POV-Ray : Newsgroups : povray.off-topic : Random C craziness Server Time
13 May 2026 23:29:12 EDT (-0400)
  Random C craziness (Message 25 to 34 of 34)
Subject: Re: Random C craziness
Date: 26 Jul 2008 17:30:00
Message: <web.488b96f97f33a1c3de7267810@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> The idea here is that we jump to one label, then jump to another, then
> jump to another, never returning to the "caller".
> If we implement this using C functions that never return, an unbounded
> amount of stack gets eaten.
> Hence, they arranged for each function to *return* the function it would
> like to jump to next, rather than actually jumping to it, and the loop I
> posted is apparently the magic incantation that implements the jumping.
Yes, indeed.
http://en.wikipedia.org/wiki/Tail_recursion#Implementation_methods
I take it that you were looking at the C output of GHC, right?  Haskell relies
on tail-recursion as much as any other functional language, as Scheme.  The
method it is implemented underneath is as a trampoline.
Date: 28 Jul 2008 05:13:26
Message: <488d8db6$1@news.povray.org>
John VanSickle wrote:
> There was an entry over at the Daily WTF in which someone posted code,
> written by another person, containing this:
> #define TRUE 0
> #define FALSE 1
> I swear that I am not making this up.
I remember it well...
http://blog.orphi.me.uk/
Date: 28 Jul 2008 16:21:44
Message: <488E2A94.3030104@hotmail.com>
On 26-Jul-08 21:39, John VanSickle wrote:
> Chris Cason wrote:
>> In the real world, no programmer would ever do something
>> that mean with a macro called TRUE. Right? :-)
> #define TRUE 0
> #define FALSE 1
Probably Unix convention?
http://en.wikipedia.org/wiki/True_(Unix)
http://en.wikipedia.org/wiki/False_(Unix)
Date: 28 Jul 2008 16:35:08
Message: <488e2d7c@news.povray.org>
>> #define TRUE 0
>> #define FALSE 1
Ah yes - return code 0 = OK, any other code = failure.
What have we learned here? That using integers to represent Booleans is
a Very Bad Thing. :-P
Date: 28 Jul 2008 16:56:21
Message: <488e3274@news.povray.org>
> >> #define TRUE 0
> >> #define FALSE 1
  C actually distinguishes between TRUE/FALSE and EXIT_SUCESS/EXIT_FAILURE.
They shouldn't be confused nor mixed.
Date: 29 Jul 2008 11:20:42
Message: <488f354a$1@news.povray.org>
Warp wrote:
>   Because "while(1)" is a common idiom, and avoids the ugly goto.
Either that or for(;;) { ... }
Date: 29 Jul 2008 11:27:01
Message: <488f36c5@news.povray.org>
...and to think people complain when a Haskell programmer writes
   fix ((1:) . scanl (+) 1)
or something... :-P
Date: 29 Jul 2008 15:39:00
Message: <488f71d4$1@news.povray.org>
Warp wrote:
>   (Another less fancy way would be to return a null pointer from the
> function, in which case the program will end with a segmentation fault.)
Well, maybe if you're lucky. :-) Otherwise, it just goes off happily
executing whatever is at memory address zero (or whatever NULL maps to).
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 29 Jul 2008 17:05:51
Message: <488f862f@news.povray.org>
  I'm pretty sure POSIX or some other type of standard states that jumping
to the null pointer will always cause a segmentation fault.
Date: 29 Jul 2008 17:21:04
Message: <488f89c0$1@news.povray.org>
But not the C standard. Try it on MS-DOS, Win 3.1, AmigaDOS, a credit
card terminal, a cell phone, etc. :-)  Basically, you're saying you
can't have a POSIX-compliant system without memory mapping, methinks.
But C is used in particular because of its primitiveness and lack of
reliance on a particular complex bit of hardware.
"The operating system is there to provide the facilities the language
designer left out."
