POV-Ray : Newsgroups : povray.off-topic : Oh what joy! Server Time
16 May 2026 14:44:27 EDT (-0400)
  Oh what joy! (Message 1 to 10 of 91)
Subject: Oh what joy!
Date: 26 Jun 2008 11:45:39
Message: <4863b9a3@news.povray.org>
"Hey Andrew, those harddrives that are left over there, can you arrange
for somebody to come and take them away? I mean, we can't just leave
them there. Even if they're been erased, you can still get the data off
them if you want to."
Uh... like, WTF?
I mean, sure, if you take the drive apart and crawl over it with a
microscope, you can recover data. But who the **** is going to bother?
It's not like you could recover any particularly valuable data.
(Personally, I think my boss honestly believes that you can take an
erased harddrive and just plug it in and type "undelete" and all the
data will come back. It doesn't work like that...)
http://blog.orphi.me.uk/
Subject: Re: Oh what joy!
Date: 26 Jun 2008 11:50:03
Message: <4863baab@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4863b9a3@news.povray.org...
Um, actually...
http://www.pcworld.com/article/id,108831-page,1/article.html
http://www.guard-privacy-and-online-security.com/how-clean-off-the-hard-driv
e.html
Your boss is right. It may not be as easy as 'undelete' but the data's there
and it doesn't take a microscope to find it, and it could be worth a lot of
money.
Date: 26 Jun 2008 12:02:15
Message: <4863bd87@news.povray.org>
Gail Shaw wrote:
> Um, actually...
A study found that some people selling drives hadn't even bothered to
erase them at all. Pressing the "delete" button doesn't erase the file.
This isn't news.
> e.html
This doesn't look terribly convincing to me.
> money.
Right. Well I'll tell you what, you show me an actual technique that
allows you to recover data from a harddrive after every individual block
has been written with zeros, without the use of a microscope. ;-)
Date: 26 Jun 2008 12:10:26
Message: <4863bf72@news.povray.org>
Depends how erased it is, of course. Your boss might not know that you
know how to erase a drive correctly. :)
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 26 Jun 2008 12:33:15
Message: <4863c4cb$1@news.povray.org>
> money.
It depends how you erased the drive. If you just formatted it, no, the
data's all still there. If you actually overwrote it, it takes special
electronics to retrieve it if you can at all.
If you're the DoD, and large numbers of people die when a foreign
government spends several millions of dollars to recover the data from
the disk, yes, 21 passes is probably good. That, or scrubbing the drive
with a belt sander or wire brush and then soaking it in acid until it
dissolves.
If shredding is good enough for your paper records (vs shred,
incinerate, stir, then dissolve in acid) then the IFIPS standard is
probably good enough for your hard drives.
If you're using Windows, simply running
   cipher /w:p:
will overwrite all the spaces on drive p: that don't hold files, first
with zeros, then with ones, then with random patterns. You can do this
while the machine is in use. Of course, if you format P: and then do it,
it'll wipe pretty much everything except (potentially) old file names.
Date: 26 Jun 2008 12:50:00
Message: <web.4863c87ab122afc76cf3d0b10@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote:
> Um, actually...
> e.html
> money.
This has always bothered me.  Something does not hang right.
Could one just copy a couple of version of a linux distro (0.6 to 4 GB) on top
of it?  Would THAT be enough to completely obfuscate what was originally on the
disk?   If not, then why hasn't anyone yet made a commercial use of the ability
of HDD's to remember everything that has ever been on them?
Date: 26 Jun 2008 13:36:37
Message: <4863d3a5@news.povray.org>
news:4863bd87@news.povray.org...
Show me where in your original message you said anything about having done a
proper purge of the drive.
Date: 26 Jun 2008 13:39:16
Message: <4863d444@news.povray.org>
"gregjohn" <pte### [at] yahoocom> wrote in message
news:web.4863c87ab122afc76cf3d0b10@news.povray.org...
top
on the
ability
Copying files over won't guarenteed overwrite ever single sector of the
drive
Date: 26 Jun 2008 13:50:52
Message: <4863d6fc$1@news.povray.org>
I gave him more credit than to complain about it without having actually
erased the drive. :-)
Date: 26 Jun 2008 13:57:16
Message: <4863d87c$1@news.povray.org>
"Even if they've been erased, you can still get data off them."
Now, if I'd just done something like
   delete C:\*.*
then my boss would have a point. With the right tools, it wouldn't be
too hard to get the files back.
What I actually did was
   dd if=/dev/zero of=/dev/sda
[Note that that's "sda", not "sda1", meaning the partition table and MBR
are gone too.]
Using random data would be slightly more secure, but we have already
reached the point where drive disassembly [and extremely expensive
specialist equipment] is required. Given the sensitivity of the data
involved... further effort seems overkill.
