POV-Ray : Newsgroups : povray.off-topic : A small puzzle Server Time
14 Jun 2026 05:12:00 EDT (-0400)
  A small puzzle (Message 19 to 28 of 198)
Subject: Re: A small puzzle
Date: 17 May 2008 04:26:47
Message: <482E96F2.8080207@hotmail.com>
Darren New wrote:
> Jim Henderson wrote:
>> Perhaps in a manual transmission - in my automatic, though, I'll stick
>> with what I indicated.
> Sure. But the automatic has a clutch built into it. That's why you only
> have two pedals.
http://en.wikipedia.org/wiki/Variomatic
just plugging dutch technology that never really caught on.
Date: 17 May 2008 05:23:40
Message: <482ea41c$1@news.povray.org>
> with what I indicated...
Oh, well, yeah. Automatic transmission basically means it can change
gear and lock/unlock the clutch at will. And doing both of those things
changes the relationship. ;-)
My car has manual transmission.
http://blog.orphi.me.uk/
Date: 17 May 2008 05:25:53
Message: <482ea4a1$1@news.povray.org>
>> There isn't a linear relationship between the rotational speed of the
>> wheels and the speed of the engine.
> There is, in a (relatively primitive) manual transmission.
Indeed.
> There is not,
> however, a linear relationship between engine RPM and gasoline usage.
No - that would depend on the smoothness of the road, the inclination,
wind speed, and a bunch of other factors. Even so, I would expect it to
be possible to come up with an *approximate* number for fuel used per
cylinder.
Date: 17 May 2008 05:29:45
Message: <482ea589@news.povray.org>
It did, when improved enough.
http://www.audiworld.com/news/99/multitronic/content.shtml
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 17 May 2008 05:42:34
Message: <482ea88a$1@news.povray.org>
>> No wonder hitting anything is an instant fatality...
> Hmm, yeah, 110 feet per second, wear your seatbelt.
And won't walk across busy motorways at night while dressed only in
black. ;-)
Also, DON'T HIT A TREE!
[A nice mature Oak has brunches going up to 30 feet into the air, and
roots going down to 30 feet into the ground. The entire organism
probably weighs multiple tonnes. If you hit it, IT'S NOT GOING ANYWHERE!]
> 0.0027 tsp of gas per cylinder. (other factors ignored).
Hmm, that's actually really small... that's like... 0.015 ml. o_O
That can't be right, surely? That's less than one droplet per cylinder!
How would you portion out such a tiny amount? Surface tension would seem
to make this impossible.
Date: 17 May 2008 06:45:55
Message: <482eb763@news.povray.org>
> cylinder.
Yes, ~1/4 of used fuel is used for one cylinder (but not injected in one
- it's injected to the air intake before cylinders;). Just multiply the
~28,75cm with consumption (l/100km) and you'll get the average amount of
fuel .
Just a side-note: given that IIRC your car is <2l naturally aspirated,
I'd guess the maximum possible fuel used per minute per cylinder with
original parts is somewhere around 200cc (the injector capacity), giving
total of 0,8l/min. OTOH, that much is used rarely, basically only when
revving with pedal on the floor at the rpm of maximum power.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 17 May 2008 07:06:28
Message: <482ebc34$1@news.povray.org>
On one rev the car moves 28,75cm, in that time 2 sparks are launched.
Google says 40mpg (US, AFAIK it's pretty near 50imperial MPG) converts
to 5,8l/100km (which is pretty low for 120km/h, but possible, if you
have a modern diesel with long gearbox and good aerodynamics).
5,8l/100km makes
0,058l/km=0,000058l/m=0,00003335l/rev=0,00001668l/spark=0,01668ml/spark.
Yep, we're on the same line - I'd say the differences comes from the
roundings and converts.
To get to that consumption on those speeds you'll need a modern diesel
engine (or a hybrid-system), for example common rail -engine. In those,
the diesel is packed with very high pressure (>1000bar) on a kind of
pipe before the cylinders and released to cylinders very precisely with
piezo-electric injectors. Really fine mechanics, think about a
manufacturing fault in there...
http://en.wikipedia.org/wiki/Common_rail
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 17 May 2008 07:24:25
Message: <482ec069$1@news.povray.org>
HUGE mistake - on HALF rev the car moves 28,75cm and in that time only 1
spark is launched, therefore...
> 5,8l/100km makes
... these last numbers DO NOT MATCH, the correct final number being
0,03335ml/spark.
Also to be noted, if you really have common-rail diesel or something
similar (I recalled you have a non-GDI petrol engine), the fuel actually
is injected to the cylinder, not to the intake.
Eero "Aero" Ahonen
    http://www.zbxt.net
Subject: A different measure
Date: 17 May 2008 20:54:15
Message: <482f7e37$1@news.povray.org>
Invisible wrote:
> OK, so here's one for you...
> If I put my car into top gear and set the engine to 3,500 revolutions
> per minute, my car travels forward at almost exactly 75 miles per hour.
> So... how far forward does it travel for a single revolution of the
> engine??
> Similarly, at that speed my car achieves roughly 50 miles per gallon of
> fuel. So how much fuel does it inject into each cylinder??
> [My car has a four-cylinder, four-stroke internal compustion engine, and
> is normally-asperated. And runs on petrol, in case that wasn't obvious.
> Presumably the timing is therefore set so that exactly one cylinder
> fires for every revolution of the engine.]
The fuel consumption of a vehicle is often quoted (in metric) as litres
per 100km.  Suppose a medium sized sedan gives 10L/100km to keep the
maths easy.
So we have fuel consumption as a volume per distance.  That means it can
be reduced to an area.  Think of it as the cross-section area of a
cylindrical line of fuel that the vehicle is consuming as it hurtles
down the road.  Of course when you accelerate the engine guzzles more
than this average and while cruising at some optimal speed (around
80km/hour ?) it would sip a bit less so the shape is tapered.  It isn't
a simple cylinder but rather a lumpy one.
Lets ignore these variations and work out how large this cross-section
is on average.
Well do the calculation and you get 0.1 mm^2.  That is one tenth of a
square millimeter!  Depending on the size and resolution of your screen
and the font size that you use it is about the area of a full stop.
So as you cruise along a motorway your vehicle is slurping a stream of
fuel about the same size across as a largish grain of sand, burning it
to produce hot gases and farting them out the rear.
I find the fact that such a seemingly miniscule amount of fuel can be
used to propel quite massive vehicles along at such speeds quite
amazing.  The energy density and convenience of petroleum fuels is just
astonishing.  As someone once said if you were to write down the ideal
properties of a vehicle fuel you would pretty much define petrol.  High
energy density but not (terribly) explosive, liquid over a wide range of
temperatures, cheap (well relatively), easy to handle, not (too) toxic
or corrosive etc.
Second thought though is that when you add up the consumption of tens of
thousands of vehicles along a section of major road each day it does
start to amount to quite a lot.  Those fractions of a square millimeter
accumulate to something like the cross section of a fire hose or water
main.  Imagine the threads of each vehicle weaving with others to form a
massive cable down the center of the road.  Smaller roads might equate
to a garden hose each.  Sum this across a city and it is a huge web
spread down every road and tangled across every intersection.
Over the course of a year the sum cross section along a major road would
be larger than the cross section of a petrol tanker truck.  So it is
like every highway and major road being lined with tankers parked nose
to tail.
And all of this is with a liquid that was produced millions of years
ago.  It is the captured sunlight that fell on forests in the time of
the dinosaurs.
Subject: Re: A different measure
Date: 18 May 2008 04:31:56
Message: <482fe97c$1@news.povray.org>
> astonishing.
On the other hand, steam engines are more efficient. (I.e., transform
more of the available energy into useful work.) But they're really not
"convinient" at all.
Uh, yeah...
> the dinosaurs.
Indeed.
Still, you'd think it would be possible to somehow take plants living
today and transform their tissues into some kind of highly flammable
hydrocardon with reasonably efficiency. This would seem the obvious
sustainable solution.
