POV-Ray : Newsgroups : povray.off-topic : Smart little programming tricks, where to find ? Server Time
28 Jun 2026 21:04:19 EDT (-0400)
  Smart little programming tricks, where to find ? (Message 22 to 31 of 51)
Subject: Re: Smart little programming tricks, where to find ?
Date: 19 Mar 2008 12:12:02
Message: <47e14962$1@news.povray.org>
Warp wrote:
> stbenge <stb### [at] hotmailcom> wrote:
>> What's wrong with C++?
>   Some people don't like the fact that memory management requires great care.
I don't find it too difficult to delete every "new". Of course, I
haven't coded anything too huge... yet.
Sam
Date: 19 Mar 2008 12:34:11
Message: <47e14e92@news.povray.org>
  You would be surprised.
  There's a potential memory leak here:
void foo()
    char* s = new char[100];
    bar();
    delete[] s;
class A
    char* s;
 public:
    A(): s(new char[100]) {}
    ~A() { delete[] s; }
  Naturally both of these leaks can be fixed by using cleaner code:
void foo()
    std::string s(100, ' ');
    bar();
class A
    std::string s;
 public:
    A(): s(100, ' ') {}
  No 'new' -> no leaks.
Date: 19 Mar 2008 13:00:04
Message: <47e154a4$1@news.povray.org>
Hey, but there are 'new's in the standard lib :-)
I think it would be more informative to give fixes that do not rely on
the standard library... After all the 'new' operator exists for a
reason, you don't always want to use the standard lib, and knowing what
to do in these cases is useful.
No I won't do it as I'm not even sure I know where the leak is in the
first case :-)
Vincent
Date: 19 Mar 2008 13:01:41
Message: <47e15505$1@news.povray.org>
> void foo()
>     bar();
>     delete[] s;
If bar throws an exception, s won't be deleted. It can be avoided by
using a smart pointer.
> class A
>     char* s;
>  public:
Erm... No idea :) I know it could cause a double-free if you copy the
object, since it doesn't have an explicit copy constructor and the
default one doesn't do what we want in this case; but I don't know what
could cause a leak.
> void foo()
>     bar();
> class A
>     std::string s;
>  public:
>     A(): s(100, ' ') {}
Of course a string is better for this particular case :) Also avoids
many possible buffer overflows (thought not all; operator[] is unchecked).
Date: 19 Mar 2008 16:02:56
Message: <47e17f80@news.povray.org>
  If the standard library cannot be used, then it becomes a bit complicated.
> first case :-)
  If bar() throws an exception you have a memory leak.
Date: 19 Mar 2008 16:04:51
Message: <47e17ff3@news.povray.org>
> could cause a leak.
  Ok, not a leak per se, but accessing freed memory. (Although that would
require more member functions than I added there...)
Date: 19 Mar 2008 17:15:59
Message: <47e1909f$1@news.povray.org>
>> could cause a leak.
Ahh, then I can say I did figure out both.
Date: 19 Mar 2008 17:36:56
Message: <47e19586@news.povray.org>
  Ok, if you want a harder puzzle, here's a curious quirk about C++ (not
related to memory leaks, though):
#include <map>
struct A { int i; };
struct Comp
{ bool operator()(const A& a1, const A& a2) const { return a1.i < a2.i; }
int main()
    std::map<A, int, Comp> theMap(Comp());
    A a = { 1 };
    theMap[a] = 5;
a) This doesn't compile. Without using a compiler, can you tell where
   is the problem and what is the exact reason why it doesn't compile?
b) If you can't see it, try it with a compiler. I bet you still can't see
   the problem... :P
c) In the erroneous line, can you tell me exactly what that line means?
d) What is the easiest way (smallest amount of extra code) to make it
   compile and work as expected?
Date: 19 Mar 2008 18:08:32
Message: <47e19cf0@news.povray.org>
>    the problem... :P
Well I have no real idea of what goes wrong but I have a proposition for
d) :-) Down below...
Replacing
with
     Comp c; std::map<A, int, Comp> theMap(c);
seems to do the trick as far as I figure. I don't like those anonymous
objects anyhow ;-)
A trouble with references or some such ? That prevents the full
instanciation of the map template ?
Vincent
Date: 19 Mar 2008 18:24:48
Message: <47e1a0c0$1@news.povray.org>
> #include <map>
> struct Comp
> int main()
>     A a = { 1 };
>     theMap[a] = 5;
Hrm, I never used map myself. I think I'll go search documentation on
what the template parameters are.
>    the problem... :P
Oh I think I know. I took a while without noticing anything wrong, but
now I remember having read about it in C++ FAQ Lite. theMap(Comp())
*declares a function* instead of instantiating an object. Good to know
all the time I wast^H^H^H^H spent reading that website was actually useful.
Okay, *after* remembering that and writing that paragraph, I went and
searched for what I remembered having read. Maybe that counts as
cheating... I wouldn't have searched if I had read question D before, so
I could try figuring out the solution myself :)
http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.2
The solution is:
std::map<A, int, Comp> theMap = Comp();
