POV-Ray : Newsgroups : povray.off-topic : Data recovery Server Time
7 Apr 2026 22:34:48 EDT (-0400)
  Data recovery (Message 81 to 90 of 128)
Subject: Re: Data recovery
Date: 1 Sep 2008 12:26:55
Message: <48bc17cf$1@news.povray.org>
Invisible wrote:
>> Or just mount the separate volume as a subdirectory of the system
>> volume. :-)
> Does Windoze let you do that yet?
Yes, that's also possible. IIRC it came with W2k.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 12:38:42
Message: <48bc1a92$1@news.povray.org>
Invisible wrote:
> Does anybody actually use RAID on a home system?
Yes.
These
aero@grunka ~ $ dmesg|grep 7\:\ ST37
[    6.425893] ata2.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
[    7.613720] ata4.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
[    8.198858] ata5.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
[    8.783579] ata6.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
4pcs of 750G Barracudas give me this:
aero@grunka ~ $ df -h|grep md5
/dev/md5              2.1T  451G  1.7T  22% /home
That's RAID-5 -array, so it can handle a break-up on any of those disks.
These are RAID-1:
aero@grunka ~ $ df -h|egrep 'md0|md2'
/dev/md0               84G   20G   65G  24% /
/dev/md2               88G   22G   67G  25% /netroot
And so are these:
garmaugh ~ # df -h|grep md
/dev/md/0             962M  179M  734M  20% /
/dev/md/2             9.2G  2.1G  6.7G  24% /usr
/dev/md/3              13G  708M   12G   6% /var
> My dad is the only person I know who's tried it, and he has lost far
> more data due to RAID glitches than to any physical hardware failure!
I've also lost some data due to my own stupidity with RAID. OTOH, I've
saved at least 5 times that amount of data from disk breaks with RAID.
> have to tell it to rebuilt the array (BE CAREFUL TO SELECT THE RIGHT
> SOURCE DRIVE!)
I too can tell you that :). That's the way I erased one array - I synced
the empty disk over a fuller one.
> and wait many, many hours for that to complete. And then
> it would work for another few hours before failing one of the drives again.
Freaking slow, if RAID-1 takes many, many hours. That 2-terabyte array
took some hours and it's RAID-5, so the computer had to calculate all
the data. RAID-1 is "only" reading and writing and it's much faster.
> In summary, it was hopeless and an utter waste of time.
In summary, he did it wrong ;).
>> Yep, that's true and very reasonable. You should also RAID the
>> work-partition and take scheduled backups ;).
> Backup onto *what*?
Ie. on external HD?
> I have, like, 100 GB of data now. I'm not aware of anything large enough
> to hold that other than another HD. (Or an LTO tape...)
Surf man, surf.
http://www.ebuyer.com/product/143877
Smaller ones are cheaper:
http://www.ebuyer.com/product/128601
Plug it in, sync it (ie. with rsync oslt) and plug it out. Or buy 2 of
them, schedule a sync for every night and manually change the cable to
another drive every day (this is because offline backups are freaking
good idea).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 12:41:49
Message: <48bc1b4d@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48bc0807$1@news.povray.org...
>>> I mean, *now* I have multiple seperate physical HDs so it's kind of
>>> unavoidable having seperate logical volumes.
>> No, it isn't. With RAID you can combine several HDs to one logical
>> volume, which even can hold if one of the disks break down.
Yup. My 'server' has four 160 GB sata drives in a RAID 5 config. Since it's
also my first stage backup location, I wanted redundancy. Just wish I'd
bought larger drives.
Date: 1 Sep 2008 12:43:40
Message: <48bc1bbc@news.povray.org>
news:48bc06f6$1@news.povray.org...
>> Note you can also make "my documents" and "desktop" (and a bunch of other
>> system-defined folders) point to anywhere you want, including other
>> drives.
> Heh. If only that were actually true...
It is true. I can't remember offhand how to do it, but it's very possible
since Win Xp (I think).
Date: 1 Sep 2008 12:59:20
Message: <48bc1f68@news.povray.org>
"Gail" <gail (at) sql in the wild (dot) co [dot] za> wrote in message
news:48bc1bbc@news.povray.org...
>>> other system-defined folders) point to anywhere you want, including
>>> other drives.
http://support.microsoft.com/kb/310147 (for win xp)
Date: 1 Sep 2008 14:57:10
Message: <48bc3b06@news.povray.org>
>>>> other drives.
>> possible since Win Xp (I think).
Well who'd have thought it. There's actually a UI for that...
http://blog.orphi.me.uk/
Date: 1 Sep 2008 15:03:23
Message: <48bc3c7b$1@news.povray.org>
> Yes.
> These are RAID-1:
> And so are these:
Is that software RAID or hardware RAID?
My dad went with a hardware RAID solution, and it was utterly useless.
You had to resilver it every few hours because it kept breaking.
>> and wait many, many hours for that to complete. And then it would work
Ever tried to perform a low-level format on a HD? No matter what size it
is, it always takes an extremely long time. (The bigger the drive, the
faster it is, but the power to weight ratio seems fairly constant, so it
always takes a long time.) Formatting a huge drive with, say, FAT or
NTFS only takes a few minutes, but a low-level format takes an hour or more.
Resilvering the mirror was similar. It's mirrored at the hardware level,
so the disks must be block-by-block identical.
>> Backup onto *what*?
> Ie. on external HD?
Yeah, I guess... Doesn't seem like you're gaining a huge amount, but I
guess it's better than nothing.
>> enough to hold that other than another HD. (Or an LTO tape...)
> Surf man, surf.
...in other words, a HD. Like what I said. :-P
Date: 1 Sep 2008 15:04:28
Message: <48bc3cbc$1@news.povray.org>
> it's also my first stage backup location, I wanted redundancy. Just wish
> I'd bought larger drives.
Heh. And I thought *I* was crazy for owning just _one_ 160 GB drive in a
home PC...
What on earth do you use it for?
(I filled mine saving large uncompressed videos rendered with POV-Ray.)
Date: 1 Sep 2008 15:11:43
Message: <48bc3e6f@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:48bc3c7b$1@news.povray.org...
> My dad went with a hardware RAID solution, and it was utterly useless. You
Hardware RAID on a desktop machine? Hardware raid controllers are
exceedingly expensive. Are you sure it wasn't RAID implemented in the
firmware/drivers?
That's far more common on desktop-type machines. It's what I've got in my
'server'
Date: 1 Sep 2008 15:26:29
Message: <48bc41e5$1@news.povray.org>
>> volume. :-)
Windows has let you do that for roughly ... since before Windows.
It does seem to have a little bit of trouble "sticking" in my
experience. Not sure why. But it's supposed to work, certainly.
