POV-Ray : Newsgroups : povray.off-topic : Formatting speeds redux Server Time
7 Apr 2026 19:27:45 EDT (-0400)
  Formatting speeds redux (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Formatting speeds redux
Date: 6 Jul 2008 15:21:51
Message: <48711b4f$1@news.povray.org>
Am Sun, 06 Jul 2008 19:03:47 +0100 schrieb Orchid XP v8:
> Warp wrote:
>>   I use ReiserFS for all my linux partitions.
> I've not used it, but I've heard good things about it.
>> Besides being journaled,
>> it's more compact than many other FSs
> I doubt I'd notice the difference. Heck, I don't even notice the
> difference between ext2 and ext3...
> What I would be curios to know is this. The traditional Unix file
> permissions system allows you to assign a set of permissions to the
> "owner", another set to the "group", and a third set to "everybody
> else". Is there any kind of extension that allows you to assign
> arbitrary permissions to individual users and/or groups beyond what the
> traditional system allows? (I would anticipate the Big Problem with
> attempting to do this would be that it breaks everything that expects
> the old behaviour!)
It is called "Access Control Lists" and part of POSIX. Manpage is called
acl(5).
Date: 6 Jul 2008 15:24:37
Message: <48711bf5$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> I didn't even try the other Linux file systems.
>   I use ReiserFS for all my linux partitions. Besides being journaled,
> it's more compact than many other FSs because it packs file tails into
> single sectors. (In other words, if the data in the last sector of two
> files would fit in a single sector, ReiserFS puts then into the same
> sector.)
That's handy. (The difference between ext2 and ext3 is that ext3 is
journaled. You can even switch back and forth between the two of them by
essentially deleting or creating the journal file.)
>   One disadvantage of ReiserFS is that to run reiserfsck the partition
> must be read-only. This means that if you need to run it on your main
> partition you'll have to boot to single-user mode and remount the
> partition to read-only before you can run reiserfsck.
I'm pretty sure that's true of ext3, also. Indeed, I'm not sure I know
any file system you can check for consistency while it's in use. (Not if
you want to actually correct flaws, at least.)
Does it work to set /forcefsck and reboot, or do you actually have to be
sitting there to do it?
>   Another minor (in my case very minor) quirk is that deleting very
> large files can take some time (in the order of several seconds),
> unlike with some other FSs where file deletion happens instantaneously.
Yeah. I've had files large enough that it takes literally minutes to
delete on ext3, so that's no surprise either. Ext3 actually stores a
list of blocks the file occupies, even if they're contiguous, so
deleting a 500-gig file is going to take time just looking up all the
blocks it's on.
I just used ext3 because it was the default and I had to get stuff
working before I knew as much as I do now. It turns out it's one of the
more poorly-performing file systems available.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 6 Jul 2008 15:26:08
Message: <48711c50$1@news.povray.org>
Warp wrote:
>   You might notice a difference in disk usage if you have enormous
> amounts of small files. (In a non-compacting FS every file takes a
> multiple of 4 kB, rounded up. With ReiserFS they can take less. For
> example if you have 1000 files, each one 128 bytes in length, instead
> of taking 4 MB of disk space they only take 128 kB.)
Interestingly enough, in NTFS, if all the data fits in the same sector
as the inode[1], it goes into the same sector.
>   There might be some file systems which support additional permissions,
> but I don't remember right now.
There are, and yes, they aren't especially well supported, especially by
things like rsync, svn, backup programs, etc.
[1] For the NTFS definition of inode.
Date: 6 Jul 2008 15:47:40
Message: <4871215c$1@news.povray.org>
Just some more timings, for S&G:
362000 files, 77G used of 215G, ext3 IDE - 7 minutes 20 seconds.
428000 files, 6.5G used of 82G - ext3 IDE - 2:40
100,000 files, 24G used, NTFS IDE - 2:20
90,000 files, 160G used, NTFS IDE - 1:30.
Really all over the board. It looks like the biggest factor for ext3 is
the capacity of the drive, and I *suspect* the biggest complexity in
NTFS is the complexity of the directory structure. (The 3rd one has a
much more complex directory structure right now than the fourth one).
Date: 6 Jul 2008 16:20:12
Message: <487128fc@news.povray.org>
Darren New wrote:
> I'd like to find a file system I can reliably use from OSX, Windows, and
> Linux, myself. OSX can almost handle NTFS (as in, it seems to be able to
> read/write NTFS as long as you don't hit the parts that aren't
> supportable with the UNIX file system semantics), but as far as I can
> tell, NTFS still isn't safely writable from Linux? That's what google is
> telling me, at least.
Check out NTFS-3G:
http://www.ntfs-3g.org/
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 6 Jul 2008 16:47:27
Message: <48712f5f$1@news.povray.org>
...which the result that if you have many hundreds of tiny files in a
single directory... the directory structure becomes rather large and
slow to traverse. ;-) (Still better than wasting half your harddrive
though!)
I thought that would be problematic. ;-) But it at least exists though?
http://blog.orphi.me.uk/
Date: 6 Jul 2008 20:21:48
Message: <4871619c$1@news.povray.org>
> ....which the result that if you have many hundreds of tiny files in a
> though!)
Are you joking? Or are you serious? Because from what I understand, the
directory structures have nothing in them but names and pointers into
the master file table (which stores the file records that are the
equivalent of inodes). In other words, the directory hasn't anything to
do with the files, and doesn't get bigger just because you're storing
small files.
I could be wrong about that, tho, if you actually have information that
says otherwise.
On some file systems, yes.
Date: 6 Jul 2008 20:23:07
Message: <487161eb$1@news.povray.org>
Eero Ahonen wrote:
> Check out NTFS-3G:
Very cool! Thank you!
Date: 7 Jul 2008 14:42:17
Message: <48726389$1@news.povray.org>
>>> sector as the inode[1], it goes into the same sector.
>> though!)
> small files.
> says otherwise.
The information I heard is that "small" files are stored in-line inside
the directory structure to prevent additional seeks (and wasted
half-blocks). The source I got that from wasn't highly technical, so
this might be a simplification.
Date: 7 Jul 2008 14:59:57
Message: <487267ad$1@news.povray.org>
The "directory structure" includes more than the directories.
There's a "master file table", which holds all the metadata for each
file, such as its names, what directories it's in, how big it is, the
pointer to the ACL, what clusters it's stored on, when it was created,
where it's backed up, what streams it has and where, the encryption
information, and so on. The MFT is basically an array of file objects,
and each file object is an array of file properties. One of those file
properties *can* be the data of the file.
Then there are directories, which store the names and pointers into the
master file table as B-trees.
If you're familiar with old UNIX style file systems, the "master file
table" holds the equivalent of the i-nodes, and the directories hold the
equivalent of the directories.
Having lots of files in a directory leaves it the same size regardless
of how much data is in the files, because the directories just refer to
offsets in the master file table.
(Now you understand the three passes of chkdsk. :-)
The reason the formatting is fast is the master file table is just a
file, as is the free space map and ACL lists (and boot sector, for that
matter), and they're all dynamically allocated as needed just like any
other file, so it's a pretty constant amount of data written during a
format.
Ext2 pre-allocates all the i-nodes, and hence must actually clear them
(i.e., mark them as not in use). And (presumedly) for speed, it spreads
these i-nodes out across the disk, so there are thousands of seeks to
format a 750G disk.
