pan <pan### [at] syixcom> wrote:
> Round manholes fit whichever orientation you drop them.
> Round manholes cover (usually) cyclindrical access spaces which are
> better able to resist ground pressures and (again) permit putting
> thiings
> into them without concern for orientation. (Round pegs/square
> holes:
> square pegs/round holes).
You left out the fact that a round cover will not fall into the manhole
no matter how you might screw up opening it.
And what everyone so far has missed is that roads get repaved. The
manhole screws into the vault at the bottom (so you can make it flush
with the surface of the road) and has threads on the outside. When you
repave the road, the first thing you do is give all the manholes an
extra crank or two to lift them up an inch or so, so they stay flush
with the surface of the road after you add more asphalt.
Plus, of course, it takes less metal to make a round cover to cover a
certain opening than any other shape, which is important when you're
planning to place millions of manholes and calculating how much your raw
materials will cost.
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
On Sun, 08 Jun 2008 14:27:26 -0700, Darren New <dne### [at] sanrrcom>
Not in the UK they don't. They are kept in position by gravity. They
lift in and out vertically.
Regards
Wow. How do they keep them level with the road, then? How do they even
make them level with the road in the first place?
"Darren New" <dne### [at] sanrrcom> wrote
manhole
Another incidental benefit, but not the ultimate reason. Manholes have
always been predominantly round, even in cobblestone streets, which are not
designed for repaving higher, and where round bezels are actually often a
*liability* (See
http://images.google.ca/images?hl=en&q=cobblestone%20manhole ). Plus not all
manhole bezels are threaded in.
Hinged...
http://www.ngs.noaa.gov/PUBS_LIB/GeodeticBMs/images/figure05.jpg
Decorated...
http://barista.media2.org/wp-content/manhole%20japan.jpg
http://www.pinktentacle.com/2007/10/japanese-manhole-covers/
Square...
http://www.tilingandpoolprojects.co.uk/images/manHoleLarge.jpg
http://www.forgotten-ny.com/STREET%20SCENES/manholes/CT&ESC.jpg
http://www.soe.uoguelph.ca/webfiles/wjames/illustrations/AestheticInfrastructure/MHcoverSquareSanitaryPafosCyprus.JPG
http://farm2.static.flickr.com/1320/1431363588_d3de12ea72.jpg?v=0
Well, sure. Are manholes older or newer than paved streets, tho? Once
you have paved streets and decide you need manholes to be round for
them, one might decide that one might as well use manholes on paved
streets, as well?
Funny enough, the first image at that link shows a square manhole for
me. :-)
And lo on Sun, 08 Jun 2008 23:01:45 +0100, Darren New <dne### [at] sanrrcom>
did spake, saying:
If you're talking about what I think you are then there are adjustment
bricks that can be altered to raise or lower the level, but on a new road
(or a stripped one) the level of the road surface is dictated by the
ironworks. If an alteration is done then a square is cut around the cover,
the work is done and that section of road is resurfaced to the level of
the ironwork. Oh sure there are rules about the degree of difference
between new and existing surfaces - heh, but this is why we have the lumpy
bumpy roads we know and love :-P
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
On Mon, 09 Jun 2008 09:38:12 +0100, "Phil Cook"
Thanks Phil, you said it just as well as I could or better :)
Regards
And lo on Mon, 09 Jun 2008 09:50:37 +0100, Stephen <mcavoysAT@aolDOTcom>
did spake, saying:
My pleasure. Not that I, you know, take any real interest in road surfaces
:-P
Phil Cook
