POV-Ray : Newsgroups : povray.off-topic : Colour consoles Server Time
1 Mar 2026 14:34:43 EST (-0500)
  Colour consoles (Message 1 to 10 of 33)
Subject: Colour consoles
Date: 20 Aug 2008 09:08:38
Message: <48ac1756$1@news.povray.org>
You *know* something's wrong when you find yourself envying people who
use Unix because it can emulate an obsolete VT100... o_O
Basically, I have a perfectly working console application, but I wish I
could just make certain parts of its output come out in a different
colour. On Unix, this would be a fairly trivial matter of writing some
escape codes to stdout and you're done. On Windoze... well that doesn't
work.
I wonder... Is there some function call in the Win32 API that can
actually change the colour of the text in a console window? Or is that
impossible? Does anybody here know the Win32 API well enough to know the
answer?
(Certainly the "color" command changes the colours of the console window
- but it changes the colour of *everything*. I don't know if you can
change just some of the text, rather than all of it...)
http://blog.orphi.me.uk/
Subject: Re: Colour consoles
Date: 20 Aug 2008 10:03:09
Message: <op.uf6uniy17bxctx@e6600>
> work.
NT-based console windows do not support colour escape codes. Only 16-bit
applications (running under NTVDM) can use colour escapes.
http://msdn.microsoft.com/en-us/library/ms682088.aspx
FE
Date: 20 Aug 2008 10:12:10
Message: <48ac263a$1@news.povray.org>
>> doesn't work.
Indeed. So that isn't much help.
Bugger. I don't have bindings for those particular functions. :-(
I wonder if I could write some...?
Date: 20 Aug 2008 10:54:03
Message: <48ac300b$1@news.povray.org>
Oh. My. God.
I literally can't believe this... I just wrote and compiled a C program
that calls the Win32 API directly, AND IT FRIGGIN WORKED!! 0_0
*dies*
I would never have believed it was possible... I was sure it would
blue-screen the machine or crash spectacularly, but no, it actually
worked properly. (AND, best of all, it IS possible to change the colour
of just some characters in a console window. I wasn't sure it could be
done.)
I was a little shocked to discover that I already have the necessary C
header files. And, obviously, it took a litle while to figure out how to
make my Haskell compiler compile raw C files instead of Haskell programs.
The hardest part was figuring out what "warning: function foo() defined
implicitly" means. Apparently it means you spelt the function's name
wrong, so the compiler couldn't find it in the header file. This also
causes the linker to make rude comments.
But once you get over all of these things... my God, I made a direct OS
call and *didn't* crash the OS. Astonishing!
I think I need to go sit down...
Date: 20 Aug 2008 11:01:39
Message: <48ac31d3$1@news.povray.org>
Invisible wrote:
> Oh. My. God.
> *dies*
..and it only took you twelve minutes!
*Falls_over_in_amazement*
John
"Eppur si muove" - Galileo Galilei
Date: 20 Aug 2008 11:20:18
Message: <48ac3632@news.povray.org>
Really? Gee, it seemed like much longer than that to me...
The hard part, of course, is writing some Haskell bindings. ;-) In
particular, I cannot for the life of me figure out how to get at
symbolic constant names. :-(
Date: 20 Aug 2008 11:38:38
Message: <48ac3a7e$1@news.povray.org>
On Wed, 20 Aug 2008 16:20:17 +0100, Invisible wrote:
> In
In C?  Look at #define
Jim
Date: 20 Aug 2008 11:40:26
Message: <op.uf6y5oqx7bxctx@e6600>
If you are looking for 'FOREGROUND_BLUE' and the like, they are defined in
'WinCon.h'. There you will also find the structure definitions relevant to
the console subsystem.
FE
Date: 20 Aug 2008 11:42:13
Message: <48ac3b55$1@news.povray.org>
>> In
I meant how to get that stuff into Haskell.
It seems Haskell provides a magical command which somehow lets you call
a C function as if it's a Haskell function, assuming you can find a
header file that contains the C function you're after. (I literally have
*no idea* how the linker finds the actual code...) However, there seems
to be no way to import constants. In fact, every Haskell binding I've
looked at has these hard-coded in the Haskell source code rather than
imported, so I've just waded through a few KB of header files tracking
down all the #defines and their literal values.
And you know what?
I just ported my program to Haskell, AND IT STILL WORKS CORRECTLY! 0_0
This is an unprecidented level of success. It seems I can actually call
any C function I have a header file for. Wow.
Date: 20 Aug 2008 11:43:05
Message: <48ac3b89$1@news.povray.org>
So this doesn't work?
http://www.windowsnetworking.com/kbase/WindowsTips/Windows2000/UserTips/Miscellaneous/CommandInterpreterAnsiSupport.html
