![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp <war### [at] tag povray org> wrote:
> gregjohn <pte### [at] yahoo com> wrote:
> > The question then, if Linux is chosen, is which distro is best for guiding your
> > Dad in for a landing over the phone. I've seen Linux big-wigs in forums say,
> > "I positively do not care if Linux is ever the right OS for someone's
> > grandfather. UNIX never was." I think I'd stay away from a distro where too
> > much say was purists about closed source drivers. Folks' Dads might not be
> > able to roll their own.
> Well, you have two options:
> 1) A computer with an OS which has a steep learning curve.
> 2) A computer with an OS that doesn't even boot.
> Which of the two options is better?
3) A computer with a version of an OS which does NOT do crazy things like make
you recompile the kernel to install a wireless driver in order to meet some
ideologue's view of "freedom". [Debian circa 2005 did this.] Ubuntu, for the
moment, unless RMS's legions get to Mark, does not.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have had linux in my computer for many years (started with Suse 9.3,
then upgraded to 10.2), and I have not needed to recompile the kernel
even once.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> make
>> some
>> the
> even once.
I tried several different Linuxes on my machine over the last couple of
years, and I never managed to get past the really steep learning curve that
would enable me to get the wireless card working. I found some ridiculous
50 page PDF explaining in detail how to do it, but then I got stuck on like
page 3 when something it told me to do didn't exist on my system. Every
time I just gave up (and it's not like I didn't try for several evenings and
several hours on Google to get it working). And I'm not even going to
mention the first few times I tried Linux (maybe 5 years ago) where I got a
big green triangle across half the screen permanently, or that I couldn't
get 3D acceleration working, or ..., or .... It's just too much hassle to
learn when you can't even get started.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott <sco### [at] scott com> wrote:
> It's just too much hassle to learn when you can't even get started.
Then don't use it. It's that simple.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 29-Aug-08 9:50, Invisible wrote:
> andrel wrote:
>> My wife did that once. Try ctrl-alt-shift up (or down or sideways).
>> If that works, disable that shortcuts in the advanced settings of your
>> monitor.
>> Shortcuts are handy if the monitor physically can rotate, if not they
>> are annoying.
> Yeah, I've seen monitors that do. But the Dell monitors at work don't
> rotate like that...
> As it is, I managed to open the video options window and manually adjust
> the setting. The hardest part was operating the mouse with its axies
> transposed -
been there, done that.
> the user thought I was God-like for pulling that off! ;-)
unfortunately not, the user was my wife.
Did you turn off the keyboard shortcuts? Or do you want to play God
again later?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Warp" <war### [at] tag povray org> wrote in message
news:48b833ac@news.povray.org...
He isn't. It's that simple. ;)
~Steve~
> - Warp
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> again later?
Well, we have 12 identical machines, all presumably with these keys
turned on, and this is so far the first and only time this problem has
surfaced. So presumably the key combination required is fairly hard.
If the problem recurrs, I'll just look up what the key combination is. ;-)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I wish it were as simple to shut up the Linux fanboys who spurt out "switch
to linux" in response to any problem anyone has on windows ;-) Don't any of
them realise that if the original poster is having some (presumably quite
trivially solvable) problem on windows, chances that they manage on linux
*better* than windows are quite small?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The system not booting at all doesn't sound like a trivial problem to me.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Usually it is, but how trivial the problem is is not the point, the point is
the person isn't automatically going to become a whizz at Linux and never
get stuck again. In fact I would suspect that when people reply with
"switch to Linux", if that person actually did switch, they would have many
more problems than the one they were asking about in the first place - like
not being able to get online to ask others for help ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
