POV-Ray : Newsgroups : povray.off-topic : Suggestions on motherboard Server Time
23 Dec 2025 21:44:37 EST (-0500)
  Suggestions on motherboard (Message 1 to 10 of 40)
Subject: Suggestions on motherboard
Date: 16 Mar 2008 06:00:00
Message: <47dcfdb0@news.povray.org>
I'm busy specing up a new PC. I'm having trouble picking a motherboard
though, any advice?
Processor = Intel Core-2 Quad, 2.66
The board must support at least 4 GB of DDR2 800 memory.
Must have at least 4 SATA-2 ports. No RAID requirements
Must have at least 6, preferably more, USB-2 ports
No need for onboard LAN, video or sound. I'm buying or have seperate cards
for those.
Thanks
Subject: Re: Suggestions on motherboard
Date: 16 Mar 2008 08:52:14
Message: <47dd260e$1@news.povray.org>
> though, any advice?
> for those.
> Thanks
Just bought a new machine based on a Gigabyte GA-P35-DS3 motherboard.
It meets or exceeds all of those requirements and was quite inexpensive.
Processors: Intel Core 2 Extreme, Quad, Duo, Pentium D, Pentium 4, Celeron
FSB: 1333/1066/800 MHz
Memory: 4 x DDR2 DIMM (up to 8Gb)
4 x SATA 3Gb/s
12 x USB 2.0 / 1.1 (8 back panel, rest internal or front panel depending
on case)
Also has on board 10/100/1000 LAN, Audio, RAID, legacy IDE etc and
plenty of overclocking support which I generally don't touch.
There are many variations on the gigabyte P35 range depending on how
many SATA connectors, Firewire, on board video etc you want.
While I can't say that Gigabyte is better or worse than any other brand
in this generation, I can say that the MB is very neat, feature rich and
(so far) without problem.  All of the benchmarks for P35 chipset based
systems seem to be equivalent to within the margin of error.
Overall I am very satisfied with the performance gain over an Athlon
1800XP machine that lasted me for about 5 years :)
Date: 16 Mar 2008 08:58:20
Message: <47dd277c$1@news.povray.org>
> for those.
I'm sure you know this, but make sure you have enough slots for these.
I had to ditch the modem when I installed a wifi card in my home machine
due to lack of pci slots.
(It didn't really matter anyway because the main reason for the wifi
card was that there's no phone line in the basement and I had to put my
DSL router in another room, so the modem was not going to be used for
anything anyway)
/*   sympatico.ca  */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 16 Mar 2008 12:41:36
Message: <47dd5bd0@news.povray.org>
"Francois Labreque" <fla### [at] sympaticoca> wrote in message
news:47dd277c$1@news.povray.org...
cards
> > for those.
I will check, but is just 3 slots. One PCI express (for graphics), 2 pci.
for sound and wifi
I haven't seen a motherboard with less than 2 pci slots yet.
Date: 16 Mar 2008 13:12:47
Message: <op.t74fjkbe7bxctx@e6600>
On Sun, 16 Mar 2008 18:42:07 +0100, Gail Shaw sa dot com>
> for sound and wifi
Be aware though that the layout of the board may prevent you from using
some slots, especially those closest to the graphics card.
FE
Date: 16 Mar 2008 13:19:30
Message: <47dd64b2$1@news.povray.org>
"Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com> wrote in message
news:op.t74fjkbe7bxctx@e6600...
>> for sound and wifi
     Yes, I've noticed this from what I've read so far, some of these new
boards are getting a bit too tight for a small or low tower.
        ~Steve~
> FE
Date: 16 Mar 2008 13:29:47
Message: <47dd671b@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:47dd64b2$1@news.povray.org...
I'm so sick of tearing my hands on the inside of a PC case. These days, I
don't buy anything other than a full tower case. Plus, since I usually have
2-3 hard drives and 2 DVD drives in a machine, I need a full tower to fit
them in without squashing the drives together.
Date: 16 Mar 2008 14:32:38
Message: <47dd75d6$1@news.povray.org>
"Gail Shaw" <initialsurname@sentech sa dot com> wrote in message
news:47dd671b@news.povray.org...
> have
      Well, my present tower is 16.5" high x 7" wide x 18" long, so I
'think' I could fit something new in it - not sure what a 'full' tower is
without checking, but with what you want Gail compared to my min spec board,
you may have to choose wisely with this one. It might be a good idea to
email said board merchants to get their opinion?
     And yes, I know what you mean by 'tearing your hands'. My first tower
was a tiny thing, (still got it sat next to me doing nothing), and when I
tried to put a new HD in it, I couldn't help scraping my hands! Back then I
wished that they built bigger towers, and now they're here.  :)
     ~Steve~
Date: 16 Mar 2008 15:07:23
Message: <op.t74kulee7bxctx@e6600>
On Sun, 16 Mar 2008 19:30:18 +0100, Gail Shaw sa dot com>
> have
I find that full tower cases tend to just give you a lot of empty space
where you do not need it, and force you to use longer cables. There are
some really good midi-tower cases by Antec that are very easy to work
with. Some think they are expensive, but they are well worth it.
FE
Date: 16 Mar 2008 15:41:45
Message: <47dd8609@news.povray.org>
I'll tell you something that *I* noticed...
I had a look on ebuyer, and almost *all* the motherboards had *exactly*
the same feature set until you start getting pretty expensive. I mean,
PCI slots, same number of SATA slots, etc. [Many of them lack IDE
entirely, which is potentially problematic...]
It's as if they all use the same chipset or something...
Once you get into the "really" expensive ones, a much wider variation is
apparent. Convergent evolution?
http://blog.orphi.me.uk/
