Tim Nikias wrote:
> Heh, that reminds me... Some guy actually wrote code like this:
Somehow those variables remind me of what I've decided I'll do at work
some day, when I'll have a place where it fits:
if (!successful) {
try_harder();
> Regards,
> Tim
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
Warp <war### [at] tag povray org> wrote:
> Gail Shaw <initialsurname@sentech sa dot com> wrote:
> > Whereas I find the first far too spread out to be able to read easily
> Compactness does not imply readability. On the contrary.
> - Warp
IBELIEV
ETHATIN
THISCAS
EIAMCOM
PELLEDT
OAGREEW
ITHYOU!
BEST
REGA
RDSM
IKEC
I'd say that there is only a fairly weak correlation (positive or
negative) between compactness and readability.
x = 2*y*y*y - 3*a*b
is much more readable than
t1 = y*y
t2 = y*t1
t3 = 2*t2
t4 = a*b
t5 = 3*t4
t6 = t3-t5
despite being much more compact. Counter-examples in the opposite
direction are not hard to find either.
http://blog.orphi.me.uk/
> t1 = y*y
> t2 = y*t1
> t3 = 2*t2
> t4 = a*b
> t5 = 3*t4
> t6 = t3-t5
Hey ... that looks familiar.
... I think someone here used to write code exactly like that! 0.o
Stephen wrote:
> On Fri, 27 Jun 2008 01:26:58 +0300, Eero Ahonen
> <aer### [at] removethis zbxt net invalid> wrote:
>> Warp wrote:
>>> I disagree.
>> Good, 'cause you're wrong.
> I can't help but agree with you.
I disagree.
Everyone's wrong!
> if (!successful) {
> try_harder();
>> Regards,
>> Tim
try
AcheiveYourGoals();
catch(DidntSucceedException ex)
TryAgain();
:p
stbenge wrote:
> If I worked for an organization, I would definitely change my style. Of
> course if I were programming for a living, I would probably go to school
> where they would teach me how to write code that people could decipher :)
Write code that others can decipher? Why would you do a thing like that? ;)
Everyone knows that if you code for a living, you code for job
security... you wouldn't want the janitor to take your job, would you? :D
(Of course, I'm joking .... it doesn't work well in a team environment
to code for job security)
Halbert wrote:
> How about Microsoft's engineers starting the whole Hungarian Notation
> convention with Windows programing. (like lpstrFilePath or iRecursion, etc.)
> There seems to be no set standard to it. While the intention is good, a
> beginner may have wonder why some variables have names like lpszDemung or
> lpfnCBack.
There seems to be two standards, one which describes type: lpszString
and one that defines function (sort of): instead of iOptions, it's fOptions.
You don't know how many times I've looked at a function signature, and
seen fSomething on something that should receive bits and wondered why
the hell they want a float, only to look a bit to the left and see that
it is indeed an integer.
Mike Raiford wrote:
> try
> AcheiveYourGoals();
> TryAgain();
try
AchieveYourGoals();
catch (Failure e)
CallAirStrike();
// With appologies for Murphy...
Mike Raiford wrote:
> try
> AcheiveYourGoals();
> TryAgain();
> :p
Would be great, too :). The thing about my code is that at work we have
this department-wide habit that if someone says "this doesn't work" or
"I can't do this" oslt, the first answer is usually "try harder".
Eero "Aero" Ahonen
http://www.zbxt.net
> x = 2*y*y*y - 3*a*b
The context was really a multilined program source code, not a
mathematical formula, which your line really is.
Mathematical formulae can often be written compactly because they
a) aren't really program code, and b) there's an established syntax
to write it compactly.
Perhaps you forget, the very word "computer" means "device for
performing mathematical calculations". ;-)
Having programmed with Haskell for a while now, I would contest the
"programs aren't mathematics" assertion. Having played with mathematics
for even longer, I would contest the "established syntax" assertion too!
[Rather, there are several incompatible and variously ambiguous syntaxes
for writing any particular mathematical construct...]
Regardless, I would assert that how "readable" something is depends on
how well it maps to your underlying mental processes - which is rather
independant of the compactness or otherwise of the code. ;-)
It's certainly what the compiler transforms your code into - this is
what machines derived from the design of Turing expect. But it is not
necessarily how humans think. ;-)
"Eero Ahonen" <aer### [at] removethis zbxt net invalid> wrote in message
news:4864edce$1@news.povray.org...
> if (!successful) {
> try_harder();
My honours project at university had a line of code in it
while (!hellFrozenOver) {
Mike Raiford wrote:
>> Of course if I were programming for a living, I would probably go to
>> school where they would teach me how to write code that people could
>> decipher :)
Around here it is highly unlikely that a janitor would know how to
program a computer, let alone operate one. This isn't to say people
around here are stupid or anything. They are just generally
computer-illiterate.
A bit off-topic, but this reminds me of a guy I worked with at the
travel nurse agency. The man worked in the 'computer engineering'
section, along with the manager. His job, as far as I could tell, was to
keep the computers running smoothly, and to archive lists of available
or potentially available nurses. Now maybe I'm missing something here,
but do you really need your own server for that kind of work? Can't you
do those things with conventional computers and storage? Why did we even
need a server when there were only about zero or three people making
travel reservations at any given time? I wonder things these because the
'computer engineer' seemed very self-important, an active preserver of
personal job security. He even cast a contentious look one time when I
helped a lady with her computer's resolution! Odd situation at any rate.
Sam
...you realise that when hell freezes over, your program is going to
fail in an undefined way, right? (YHF bug?)
"Orchid XP v8" <voi### [at] dev null> wrote in message
news:48652fca$1@news.povray.org...
In the case of that piece of code, it would just not do anything on that
fateful day
The loop in question was the program's main activity loop (Distributed VR
system)
> Case in point:
> n=(i<12&&j>=i)?(sqrt(z)*y+j):(y+j*i);
> vs
> if( i < 12 && j >= i )
> n = sqrt(z) * y + j;
> else
> n = y + j * i;
I'd like to see the specification that gave rise to that snipped of code. ;)
Actually, it means "person whose job it is to do the arithmetic." Only
after they automated it did it refer to a machine. :-)
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
>> if (!successful) {
>> try_harder();
was that before or after Lordi won?
"andrel" <a_l### [at] hotmail com> wrote in message
news:486### [at] hotmail com...
Lordi?
Sorry, reference to something I am not familar.
LMAO!
Sweet...
Gail Shaw wrote:
> Lordi?
Most improbable Eurovision winners in history.
Orchid XP v8 wrote:
> Gail Shaw wrote:
>> Lordi?
Yes. The only Finnish band ever made it so far (=to the finals, that is)
with having even a slightest chance of winning.
Eero "Aero" Ahonen
http://www.zbxt.net
Halbert wrote:
> Why doesn't the rest of the world understand that?
Because I learned to program on a machine with 8k of memory. A byte
saved is a byte earned.
John
> Lordi?
Sorry Gail, that was sort of eurocentristic. Indeed the winners of the
Eurovisionsongcontest a few years back.
(http://www.youtube.com/watch?v=p6VzdtmrP6Y is the best I could find).
Finland was considered the country most unlikely to win the contest ever
before this act. Especially by the Finnish themselves. On some webpages
it was put down as an event even less likely than hell freezing over.
Some publications the day after apparently opened with 'it is official:
hell frozen over' or similar. IIRC Eero is from Finland.
Why Finland won: they couldn't so they send in a hardrock band because
that is not what the songcontest was about. The band was dressed like
monsters, again not exactly according to dress code. Very important
contribution was that the voting was not done anymore by a geriatric
jury with knowledge and taste but by SMS by mainly adolescents. And
within it's genre it was a good song of course.
On Fri, 27 Jun 2008 13:29:17 -0700, Darren New <dne### [at] san rr com>
You are right of course but should it have been computor not computer.
Regards
On Sat, 28 Jun 2008 10:43:44 +0200, andrel <a_l### [at] hotmail com>
>> Lordi?
Isn't Hell a town in one of the Nordic countries?
Regards
> > Lordi?
Ah. I'm also not a major music fan.
The code dates from well before that, 1998.
http://en.wikipedia.org/wiki/Hell%2C_Norway
Also:
http://en.wikipedia.org/wiki/Hell%2C_California
http://en.wikipedia.org/wiki/Hell%2C_Michigan
http://en.wikipedia.org/wiki/Hell%2C_Grand_Cayman
FE
You had a C compiler in a machine with 8k of memory? Which one was that?
On Sat, 28 Jun 2008 11:18:14 +0200, "Fredrik Eriksson"
Thanks, I couln't find it on Google maps.
Regards
PDP-11? I had a machine with a COBOL compiler that ran in 8K of
real-live core memory. And, like, it ran banks and stuff. :-)
An entire C or COBOL compiler which can run and compile with only
8 kilobytes of memory puts those 4k intros into shame, IMO. :P
What's a 4k intro?
(Of course, it had lots of passes. And a 50-line program took maybe 10
or 15 minutes to compile. But there was no VM either, for what that's
worth to the discussion. :-)
> What's a 4k intro?
http://en.wikipedia.org/wiki/Demo_(computer_programming)#Intros
It's rather incredible what you can squeeze into that amount of bytes.
Yarr, back then, coders were *real* coders! Haharrr!
Mmm, can't see me entering any Haskell programs in a 4KB demo
competition... The Haskell runtime engine alone is ~500KB, and that's
before you add any *functionallity*. o_O
Indeed. It used to be 32K was plenty for some rather sophisticated video
games. :-) Lots of the old arcade games had less than that, too.
For some reason I'm reminded of the demo of Uridium 2 I got to play on
my dad's Amiga.
You insert the disk into the drive, you hear a click, and instantly the
screen lights up in neon colours. First a set of blue bars appear, then
a set of thinner, transparent green bars scroll down over the top of
these, and then transparent red bars scroll up over both. The end result
is a myriad of colours. And all the time this is happening, electronic
music is playing, and the computer is still loading the *real* game from
disk.
Basically, the entire audio-visual candy-fest fits into the boot sector.
And well it might; the technicolour rainbow is just a trick of the
Amiga's copper ship, which modifies the image palette on each raster
scanline, yielding the effect of millions of colours at once, from a
bitmap that only actually handles a handful. (Notice that all the colour
bars are *horisontal*. This is not a coincidence.)
Ah, great days...
Damned TF2 takes 20 minutes to load up! o_O
I didn't say that I programmed in C on this machine, only that I learned
to program. The habit of being very stingy with memory use carries on.
John
Nowadays when I code I sometimes stumble into situations like:
"Hmm... This data will take over 100 megabytes of memory... Should
I worry? ... Nah. That's nothing."
> code. ;)
Umm. Write a contrived example showing that compact isn't always readable?
Mike Raiford wrote:
>> code. ;)
No that is more an assignment. A specification is where you specify what
the possible inputs are and what relations exist between input and
output...umm, ok, I know you were just kidding ;)
