POV-Ray : Newsgroups : povray.off-topic : Coolest thing EVER! Server Time
17 May 2026 00:27:33 EDT (-0400)
  Coolest thing EVER! (Message 91 to 100 of 112)
Subject: Re: Coolest thing EVER!
Date: 2 Sep 2008 15:20:09
Message: <48bd91e9@news.povray.org>
Darren New wrote:
> Invisible wrote:
>> You can use that to make real mode applications (e.g., DOS programs)
>> think they have the machine to themselves. But that doesn't work for a
>> protected mode program such as an OS.
> I stand corrected. :-)
Some of us have actually *read* the IA32 reference manual. ;-)
[OTOH, I guess some others have written actual IA32 programs, so...]
http://blog.orphi.me.uk/
Date: 2 Sep 2008 17:14:13
Message: <48bdaca5$1@news.povray.org>
On Sun, 31 Aug 2008 14:46:44 +0100, Orchid XP v8 wrote:
> OK, so I realise I'm probably about 20 years behind everybody else, but
> seriously... this is THE coolest thing I've seen this year! I would
> never have believed it was physically possible - and certainly not
> without spending hours setting it up. I can't get over how EASY this
> was!
Told ya that Virtualization was useful. :-)
Jim
Subject: Re: Hardware
Date: 2 Sep 2008 17:20:50
Message: <48bdae32@news.povray.org>
On Tue, 02 Sep 2008 18:24:52 +0100, Orchid XP v8 wrote:
>> Quote, from the wiki page you linked
>> "VMware and similar virtualization software for the x86 must employ
>> binary translation techniques to trap and virtualize the execution of
>> certain instructions. These techniques incur some performance overhead
>> as compared to a VM running on a natively virtualizable architecture"
> Right. So it only emulates some instructions, instead of all of them?
Not really; at least as I understand it, if you had to emulate the
instructions, you'd have to recompile.  What VMware and programs like it
do is trap them and execute them within their 'sandbox'.  It's not really
the same as emulation, which tends to be more of a translation process.
Of course, if you have a chip that supports VT (for example), then that's
entirely different.  Or a dual-core processor/MP system, which I think
VMware also can take advantage of, by using one core for the virtualized
system and one for the host.  Not sure how they do that, I don't imagine
it's well documented publicly.
I do know when I played around with virtualization a few years ago, there
was a need to recompile kernels that were running (one of the issues that
prevented NetWare from running natively in XEN, for example - NW kernel
would've had to be rewritten in order to deal with the fact that it is a
nonpreemptive OS - from what I understand from people who have worked
closely with the NW kernel developers, that makes virtualization (at
least as implemented in XEN 2) more difficult to achieve.
Jim
Date: 2 Sep 2008 17:22:12
Message: <48bdae84$1@news.povray.org>
On Mon, 01 Sep 2008 09:34:34 +0100, Invisible wrote:
> But surely if you're going to run a guest OS on the physical host CPU,
> the host CPU would need to have hardware support for enforcing the host
> seperation?
Nope.  I started running VMware back at version 2.x (now on version 6),
hardware at that time didn't have any concept of virtualization.  The
separation was all done in software (and very well isolated as well -
can't think of any time where the guest took the host down when the host
was clean).
Jim
Date: 2 Sep 2008 17:23:11
Message: <48bdaebf$1@news.povray.org>
> I've been thinking of playing with some virtual machine technology, but
> I wasn't aware there was one under Windows that would run Linux. Which
> virtual machine are you running here? (I.e., what's the Windows
> software?)
VMware has run Linux under Windows for *ages*.....
Jim
Date: 2 Sep 2008 17:24:34
Message: <48bdaf12$1@news.povray.org>
On Mon, 01 Sep 2008 12:57:21 -0700, Darren New wrote:
> As far as I understand it, an OS running under Xen has to know it's
> running under Xen, doesn't it?
I understood that was the case under 2.0, but not sure about XEN 3.x
Jim
Date: 2 Sep 2008 17:50:10
Message: <48bdb511@news.povray.org>
> was clean).
Many security researchers intentionally run malicious and quite dangerous
software inside a VM, so it better have good isolation :)
Date: 2 Sep 2008 17:51:32
Message: <48bdb563@news.povray.org>
"Gail" <gail (at) sql in the wild (dot) co [dot] za> wrote:
> "VMware and similar virtualization software for the x86 must employ binary
> translation techniques to trap and virtualize the execution of certain
> instructions. These techniques incur some performance overhead as compared
But they're still more than acceptably fast.
Date: 3 Sep 2008 11:38:21
Message: <48beaf6d$1@news.povray.org>
Orchid XP v8 wrote:
> Wait a sec - small firm, just started up, *testing*???
Yes. Even them can do thing properly. I know one of those.. Oh, wait, I
actually own part of it, I was building it ;).
>  From what I've seen most *large* companies don't bother to test
> anything, never mind small startups. ;-)
Yes. Even them can do things improperly. Luckily the one I work for doesn't.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 3 Sep 2008 11:42:58
Message: <48beb082$1@news.povray.org>
> running under Xen, doesn't it?  It's actually quite a large leap from
> "we can run multiple OSes" to "we can run multiple OSes that don't have
> to cooperate with the hypervisor".
That's the difference, what hardware virtualization support (might be
that also Xen 3.xx is demanded, as Jim said - dunno, 3.xx has been
around for long enough for me to gotten started with it) does for Xen.
Without such, the OS needs to know it's running under Xen, but if you
have it, you can run unmodified guest OS's also.
Eero "Aero" Ahonen
    http://www.zbxt.net
