POV-Ray : Newsgroups : povray.off-topic : Microphones Server Time
11 Jul 2026 04:30:16 EDT (-0400)
  Microphones (Message 12 to 21 of 31)
Subject: Re: Microphones
Date: 12 Jun 2008 11:48:13
Message: <4851453d$1@news.povray.org>
Invisible wrote:
> Mmm - I understand you can also make a mic out of a speaker. But it
> tends not to work well. ;-)
That's how the very first telephones worked. By the time they actually
got to something like a switchboard (i.e., telephone rather than
intercom) they figured they could separate the two.
> Hey, I wonder - can I use the alternator on my car to drive the car
> instead of recharge the battery? :-D
Yes. It's called a starter motor. ;-)
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 12 Jun 2008 13:55:32
Message: <48516314$1@news.povray.org>
>> The pre-amp is probably expecting a real microphone, not one that needs
>> power.
> Some top-notch microphones need power :-)
I was going to say... it's usually only *expensive* mics that need power
only expensive studio equipment provides this power too...
http://blog.orphi.me.uk/
Date: 13 Jun 2008 05:27:44
Message: <48523d90$1@news.povray.org>
Probably with half a dozen, I'd guess they'd be 2 - 5 HP each,
would need a good DC to 3 phase controller of course.
http://www.diyelectriccar.com/forums/showthread.php/alternator-motor-conversion-booklet-2959.html
It might be a cheap way to drive one of those carts they
get the HS students to race at the enviro-fairs.
Date: 13 Jun 2008 05:48:17
Message: <48524261$1@news.povray.org>
The starter motor is designed to convert electric to kinetic. The
alternator is designed to convert kinetic to electric. I'm musing over
whether either device can do the *opposite* job. :-P
Actually, you laugh, but I did see a report about a car that has a giant
motor inside it that drives the wheels at low speeds, acts as a starter
motor to start the petrol engine when the car is moving fast enough, and
acts as an alternator to charge the batteries thereafter. Basically the
petrol engine only runs while the car is doing more than 20 MPH. The big
advantage being that waiting at traffic lights uses no fuel.
[Actually, having computed that my car uses 10^(-6) L of fuel per minute
even when it's flying down the road at 75 MPH, I wonder just how much
fuel it can possibly be wasting on tickover? And also, doesn't
repeatedly starting up a petrol engine waste fuel anyway?]
Last I heard the car never came to market. They were still playing with
the control software to try to figure out the most optimal algorithms...
Date: 13 Jun 2008 05:59:31
Message: <48524503$1@news.povray.org>
m_a_r_c wrote:
> Out of curiosity, whitch model is your additionnal soundcard?
Behringer F-Control Audio FCA202 (I think!)
Unbalanced input impedance = 24 kΩ, max level = 2 dBV.
Date: 13 Jun 2008 06:30:42
Message: <48524c52$1@news.povray.org>
A useful tip that (apparently) not many people know, is that if you've
broken down in a dangerous location you can use the starter motor to move
along at slow speeds in *any* car (ok maybe not in those american
automatics).  Just put it in 1st gear and try to start the engine - it will
allow you to move the car to a safer location (assuming you don't also have
a flat battery!).
> The big advantage being that waiting at traffic lights uses no fuel.
My car does that already - as soon as you are stationary, in neutral, and
let go of the clutch pedal, the engine stops.  And then as soon as you touch
the clutch pedal it restarts.  Apparently meant to save a few % of fuel when
driving in cities.
Wow! What car do you have with such great fuel economy? ;-)
> I wonder just how much fuel it can possibly be wasting on tickover?
I had a Ford once that showed the fuel economy in realtime as you were
driving, but if you were stopped it switched to litres per hour, was
something like 1.5 litres per hour IIRC when stationary.  I rememeber
figuring out I could leave it running for a day or so until it used up a
full tank.
> And also, doesn't repeatedly starting up a petrol engine waste fuel
> anyway?]
Depends how warm the engine is and how often you restart it.  For a fully
warm engine I think that if you're going to let it idle for more than a few
seconds it's better to switch it off and restart.
Date: 13 Jun 2008 07:27:45
Message: <485259b1$1@news.povray.org>
> move along at slow speeds in *any* car (ok maybe not in those american
> will allow you to move the car to a safer location (assuming you don't
> also have a flat battery!).
The thing I find interesting is that my car weighs easily enough to
crush every single bone on your body... and yet it's not actually that
hard to push it along a road. If it's parked on the drive and I need to
move it a few feet to open the guarage door or something, take the
brakes off and push it... it moves surprisingly easily for such a damn
heavy object. (I guess my wheel baring work really well?)
OTOH, if there's a hill... forget it.
(Also curios is the fact that the car doesn't accelerate when you drive
it down a hill... You'd think it would.)
> and let go of the clutch pedal, the engine stops.
Mmm, interesting.
I would think this electric motor trickery probably also saves fuel on
low-speed manovers like trying to park. [Think how much you have to rev
the engine to make a car move that slowly...]
>> minute even when it's flying down the road at 75 MPH,
...OK, so maybe it wasn't exactly 10^(-6). But it worked out to be some
absurdly small figure anyway.
Interesthing. I thought it would be smaller...
>> anyway?]
I've always wanted to know... An engine is a mechanical device. So why
does temperature have any effect on anything?
Date: 13 Jun 2008 07:35:42
Message: <48525b8e$1@news.povray.org>
48524503$1@news.povray.org...
> Unbalanced input impedance = 24 k?, max level = 2 dBV.
this one then?
http://www.behringer.com/FCA202/index.cfm?lang=ENG
If I read correctly the specs sheet, it has a dual line input, no microphone
input.
you need a preamp providing plugin power to get your pc microphone working
with it.
Marc
Date: 13 Jun 2008 08:18:32
Message: <48526598@news.povray.org>
485259b1$1@news.povray.org...
http://en.wikipedia.org/wiki/Flash_point :-)
Marc
Date: 13 Jun 2008 09:40:38
Message: <485278d6$1@news.povray.org>
> The thing I find interesting is that my car weighs easily enough to crush
> every single bone on your body... and yet it's not actually that hard to
I guess they design them to be pretty good :-)
> (Also curios is the fact that the car doesn't accelerate when you drive it
Press the clutch and start off at 5mph so as to avoid any air drag.  It
should accelerate then.
Ermm, my car moves just by lifting the clutch gently, no need to rev at all.
IIRC you meant that amount per revolution of the engine, not per minute!
Things expand with temperature, an engine is designed to run smoothly at
it's operating temperature, below that there is a lot more friction.
