POV-Ray : Newsgroups : povray.off-topic : Linux & drivers Server Time
16 May 2026 15:16:33 EDT (-0400)
  Linux & drivers (Message 24 to 33 of 43)
Subject: Re: Linux & drivers
Date: 5 Sep 2008 12:14:29
Message: <48c15ae5$1@news.povray.org>
Warp wrote:
>   Another question is whether the Windows usage license allows you to do
> that...
According to the BartPE page...
Also, according to the Microsoft EULA for Windows XP/2003, a user may
not simultaneously use more installations of these operating systems
than the user has license(s) for.
I.e., if you only run BartPE on machines for which you have a Windows
license already, you shouldn't be violating the license. I'm not a
lawyer, so I really couldn't say more than that.
Obviously, if you make a BartPE disk and boot it on half a dozen
machines which you bought with Linux preinstalled, you're likely
>   Commerciality also makes it difficult to distribute projects like this:
> http://en.wikipedia.org/wiki/Hikarunix
No doubt. (And yes, that's a pretty silly project. :-)
Date: 5 Sep 2008 12:18:24
Message: <48c15bd0$1@news.povray.org>
Hmmm... Unless you create it from an XP disk you never installed and
therefore never agreed to the license for. That could be a curious
situation.  (Altho, I *think* I remember BartPE asking me if I agreed to
the XP license before it would make its copies. But that would seem easy
to patch out of BartPE. :-)
Date: 5 Sep 2008 12:57:34
Message: <48c164fe$1@news.povray.org>
On Fri, 05 Sep 2008 08:57:43 +0100, Invisible wrote:
>>> My motherboard uses the nVidia nForce 4 chipset, and as a result many
>>> Linux live CDs can't see any of the SATA drives. However, they all
>>> find the PATA ones just fine.
>> Weird, my HP system here has that same chipset on it, and the live
>> discs do OK with it - SATA drive works beautifully with openSUSE 11.0
>> running on it, too.
> When I tried this, openSUSE 11.0 did not exist.
Well, as Darren said, 3 months is an eternity in the Linux world.  :-)
> (IOW, now that it's no longer a brand new chipset, maybe drivers are
> more widely available.)
That most certainly is the case. :-)
Jim
Date: 5 Sep 2008 12:58:09
Message: <48c16521$1@news.povray.org>
On Thu, 04 Sep 2008 20:53:14 -0400, Warp wrote:
>   Does Windows support creating so-called live CDs at all (maybe through
> extensive hacking)?
In a roundabout way, yes - BartPE is one that I've seen used for
specialized applications like imaging.
Jim
Date: 5 Sep 2008 12:59:16
Message: <48c16564$1@news.povray.org>
On Fri, 05 Sep 2008 08:53:25 -0400, Tom Austin wrote:
> My understanding is that Linux and NTFS still aren't the best of
> friends.
ntfs-3g solves those issues.
Jim
Date: 5 Sep 2008 13:15:53
Message: <op.ug0p8ri57bxctx@e6600>
On Fri, 05 Sep 2008 09:57:07 +0200, Invisible <voi### [at] devnull> wrote:
>>> I still have no idea what "force deth" actually means...
>>  It makes more sense as "forced eth", even though the idea of a module
>> that forces death is somewhat amusing...
>>  Apparently, the ambiguity is at least partially intentional.
> Well, "force" because it's the nForce 4 chipset. "eth" because it's the
> Ethernet interface. I have no idea what the "d" is for.
Presumably "driver".
> ("Disassembled"? As in, they reverse-engineered a drives from the
> Windoze version?)
The Linux version actually.
http://kerneltrap.org/node/1606
FE
Date: 5 Sep 2008 13:29:46
Message: <op.ug0qvwv47bxctx@e6600>
On Fri, 05 Sep 2008 18:07:32 +0200, Darren New <dne### [at] sanrrcom> wrote:
> The boot sector is really only part of one sector. That doesn't seem
> like enough room to write code to find NTLDR or whatever the second step
> of Linux boot code is (GRUB I assume, or LILO). Especially given the
> wide range of partition types and RAID types a boot partition is allowed
> to be on in Linux.
> How does it fit enough of the file system code into the boot mechanism
> to find the files it needs? Is there something special, such that (say)
> copying the file to a different place on the disk would keep things from
> booting?
http://www.gnu.org/software/grub/manual/html_node/Bootstrap-tricks.html
http://www.gnu.org/software/grub/manual/html_node/Images.html
I know from experience that moving stuff around on the boot partition can
break GRUB.
FE
Date: 5 Sep 2008 13:44:12
Message: <48c16fec$1@news.povray.org>
>> step of Linux boot code is (GRUB I assume, or LILO). Especially given
>> the wide range of partition types and RAID types a boot partition is
>> allowed to be on in Linux.
>> (say) copying the file to a different place on the disk would keep
>> things from booting?
> can break GRUB.
So the location of the real meat is hard-coded into the MBR. Neat...
http://blog.orphi.me.uk/
Date: 5 Sep 2008 13:46:14
Message: <48c17066$1@news.povray.org>
>> Windoze version?)
Ah. So there *is* a Linux driver, the guys just dislike closed-source
drivers, so they wrote their own?
Date: 5 Sep 2008 13:49:19
Message: <48c1711f$1@news.povray.org>
>> friends.
Several programs claim to "solve" these issues - with varying degrees of
safety warnings. ;-)
(There are kernel NTFS drivers, there's a gizmo that loads NTFS.SYS from
your Windoze partition and uses that, there are read-only NTFS drivers,
and so on and so forth.)
