POV-Ray : Newsgroups : povray.off-topic : Feeling the pinch yet? Server Time
9 Jun 2026 08:22:57 EDT (-0400)
  Feeling the pinch yet? (Message 24 to 33 of 53)
Subject: Re: Feeling the pinch yet?
Date: 21 Mar 2008 10:36:45
Message: <cfl7u3ddjcitaopimgbhnju19r8if09sdl@4ax.com>
On Fri, 21 Mar 2008 17:14:52 +0200, "Gail Shaw"
<initialsurname@sentech sa dot com> wrote:
>"St." <dot### [at] dotcom> wrote in message news:47e3be7e$1@news.povray.org...
>>   Well, ok, but what if the back springs were just rewound by the drive of
>> forward motion (and not from the front two springs) anyway?
>You'd still get less energy (a lot less) back into the spring. Basically
>Energy from unwinding spring = energy converted into forward motion + energy
>stored back in spring + energy converted to heat.
>(or in physics terms)
>Energy added to system = Delta (kinetic energy) + Delta(potential energy) +
>heat
He is pulling your leg :)
Unless St thinks that the world is flat (and if it is, where are you
then?) then he is seeing how long it would take for you to cotton on.
Regards
Date: 21 Mar 2008 10:40:34
Message: <ail7u31509e72bpk92pq7v3d7jtnepes5l@4ax.com>
On Fri, 21 Mar 2008 15:33:28 -0000, "St." <dot### [at] dotcom> wrote:
>  Yes, to me as a non-scientific person, I'm thinking that this is, and
>should be, achievable/possible, but alas, something that *seems* so simple,
>is clearly not the case.
Opps! Scratch the last post to Gail. :)
Sorry!
"Oh! Dear" he said. (Falling off the edge of the world.)
Regards
Date: 21 Mar 2008 10:42:23
Message: <47e3d75f@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47e3d54d@news.povray.org...
simple,
Think of it this way. If you have 2 pans of water, same volume, one's just
above freezing point (0C) and one at boiling point (100C). Can you use the
pan of boiling water to bring the second pan up to boiling point?
Similar thing, just with heat, instead of springs
Date: 21 Mar 2008 10:43:18
Message: <47e3d796@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47e3d2fb@news.povray.org...
> Yes, I've just done a little reading about PMM's and thermodynamics was
> mentioned quite a lot. I don't know, I can see that yes, there would be a
> problem with heat, but what about other materials? I know that PTFE is one
> of the slipperiest plastics out there, but then of course, you wouldn't
have
> the strength.
Heat's just the loss of energy from the system. Even if you have a
frictionless material, you cannot create energy. Say we have found a
frictionless material (or one with such low friction it's barely noticable)
Say a fully wound spring as an amount of energy in it (X joules). You use
that to increase the speed of a vehicle, (using Y joules where X<Y), then
all you have left to rewind the second spring is the left over (X-Y)
Energy can never be created or destroyed. It can only be converted from one
form to another - 1st law of thermodynamics
Date: 21 Mar 2008 10:44:16
Message: <47e3d7d0@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> wrote in message
news:cfl7u3ddjcitaopimgbhnju19r8if09sdl@4ax.com...
    It ISN'T flat??  :oO
     ~Steve~
> Regards
>     Stephen
Date: 21 Mar 2008 10:44:24
Message: <47e3d7d8@news.povray.org>
news:ail7u31509e72bpk92pq7v3d7jtnepes5l@4ax.com...
simple,
> Sorry!
Don't worry, it's nice under here. *g*
Date: 21 Mar 2008 10:50:52
Message: <i9m7u3louiamhao5rsd4sk2q96fhifd3a8@4ax.com>
On Fri, 21 Mar 2008 17:44:53 +0200, "Gail Shaw"
Yes, but I got dizzy with the blood rushing to my head :)
Regards
Date: 21 Mar 2008 10:55:53
Message: <47e3da89@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:47e3d75f@news.povray.org...
> simple,
 Oh! That's a good anology Gail! No, of course that couldn't happen, and I
can see no way around it to make it happen other than making use of other
materials to do it. For example, (and this is off the top of my head): Steam
from said hot water soaks a towel above it. Towel gets heavy and falls onto
lever, switching gas on under cold water pan to heat it up
  But there are those other outside influences again. I see the problem now.
     ~Steve~
Date: 21 Mar 2008 10:58:29
Message: <qlm7u3lr5ovt1v54g35cfjkirjikv4soks@4ax.com>
On Fri, 21 Mar 2008 17:42:53 +0200, "Gail Shaw"
Maxwell's demon could :)
Doesn't that mean the universe will suffer when Entropy increases?
Thus proving the end of society as St first pointed out.
You've just proved his point. And if he was right about that then
maybe the Perpetual Motion Machine is possible after all!
Regards
Date: 21 Mar 2008 11:31:06
Message: <47e3e2ca$1@news.povray.org>
Btw, literally just found this - the author is either psychic, or he knows
what he's taliking about. Note the date. It's a good read.
     http://www.usagold.com/contests/june2004.html
       ~Steve~
