POV-Ray : Newsgroups : povray.off-topic : Something file systems need Server Time
16 May 2026 14:00:18 EDT (-0400)
  Something file systems need (Message 11 to 16 of 16)
Subject: Re: Something file systems need
Date: 25 Aug 2008 17:35:19
Message: <48b32597@news.povray.org>
Jim Henderson wrote:
> Well, arguably, there is - you put it in /tmp - most programs do that.
> Then you just exclude the directory from your backups.
Well, yes, but programs don't do that. KDE doesn't put the fingernails
there. Firefox doesn't put the cache files there. Thunderbird doesn't
put the index files there. VI doesn't put .swp files there. Etc.
Basically, anyone who doesn't want to have to pick an arbitrary name and
then somehow relate it back to the file it's related to isn't going to
put it in /tmp/.  And /tmp really isn't where you want to store all that
stuff anyway, or you'll wind up filling up whatever partition /tmp is
on, which is usually smaller than the partition your home directory is on.
> Demonstration I saw showed it pegging the CPU at 100% for nearly 40
> minutes because the rights were stamped on each object.  Come to think,
> it wasn't the filesystem - it had to do with assigning rights in AD
> itself, not to the filesystem.  It's been a few years.
I'm not saying you didn't see it. Only that I never did. :-)  They
*have* changed how ACLs are stored on files between 2000 and XP (IIRC).
Date: 25 Aug 2008 18:03:34
Message: <48b32c36$1@news.povray.org>
True.  But that's also what environment variables TMP and TEMP are for as
well.  But you're right that FF doesn't put its cache files there;
there's a reason I flush my cache when existing FF (pain in the behind to
sync the directory with a zillion cache files).
> on.
There again, that's what the environment vars are for.
I'm talking on server - ACLs in AD, not the filesystem.  I could probably
reproduce it if it were worth my time. ;-)
Jim
Date: 25 Aug 2008 18:58:24
Message: <48b33910$1@news.povray.org>
I'm not sure what you mean. You'd change the environment variables for
each program?  That doesn't sound like a good idea.  And I expect there
are some programs that use $TMP that expect certain semantics to go with
it (like it gets cleaned up after a reboot) or some such, too.
Sure, I understand.
Date: 25 Aug 2008 19:50:37
Message: <48b3454d$1@news.povray.org>
No, that you'd have a path which was storage for temp files, system-
wide.  In *nix, ISTR there's a call to "create a temporary file", no need
to track it by name because all the program needs is the file handle.
>> probably reproduce it if it were worth my time. ;-)
> Sure, I understand.
:-)  It was a great deal of fun to watch.
Jim
Date: 25 Aug 2008 20:25:48
Message: <48b34d8c$1@news.povray.org>
> wide.
Um, right. Same with Windows.
Um, no. If you want to close the file and reopen it later, because it's,
say, a cache file, then you need to know the name.  How come people
invariably think a "temp file" means you never close it, reopen it, or
pass it to another program?  In any case, I'm not talking about temp
files. I'm talking about cache files.  And since programs *don't* do
this, a discussion of how it might be able to work without changing the
file system doesn't help anyway.
Date: 26 Aug 2008 12:05:22
Message: <48b429c2$1@news.povray.org>
>> wide.
Yes.
>> In *nix, ISTR there's a call to "create a temporary file", no need to
It's a question of programming practice.  Kinda like passing laws that
duplicate other laws because the older laws aren't enforced.
Jim
