POV-Ray : Newsgroups : povray.off-topic : Quotable Server Time
2 Jul 2026 15:47:20 EDT (-0400)
  Quotable (Message 61 to 70 of 179)
Subject: Re: Quotable
Date: 2 Jun 2008 03:37:01
Message: <4843a31d$1@news.povray.org>
>   If there's "no evidence", what do you call the interference pattern?
> "Non-evidence"?
Don't forget: A single electron doesn't make an interference pattern. It
produces a bright spot on the fluorescence screen saying: Exactly here
and nowhere else the electron hit the screen.
Only if you observe many many events and add up their positions they
converge to an interference pattern.
Date: 2 Jun 2008 03:37:07
Message: <4843a323@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> For example, there's no known mathematical model to indicate where a
> specific electron is, and indeed if I understand correctly, experiments
> show there cannot be one.
  That's a bit like being in the middle of the ocean and saying "there's
no mathematical model which says where the water is", speaking as if the
"water" was a point in space and you'd had to locate it at some specific
coordinates.
  Your statement is like that. You are starting from the assumption that
an electron is an extremely small particle with well-defined boundaries,
approximately equal to a mathematical point, and then you ask for a
mathematical model to say where that point is in space. As with the
water example, that's kind of silly.
  What the mathematical model *can* do is to give a distribution function
which tells how the electron is distributed in space (a bit like a
function which tells how the water is distributed, except that with
the electron the "density" of the "water" is not constant).
  These probability functions may not be infinitely accurate (because they
depend, among other things, on finite measurements which are accurate only
to so many decimals), but they can be used for practical calculations.
  It's not like you could shoot an electron to some direction, and then
the electron suddenly hits the other side of the Earth (or the solar
system). It hits a quite accurately calculable place.
Date: 2 Jun 2008 03:38:58
Message: <4843a392@news.povray.org>
Stephen <mcavoysAT@aoldotcom> wrote:
> >> Do you mean that someone has managed to square the circle?
> >  The "squaring the circle" problem imposes some restrictions.
> Indeed, a straight edge and compass. What more do you need?
  I assume that dividing the circle into an uncountable set of points.
Date: 2 Jun 2008 03:41:22
Message: <4843a422@news.povray.org>
  Wasn't it "impossible" to accurately measure the place and velocity
of a quantum particle? ;)
  But I believe it can be done by shooting just one electron at a time,
so the electron indeed interferes only with itself, not with other
electrons.
Date: 2 Jun 2008 03:45:33
Message: <4843a51d$1@news.povray.org>
Am Mon, 02 Jun 2008 03:41:22 -0400 schrieb Warp:
>> It produces a bright spot on the fluorescence screen saying: Exactly
>> here and nowhere else the electron hit the screen.
Indeed, and that's what I said: It hit the screen *here* and I have no
clue how fast and from what direction :P
> electrons.
Yes, I've seen this experiment. *Single* bright spots lighting up
briefly, no observable pattern if you just look at it. Unless you average
"all the video frames" (which you can do either with real video frames or
"simulated" with a photographic film), an interference pattern emerges.
Date: 2 Jun 2008 03:48:47
Message: <6d9744lamipqvgdo0c5po1u36b4ot0ngal@4ax.com>
Invisible ???
Regards
Date: 2 Jun 2008 07:30:00
Message: <4843d9b8@news.povray.org>
Darren New wrote:
> Warp wrote:
>>   I would say that mathematics can always be used to represent reality
>> when put in the proper context.
> The fascinating thing to wonder about is ... why is this so?
> Most people are so used to it that it's hard to even imagine a world
> where this isn't true. Even the religious types try to come up with
> "laws" that would govern the supernatural.
> Of course, maybe that's just anthropogenic. If the universe didn't work
> consistently, I'd (wild-ass) guess that it's likely that life capable of
> wondering about it wouldn't have evolved.
> And the thing about QED is there doesn't seem to be math at the bottom
> level - it's random on an event-by-event basis. (Maybe there's a math
> for that? I don't know of any. Statistics only deals with multiple events.)
I wouldn't say that it is truly random, but merely that predicting the
outcome of any interaction requires information that is presently not
available.
For instance, the decay of unstable particles appears to happen
randomly, but at what appears to be a predictable rate for aggregate
amounts of like particles.  What is likely is that the particles decay
when they encounter certain conditions (such as a gradient in the
electric or magnetic potential) that is high enough to overcome the weak
internal cohesiveness of the particle, causing it to come apart.  Since
the gradient of potential at any place is not (and probably cannot be)
known with sufficient precision (and is certainly in a state of constant
change), it appears random.
John
Date: 2 Jun 2008 10:29:04
Message: <484403b0@news.povray.org>
somebody wrote:
> "Darren New" <dne### [at] sanrrcom> wrote in message
> news:484363fb$1@news.povray.org...
> Some syntatically correct questions can be meaningless. What colour is the
> note C#?
It's an octave of blue, if I got the math right. I started from 4435Hz,
though, instead of a more accurate number, so it's probably off by a bit.
Date: 2 Jun 2008 10:34:18
Message: <484404ea@news.povray.org>
>> the note C#?
You see the look on my face right now? This look means that you have
just BROKEN MY MIND!
http://www.questionablecontent.net/view.php?comic=165
http://blog.orphi.me.uk/
Date: 2 Jun 2008 11:43:07
Message: <4844150b$1@news.povray.org>
Warp wrote:
>   Ever heard of the Banach-Tarski paradox? A solid ball in 3-dimensional
> space can be split into several non-overlapping pieces, which can then be
> put back together in a different way to yield two identical copies of
> the original ball.
Am I the only one here, who's waiting for a raytraced animation-example
of this? :)
Eero "Aero" Ahonen
    http://www.zbxt.net
