On Mon, 21 Jul 2008 16:19:47 +0100, Invisible wrote:
> Jim Henderson wrote:
>> You should take some photos. ;-)
> OMG, you're right! Damn, and I don't have a camera...
There's always tomorrow. :-)
Jim
> What good are photos? I say videos! He could be the next Youtube star.
> Crushing CD's with maniacal laughter in the background. It would be
> great!
Oooh, I like the way you're thinking here.....
Jim
Quote:
> Weeee... I just found a cake of those square mini-CDs, preprinted with
> some obsolete software of ours. I just shredded the whole lot. These
> preprinted ones seem much more "chunchy" than the CD-Rs I'm mostly
> destroying. And their small size appears to give them superior sonic
> qualities. The sound they produce is truly horriffic! :-D
> http://blog.orphi.me.uk/
> http://www.zazzle.com/MathematicalOrchid*
You ARE recording it and putting in on youtube, I will assume?
Heh. Why? It's almost certainly already there... ;-)
Invisible wrote:
> Wooooooyeah!!
> My shiny new CD shredder has arrived. This is NOT your average little
> home shredder. This thing is BIG, it's HEAVY, and it makes an
> indescribably delightful sound as it CRUNCHES through helpless little
> CDs... Muhuhuhuhu! >:-D
> (Seriously - people have been giving me weird looks all afternoon.
> Possibly due to the transcendental look of glee on my face!)
> Guys, you seriously gotta try this thing...
The one we used in the Air Force merely ground everything off of one
side of the CD, down through the data layer. The shaved off stuff was
reduced to a fine grit in order to preclude reconstruction.
John
Ooo... powdered data. Shiny...
I dare say the Air Force has much more interesting stuff to dispose of
than I do. ;-) I'm a litle surprised to hear that they use anything as
modern as a CD though...
Actually the desktop systems they buy for administration purposes are
generally the same stuff you can buy at any office supply store, and the
other administrative IT is generally at the same level.
The general rule is that if the military goes commercial off-the-shelf
(COTS) for something, it gets fairly recent technology at a fairly
decent price.
For some things, no commercial vendor makes it. For these items, the
military has to contract out the manufacturing process, and generally
the design as well. Proprietary designs abound. Quantities are limited
(only items that are ubiquitous and in heavy use get more than a few
thousand made), so margins are high. The design process takes so long
that the equipment, when finally fielded, can be a decade behind the
commercial world.
When I first entered the service (in 1984), a certain piece of
cryptographic equipment, which used vacuum tubes to generate its timing
signals, and magnetic core logic to generate the right ones and zeros,
was then nearing the end of its service life (I saw it in use until
1988). It took up an entire equipment rack (six feet tall, nineteen
inches wide). All it did was encrypt/decrypt digital data at a rate
measurable in kilohertz at the very fastest, but in the 1950's when it
first saw service, it was considered more than adequate.
John
Mmm, OK.
> commercial world.
Weeee... and *this* is why I'm not sure I want to work on military
crypto devices. :-}
> crypto devices. :-}
About a decade later, the military developed a solid-state (discrete
transistors packaged into modules) piece of equipment which occupied
only half on an equipment rack, and it ran in the kilohertz range.
Later, stuff that runs at T-1 speeds, and occupies one-tenth of the
rack, came into service (and remains in service).
The half-rack systems were finally dismantled in the early nineties,
after seeing nearly three decades of service, but the remaining stuff,
when it is adequate to the requirements at hand, is still in use (and,
BTW, is very reliable).
John
The best sound I heard was some sort of flourescent light bulb shredder
hooked to basically a shop-vac. You can imagine the sound of sucking
destruction that entailed when nom-nom-nomming a 6-foot long light bulb.
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
