POV-Ray : Newsgroups : povray.off-topic : Smart little programming tricks, where to find ? Server Time
29 Jun 2026 00:25:42 EDT (-0400)
  Smart little programming tricks, where to find ? (Message 2 to 11 of 51)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Smart little programming tricks, where to find ?
Date: 18 Mar 2008 06:03:58
Message: <47dfa19e@news.povray.org>
Fa3ien <fab### [at] yourshoesskynetbe> wrote:
>   0 == myvalue
> instead of
>   myvalue == 0
  I have always disliked that "trick" because it breaks the logical way
to "read" the line. Nobody says "if zero is equal to this value". The
common expression is "if this value is equal to zero".
  I have seen some people go further and extend that "trick" to things
like:
    0 < money
  This always confuses me. Again, nobody says "if zero is smaller than
the amount of money". That sentence would be quite confusing. Naturally
everyone says "if the amount of money is larger than zero".
Date: 18 Mar 2008 08:23:36
Message: <47dfc258@news.povray.org>
"Fa3ien" <fab### [at] yourshoesskynetbe> wrote
> I've read (in "joel on software") that, to avoid confusion between == and
> when you sometimes use languages that use = as assignments AND
comparisons,
> you can do some comparisons like this :
>   0 == myvalue
I think the best "trick" is to use a programming language which was designed
with at least some forethought, so that such tricks are unnecessary.
Date: 18 Mar 2008 10:44:24
Message: <47dfe358@news.povray.org>
  Such languages may lack necessary libraries, support or efficiency.
Date: 18 Mar 2008 10:47:27
Message: <47dfe40f$1@news.povray.org>
And that's the sad part. C is a horrid, horrid language, but it's where
all the libraries are. All the "good" languages I've seen have a
crippling lack of half-decent libraries... [And usually, rather limited
documentation and unpolished toolchains.]
http://blog.orphi.me.uk/
Date: 18 Mar 2008 10:49:09
Message: <47dfe475@news.povray.org>
  Btw, often people wonder why C++ is so popular, given that there are
so many "better" languages out there.
  IMO one very important factor for the popularity of C++ is the staggering
amount of libraries for it. Since almost all C libraries can be used in C++,
the amount of available libraries is simply enormous.
  This is, IMO, often one of the major killers for new languages: Lack of
libraries. The language may be the most perfect language in the world, but
if you don't have libraries to do what you want, it's almost useless.
Nobody wants to reinvent the wheel for every little thing that has been
already implemented to death by other people.
Date: 18 Mar 2008 13:06:05
Message: <47e0048d@news.povray.org>
I mostly agree.  When I seen that trick, I also thought that it was not
very "natural", being the reverse of "this equals that".
However, there are many areas were programming require some kind
of backwards-thinking or even worse, so that's quite benign.
All in all, I don't recommend the trick or even think I'm gonna
use it myself, it was mostly an example of a small trick that
implies a little thinking, and I was wondering if there were any
other small programming tricks of that kind.
Fabien.
Date: 18 Mar 2008 18:00:59
Message: <47e049ab@news.povray.org>
Heh.
To answer the original question, check out the book "programming pearls".
I do the (0 == X) and it seems quite natural after a time. (And I
occasionally get asked why I do such things in languages where
assignment and equality don't get mixed up, like Tcl. :-)
I also do the "never use the > sign" in comparisons. It's not a question
of how you read it out loud, but a question of putting the things in the
right order. For example:
   0 < A & A < B
If A is between zero and B.
   A < B | C < A
If A is outside the range B to C.
   if (start + 300 < now)
If now is at least 300 seconds past when we started.
Start putting in complicated timestamp calculations, and it becomes very
helpful. Always use < or <=, always add rather than subtract offsets,
and I almost never make a mistake and get the wrong things being compared.
It's kind of like drawing a picture, rather than writing a sentence.
IME, most programmers are more visual than auditory.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 18 Mar 2008 18:11:03
Message: <47e04c07@news.povray.org>
That's why I'm looking at Erlang. Decent language, good efficiency,
industrial-strength libraries.
Date: 19 Mar 2008 05:31:27
Message: <47e0eb7f@news.povray.org>
Darren New wrote:
>> where all the libraries are. All the "good" languages I've seen have a
I did look at Erlang. (Let's face it, other than Lisp, it's the only
remotely "popular" functional language. And Erikson is behind it, so
that's a pretty damn big vote of confidence in the soundness of the
technology.)
But alas, it's not purely functional, and the general style just seemed
untidy and complicated. It's just not my cup of tea...
Date: 19 Mar 2008 06:42:51
Message: <47e0fc3b$1@news.povray.org>
Warp wrote:
>     0 < money
Where that really comes into play is range statements:
if(10 < money && money < 100)
which can be read as "if money is between 10 and 100"
Someone I used to work with insisted that you use the same direction in
comparisons if you had more than 1 comparison. It seemed to make sense
when he used this example. The equivalent (and probably the way most
people are familiar with handling ranges) "money > 10 && money < 100"
isn't as quick to parse what you're looking for. Using that sort of
statement with a single comparison seems a bit ridiculous to me, though.
I have seen and used the [Constant|Literal] == [Variable] syntax before,
it's good for preventing assignment where you meant equality bugs. Of
course, the problem becomes obvious when you begin debugging seemingly
bizarre behavior. But, the objective is to prevent such behavior in the
first place.
My favorite syntactical bug was the following:
for(int i = 0; i < cItems; i++);
    ... Block of code ...
It's subtle, and if your for loops are any more complex than the above
trivial example, results in headaches. I spent an hour tracking
something similar down in my early days.
