POV-Ray : Newsgroups : povray.off-topic : Data recovery Server Time
7 Apr 2026 08:52:56 EDT (-0400)
  Data recovery (Message 79 to 88 of 128)
Subject: Re: Data recovery
Date: 1 Sep 2008 11:15:02
Message: <48bc06f6$1@news.povray.org>
>>> I mean, *now* I have multiple seperate physical HDs so it's kind of
>>> unavoidable having seperate logical volumes.
>> No, it isn't. With RAID you can combine several HDs to one logical
>> volume, which even can hold if one of the disks break down.
> Or just mount the separate volume as a subdirectory of the system
> volume. :-)
Does Windoze let you do that yet?
> Note you can also make "my documents" and "desktop" (and a bunch of
> other system-defined folders) point to anywhere you want, including
> other drives.
Heh. If only that were actually true...
[No, wait. I take that back. If I had *my* way, I'd have that hated My
Documents folder permanently removed.]
http://blog.orphi.me.uk/
Date: 1 Sep 2008 11:19:35
Message: <48bc0807$1@news.povray.org>
Does anybody actually use RAID on a home system?
My dad is the only person I know who's tried it, and he has lost far
more data due to RAID glitches than to any physical hardware failure!
to it in a RAID-1 configuration. Every 6 hours or so, the RAID
controller would "fail" one of the drives and stop using it. Then you'd
have to tell it to rebuilt the array (BE CAREFUL TO SELECT THE RIGHT
SOURCE DRIVE!) and wait many, many hours for that to complete. And then
it would work for another few hours before failing one of the drives again.
In summary, it was hopeless and an utter waste of time.
Now all the *servers* here at work have RAID on them, but they have
expensive high-end UltraSCSI 360 RAID controllers with the
battery-backed RAM and so on and so forth. Nobody is rich enough to put
those in a desktop machine.
>> But I did it back when I only had one drive too. Makes reinstalling
>> the OS that much easier without losing work. (If anything on my PC
>> could be considered "work".)
> Yep, that's true and very reasonable. You should also RAID the
> work-partition and take scheduled backups ;).
Backup onto *what*?
I have, like, 100 GB of data now. I'm not aware of anything large enough
to hold that other than another HD. (Or an LTO tape...)
Date: 1 Sep 2008 12:26:55
Message: <48bc17cf$1@news.povray.org>
>> volume. :-)
Yes, that's also possible. IIRC it came with W2k.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 12:38:42
Message: <48bc1a92$1@news.povray.org>
Yes.
These
aero@grunka ~ $ dmesg|grep 7\:\ ST37
[    6.425893] ata2.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
[    7.613720] ata4.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
[    8.198858] ata5.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
[    8.783579] ata6.00: ATA-7: ST3750640AS, 3.AAK, max UDMA/133
4pcs of 750G Barracudas give me this:
aero@grunka ~ $ df -h|grep md5
/dev/md5              2.1T  451G  1.7T  22% /home
That's RAID-5 -array, so it can handle a break-up on any of those disks.
These are RAID-1:
aero@grunka ~ $ df -h|egrep 'md0|md2'
/dev/md0               84G   20G   65G  24% /
/dev/md2               88G   22G   67G  25% /netroot
And so are these:
garmaugh ~ # df -h|grep md
/dev/md/0             962M  179M  734M  20% /
/dev/md/2             9.2G  2.1G  6.7G  24% /usr
/dev/md/3              13G  708M   12G   6% /var
I've also lost some data due to my own stupidity with RAID. OTOH, I've
saved at least 5 times that amount of data from disk breaks with RAID.
> SOURCE DRIVE!)
I too can tell you that :). That's the way I erased one array - I synced
the empty disk over a fuller one.
Freaking slow, if RAID-1 takes many, many hours. That 2-terabyte array
took some hours and it's RAID-5, so the computer had to calculate all
the data. RAID-1 is "only" reading and writing and it's much faster.
In summary, he did it wrong ;).
> Backup onto *what*?
Ie. on external HD?
Surf man, surf.
http://www.ebuyer.com/product/143877
Smaller ones are cheaper:
http://www.ebuyer.com/product/128601
Plug it in, sync it (ie. with rsync oslt) and plug it out. Or buy 2 of
them, schedule a sync for every night and manually change the cable to
another drive every day (this is because offline backups are freaking
good idea).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 1 Sep 2008 12:41:49
Message: <48bc1b4d@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:48bc0807$1@news.povray.org...
Yup. My 'server' has four 160 GB sata drives in a RAID 5 config. Since it's
also my first stage backup location, I wanted redundancy. Just wish I'd
bought larger drives.
Date: 1 Sep 2008 12:43:40
Message: <48bc1bbc@news.povray.org>
news:48bc06f6$1@news.povray.org...
>> Note you can also make "my documents" and "desktop" (and a bunch of other
>> system-defined folders) point to anywhere you want, including other
>> drives.
It is true. I can't remember offhand how to do it, but it's very possible
since Win Xp (I think).
Date: 1 Sep 2008 12:59:20
Message: <48bc1f68@news.povray.org>
"Gail" <gail (at) sql in the wild (dot) co [dot] za> wrote in message
news:48bc1bbc@news.povray.org...
>>> other drives.
http://support.microsoft.com/kb/310147 (for win xp)
Date: 1 Sep 2008 14:57:10
Message: <48bc3b06@news.povray.org>
>>>> other drives.
>> possible since Win Xp (I think).
Well who'd have thought it. There's actually a UI for that...
Date: 1 Sep 2008 15:03:23
Message: <48bc3c7b$1@news.povray.org>
> Yes.
> These are RAID-1:
> And so are these:
Is that software RAID or hardware RAID?
My dad went with a hardware RAID solution, and it was utterly useless.
You had to resilver it every few hours because it kept breaking.
>> and wait many, many hours for that to complete. And then it would work
Ever tried to perform a low-level format on a HD? No matter what size it
is, it always takes an extremely long time. (The bigger the drive, the
faster it is, but the power to weight ratio seems fairly constant, so it
always takes a long time.) Formatting a huge drive with, say, FAT or
NTFS only takes a few minutes, but a low-level format takes an hour or more.
Resilvering the mirror was similar. It's mirrored at the hardware level,
so the disks must be block-by-block identical.
>> Backup onto *what*?
> Ie. on external HD?
Yeah, I guess... Doesn't seem like you're gaining a huge amount, but I
guess it's better than nothing.
>> enough to hold that other than another HD. (Or an LTO tape...)
> Surf man, surf.
...in other words, a HD. Like what I said. :-P
Date: 1 Sep 2008 15:04:28
Message: <48bc3cbc$1@news.povray.org>
> it's also my first stage backup location, I wanted redundancy. Just wish
> I'd bought larger drives.
Heh. And I thought *I* was crazy for owning just _one_ 160 GB drive in a
home PC...
What on earth do you use it for?
(I filled mine saving large uncompressed videos rendered with POV-Ray.)
