POV-Ray : Newsgroups : povray.off-topic : Using Excel as a 3D engine Server Time
17 May 2026 04:36:42 EDT (-0400)
  Using Excel as a 3D engine (Message 6 to 15 of 45)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Using Excel as a 3D engine
Date: 10 Mar 2008 11:26:11
Message: <47d56123$1@news.povray.org>
Invisible wrote:
> Now, just imagine if Excel would use Haskell instead of VB - you could
> use the same language for the cell formulas and the macros! :-D
Actually I'd say you can do that with VBA too. Just create a function
that passes the input to VBA translator.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 10 Mar 2008 11:36:09
Message: <47d56379@news.povray.org>
Right. And what non-trivial operations can you perform with a snippet of
VBA small enough to resonably fit into a single cell?
Yeah, exactly.
http://blog.orphi.me.uk/
Date: 10 Mar 2008 14:01:57
Message: <47d585a5@news.povray.org>
Depends on A) what you're doing and B) what functions for VBA you have
pre-made. Would the 1024 (oslt) char limit on Excel cell would be
seriously more usable with plain Haskell?
> Yeah, exactly.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 11 Mar 2008 04:20:48
Message: <47d64ef0$1@news.povray.org>
>> of VBA small enough to resonably fit into a single cell?
Well let's put it this way. If you wanted to calculate the geometric
mean (assuming there isn't already a function for that), in VBA you'd
have to write an explicit FOR loop (with initialisation, update, etc.),
whereas in Haskell you'd just keep a "map" call... It's a 1-liner.
Date: 11 Mar 2008 11:57:27
Message: <47d6b9f7$1@news.povray.org>
Meaning that you have pre-done function/call for it in Haskell (no, it
doesn't have to be self-made, it just is implemented earlier, usually
since someone has needed it).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 11 Mar 2008 14:15:50
Message: <47d6da66$1@news.povray.org>
>> etc.), whereas in Haskell you'd just keep a "map" call... It's a 1-liner.
The point being that it is *possible* to define the "map" function in
Haskell, whereas such a function cannot be defined in VBA. :-P
Date: 11 Mar 2008 14:53:16
Message: <47d6e32c$1@news.povray.org>
Invisible wrote:
> in VBA you'd have to write an explicit FOR loop
Not in Excel. What are you smoking? :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 11 Mar 2008 15:05:38
Message: <47d6e612$1@news.povray.org>
Umm.. I'm not getting this - why is it impossible to define in VBA?
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 11 Mar 2008 16:03:29
Message: <47d6f3a1$1@news.povray.org>
Because in VBA, you can't pass functions as arguments to functions.
Date: 11 Mar 2008 17:16:21
Message: <47d704b5$1@news.povray.org>
Oh, right. I bet there's *some* way to get the equivalent of function
pointers, but I don't know VBA well enough offhand...
Actually, you can. It just takes more work. You have to do it the way
you'd do in (say) java, and make a com object with the functionaltiy you
need. Perhaps overkill, yes.
