POV-Ray : Newsgroups : povray.off-topic : Oh what joy! Server Time
29 Mar 2026 06:50:23 EDT (-0400)
  Oh what joy! (Message 62 to 71 of 91)
Subject: Re: Erasure
Date: 27 Jun 2008 17:23:09
Message: <48655a3d$1@news.povray.org>
>> holding file data will still be intact. (Formatting with, say, ext2
>> takes a tiny fraction of the time that FAT or NTFS formatting takes,
> D'oh?  Hardly.   I've never had an NTFS format take more than a half a
> minute or so, and formatting a 750G drive with ext3 on the same machine
> takes 10 or 15 minutes.
For me, it typically takes about 20 minutes to do a full NTFS format on
a large partition. (Doesn't seem to matter how big the drive is -
presumably because larger drives are also newer and hence faster.)
> Ext2/3 stores i-nodes all over the disk, preformatting them. This takes
> time when you have a couple gig of i-nodes to fill out.
For me, ext2 takes about 15 seconds or so - very much faster. Comparable
to an NTFS "quick format".
>> I am unsure as to whether #4 and #5 are different in any way. Both
>> seem to take the same amount of time...
> On my drives, at least one of the maxtor "format back to factory-fresh"
> only wrote the first sector on each track or something. It finished way
> too fast to be writing the whole drive. Unless the drive had a command
> built in that wiped the entire track in one rotation or something,
> rather than actually having to transfer the data from memory to the
> drive for the whole thing.
On the Maxtor tool I have, there are two options: "low-level format
(quick)" and "low-level format (full)". The former erases the beginning
and end of the drive. The latter erases everything. (And takes a
ridiculous amount of time to complete.)
Clearly I'm going to have to actually do some experiments. :-P
http://blog.orphi.me.uk/
Subject: Re: Oh what joy!
Date: 27 Jun 2008 17:24:06
Message: <48655a76$1@news.povray.org>
Jim Henderson wrote:
> First rule in data security:  Never assume any data is unrecoverable.
> Second rule in data security:  Never assume nobody is watching.
Third rule in data security: There's no point in overkill. :-P
Date: 27 Jun 2008 17:28:49
Message: <48655b91$1@news.povray.org>
>> I see lots of talk of *boken* hard drives, but not much about
>> deliberately erased media.
> They've got the equipment for that.  I used to talk with them
> occasionally, and they did do forensic analysis for law enforcement back
> then.  Don't know if they still do.
Forensic analysis isn't too hard if the person didn't get a change to
destroy their data before the PC was ceased. ;-)
>>> Or use something like this: http://freshmeat.net/projects/mobiusft/
>> I can't even find any documentation explaining what this *is*...
> It's a forensic data toolkit.  Used for investigating criminal activity
> that's been stored on hard drives and then wiped/erased/whatever.  Often
> times, you don't recover a file, but you recover data on individual
> blocks (think like chkdsk).
Right. But if I've erased every individual block on the drive (rather
than just, say, reinstalling Windows on it) then it won't find anything.
>>> - people have been convicted using evidence recovered from a drive
>>> without using "a microscope" (and BTW, how would that help?  The data
>>> is encoded in a magnetic field, a microscope won't see that).
>> I didn't mean a light microscope - I was actually thinking of a Magnetic
>> Force Microscope...
> Well, all I know is that I know people who actually *do* this kind of
> work on a regular basis.
> Doing a DoD style wipe is generally sufficient, but as others pointed
> out, the point from a data security standpoint is to make the cost of
> recovery more than the value of the data when recovered.  In *most*
> cases, a wipe is sufficient, but it really depends on how valuable the
> data is to your competition.
1. These drives probably never contained any live data in the first
place. ("Live data" as in data generated in our lab.)
2. Any such data they did contain is going to consist of a huge chunk of
numbers, with little or nothing to identify what the hell they relate to.
3. Any such data will be at least 5 years old.
Really, it would be far, *far* easier to just have somebody come work
for us and secretly spy on our activities... Much cheaper than James
Bond data recovery techniques.
Date: 27 Jun 2008 17:31:01
Message: <48655c15$1@news.povray.org>
Gail Shaw wrote:
> One the subject of format, what does Low-level format actually do?
Nowadays, it means many different things, depending on the drive.
On old floppies, you used to have to do a low-level format by writing a
pattern of bits to the track as it spun. Basically, since floppies don't
spin exactly the same speed all the time, you need to first write a lead
in, then a bunch of sectors, then enough of a lead-out that you are sure
you overwrote the lead-in without overwriting the first sector. Each
sector consisted of a set of bits that said "here comes a sector", then
the track and sector number and sector length, then some mungable bits
that gave the read/write head time to switch from reading to writing,
then bytes that said "here comes the sector data", then the bytes of the
sector, then the flag that said "here comes the end of the sector". The
byte pattern for "the body of the sector" when you formatted it was
traditionally E5 (hex), which is why when you delete files on FAT (or
CP/M) file systems, it overwrites the first byte of the directory entry
with E5.
So that was the low-level format - taking a completely erased disk and
writing out all the header information that said which bytes were
included in which sectors.
(The Amiga stored more on the disks by basically rewriting the entire
track each time the sectors were written. Just as fast, and you didn't
need to be switching between read and write every time.)
Note that floppies are actually serial devices. So to store more than (I
think) three or four bits of 1's or 0's in a row, you have to inject
differences between. (So you have to encode 00001111 as 00101101, or
something. MFM is one such common encoding.) Kind of the same reason a
slow modem has clean tones and anything over 2400 has a "noisy" tone -
it's doing the same sort of randomized bit stuffing. The Amiga DMA
hardware could do that sort of stuffing without CPU intervention, so it
wasn't a lot of overhead to rewrite an entire track when you changed one
sector.
Nowadays, floppies come pre-low-level-formatted. I think if you put in a
"raw" floppy (i.e., one with a file system the OS doesn't recognise), it
will do the low-level format. Otherwise, you couldn't erase a floppy
with a magnet and then have it work.
With a hard-drive, it used to be the same sort of thing. Some hard
drives, however, now have one platter dedicated to nothing but
synchronization information, basically. So all the information about bit
timing and such is on one platter. In other words, instead of a serial
stream, there's a parallel stream. Doing a "low level format" means
rewriting that platter, which is much more sensitive to problems of
rotational speed and such. In other words, they do they low-level format
on a machine with much higher precision than the motor they put in the
drive they sell to you, so it's very hard to recreate the patterns.
Nowadays, a "low-level format" on a hard drive means to write some
constant pattern over all the bytes you can write to.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 27 Jun 2008 17:38:56
Message: <48655df0$1@news.povray.org>
Oh, are you doing a quick format, or a full format? A "full format"
actually does read the entire drive. Ext apparently won't do a "full
format". You have to do a quick format, then scan the disk for errors.
>> takes time when you have a couple gig of i-nodes to fill out.
Try doing a "quick format" with NTFS. The difference between a 15-second
ext format and a 20-minute NTFS format gives me the impression that your
NTFS format is actually looking for flawed sectors to map out.
Either cipher /w:x: on Windows (or at least Windows recent enough to
actually have that functionality) or dd if=/dev/urandom should do the
trick.
I'll try formatting a spare partition I have here with NTFS and ext2 and
see what I get in timings.
Date: 27 Jun 2008 17:52:18
Message: <48656112$1@news.povray.org>
Doctor John wrote:
> GPG shreds files on all my machines. It can also encrypt a whole
> filesystem. What else do you need?
Deniability and perfect forward secrecy?
Date: 27 Jun 2008 17:54:52
Message: <486561ac$1@news.povray.org>
Doctor John wrote:
> m_a_r_c wrote:
>> good quality coke
> Snort! :-D
> John
Yeah, why burn it when that's still an option?
Date: 27 Jun 2008 18:14:32
Message: <48656648$1@news.povray.org>
OK, on a 40 gig partition,
ntfs /q - 5 seconds
ntfs full scan - about 20 minutes. (I stopped 10% in)
ext2 - 23 seconds
ext2 -c (full scan) - about 20 minutes.
ext3 - 27 seconds.
(Note the extra 4 seconds is roughly a constant, independent of disk size.)
An ext3 format of a 750G drive at work took something like six to ten
minutes, but I might have had other layers in there (raid or encryption
or something) that I don't recall.  I do recall doing the equivalent of
chkdsk /f /r on the ext3 drive went about 36 hours for the first pass,
and then said "starting second pass" without even any indication of how
many passes it was planning to do, so I killed it at that point. :-)
Date: 28 Jun 2008 01:36:14
Message: <4865cdce$1@news.povray.org>
Invisible wrote:
> As far as I know, both option #5 and option #6 make it impossible to
> read any useful data from the drive just by plugging it in and asking
> the drive electronics to read the data off the disk surface. In either
> case, you would have to physically dismantle the drive and crawl over it
> with a microscope - which is damned expensive. Using random data (and
> multiple passes of it) reputedly makes this process harder - but not
> impossible. Non-sequential writes are supposed to make it harder still.
The US military overwrites (with pseudorandom data) five times before a
classified drive becomes unclassified.
I suppose a drive could be designed so that a single pass is good
enough, but if you're in that big a hurry, thermite is your friend.
John
Date: 28 Jun 2008 05:06:40
Message: <4865ff20$1@news.povray.org>
Full format.
Does it just scan the disk, or does it actually write data to it? I was
under the impression it wipes the cluster descriptors, yet doesn't
actually erase every single block on the disk...
>> Comparable to an NTFS "quick format".
An NTFS quick format takes about 15-20 seconds, same as ext2.
