POV-Ray : Newsgroups : povray.off-topic : Fun with cryptography Server Time
17 May 2026 01:37:38 EDT (-0400)
  Fun with cryptography (Message 5 to 14 of 74)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Fun with cryptography
Date: 3 Jul 2008 02:28:10
Message: <486c717a@news.povray.org>
>> The document claims this is because "IPSec is too complicated to be
>> secure", and that "TSL is mature and battle-tested".
> I like how they make this assertion, then later on say "you might need
> the load balancing that IPsec does, but you can get that with OpenVPN by
> running this other complicated program on a spare machine." It sounds
> like a lot of the complication is stuff that OpenVPN basically leaves out.
Well, is that a protocol feature or a software feature?
> Plus, I'm not really sure how they're running TLS over UDP, given that
> TLS is stream-oriented and assumes reliable delivery. It's also not real
> obvious from their descriptions that it's possible to run a UDP protocol
> over OpenVPN.
Hmm, that's a good point.
>> Also amusing is the statement "Blowfish is a very strong algorithm
>> with no known weaknesses. Its 128-bit key provides us with a large
>> enough key space to make brute force key attacks impossible in
>> polynomial time." Erm... like... WTF?
> Of course, it hasn't been tested as furiously as AES, either.
I was more amused by the statement that key size has any relationship to
complexity class.
Blowfish is far more popular than, say, TEA or SQUARE or any number of
other ciphers from the zoo of less-known algorithms out there. I note
however that Blowfish has been "replaced" by Twofish which is meant to
be stronger. (And AES finalist, I believe.)
A lot of people are apparently jumpy about the whole XSL attack thing on
AES.
http://blog.orphi.me.uk/
Date: 3 Jul 2008 12:35:24
Message: <486cffcc$1@news.povray.org>
>> by running this other complicated program on a spare machine." It
>> sounds like a lot of the complication is stuff that OpenVPN basically
>> leaves out.
I'm saying that they mock IPsec for solving problems *they* don't have,
because it was "designed by a committee".  I suspect the people on the
"committee" actually *did* have those problems, so incorporated
solutions to them into the standard, instead of making everyone solve it
themselves with ad hoc solutions consisting of interacting layers which
could easily introduce a security hole if you don't know what you're doing.
> complexity class.
Yes, I understood the WTF. :-) Of course, if it's running over TLS, you
can put whatever cipher both sides agree on in there.
And actually, key size *can* have a relationship to complexity class,
perhaps. If you can pre-compute something that lets you look up in
polynomial time the key that someone is using, except that the key is
too long to store the precomputed somethings for every key, I can see
where that can happen. (Technically, the same complexity class, but in
practice, you can break something in polynomial time if you discount the
precomputation, perhaps.)
But yeah, the whole discussion was full of WTFs like that. Plus, they
say basically "IPSec is too complicated to deploy, OpenVPN does the same
thing only its easy to deploy", without giving any evidence at all of
either. Most of the paper is a description of SSL, and I'm pretty sure
there aren't fundamental security problems with IPSec that aren't in SSL.
(And apparently the authors don't know that actual difference between
SSL and TLS.  Hint: OpenVPN seems to use SSL.)
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 3 Jul 2008 13:57:54
Message: <486d1322$1@news.povray.org>
Hmm. I just wanted to know whether this piece of software was worth using.
I think I have my answer now...
Date: 3 Jul 2008 15:56:14
Message: <486d2ede$1@news.povray.org>
Oh. I imagine if it solves the problem you have, it's probably worth
using, assuming you can get it working and it's sufficiently widespread
you trust it.
That the people writing the *paper* didn't write it in a convincing way
doesn't really say much about the *code*.
Date: 3 Jul 2008 16:02:03
Message: <486D3071.9050802@hotmail.com>
Invisible wrote:
> Weeeee....
> http://eprint.iacr.org/2008/166.pdf
> There's nothing like cryptanalysis to make you paranoid! ;-)
It lead to a discussion in parliament here and a bad time for one of our
ministers. Introduction of the country-wide OV chipcard (OV is the
abbreviation for public transport) is postponed now.
At the last election in some cities voting was done again by paper and
red pencil because somebody showed that you could listen to what people
voted by putting a radio receiver close to it and a few more
insecurities of the digital voting machines.
What these examples have in common is that they were badly designed and
they relied on people not knowing the details as an important security
measure. The latter is of course an absolute sin in cryptography, but
apparently not (yet) when designing voting equipment or identification
cards.
Date: 3 Jul 2008 17:06:48
Message: <486d3f68$1@news.povray.org>
> cards.
Security through obscurity = hmm, it doesn't work. ;-)
Date: 3 Jul 2008 17:08:29
Message: <486d3fcd@news.povray.org>
True. But given that it seems to be a one man project... Well I'm sure
it *works*, but that's not the same as being secure. [Not that any sane
person is going to bother trying to hack my systems unless it's
sufficiently easy.]
Date: 3 Jul 2008 17:29:35
Message: <486d44bf$1@news.povray.org>
I see. I hadn't followed it up.  No, if the author of the code is the
author of the paper, I'd definitely go with IPSEC. :-)
Date: 4 Jul 2008 04:08:07
Message: <486dda67$1@news.povray.org>
It appears the report was written by somebody other than the author. But
then, comments like "OpenVPN seems to be using SSL" make me suspicious.
As does the fact that SSL and TLS both run over TCP, yet OpenVPN seems
to be using UPD. That looks like a big enough deviation from the
standard that I'm left wondering how many design decisions have been
made with potential security implications.
It's not like OpenVPN just calls the OpenSSH crypto library to do its
bidding; it looks like a complete new implementation.
Date: 4 Jul 2008 05:22:11
Message: <486debc3$1@news.povray.org>
That sentence made me laugh.  Of course, it's 3 AM here (almost 3:30), so
I'm a little sleepy, but can I just say THANK YOU?  I *really* needed a
laugh.
Tough night, and this really helped.
Thank you.
Jim
