2008 09:57:47
Message: <48cbc6db@news.povray.org>
  We clearly have completely different definitions of "installing a
program".
Date: 13 Sep 2008 10:14:47
Message: <48cbcad7$1@news.povray.org>
> program".
Yes.
To me, if you can use a program just by running it, that's not
"installing" it.
If, however, you have to insert DLLs into particular folders, create
registry keys and configure environment variables, that's "installing"
something.
The former means you can just drop the binary only (say) a USB flash
drive and use it anywhere. The latter means that you have to do some
setup (and probably removal) at every PC.
