POV-Ray : Newsgroups : povray.off-topic : Using Excel as a 3D engine Server Time
17 May 2026 00:27:52 EDT (-0400)
  Using Excel as a 3D engine (Message 36 to 45 of 45)
Subject: Re: Using Excel as a 3D engine
Date: 12 Mar 2008 13:57:46
Message: <47d827aa$1@news.povray.org>
scott wrote:
> Get a book?
I think if I ever need to do this for real, that would be the only
viable option...
http://blog.orphi.me.uk/
Date: 12 Mar 2008 14:55:23
Message: <47d8352b@news.povray.org>
Gilles Tran wrote:
> I don't understand what you're saying... The entire Office suite uses VBA.
> Actually that's one big selling point of Office (for businesses): one can
> automate all the Office applications using the same language and have them
> interact with each other.
And that's a darn good thing. I've avoided tens or even hundreds of
hours of clicking around spreadsheets with VBA in past 5 years.
What comes for the missing pre-defined functions, I haven't found an
"explode" -function so far, so I did need to code one. It wasn't hard -
macro recorder and surfing the internet told me everything I needed.
> G.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 12 Mar 2008 22:14:20
Message: <47d89c0c$1@news.povray.org>
Invisible wrote:
>>> in VBA you'd have to write an explicit FOR loop
>> Not in Excel. What are you smoking? :-)
> Really? Care to explain that one?
Yeah. I don't need a loop to call SUM(A1:A10) either. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 12 Mar 2008 22:16:29
Message: <47d89c8d$1@news.povray.org>
Invisible wrote:
> And this stuff isn't really documented anywhere.
Are you familiar with msdn.microsoft.com, the complete documentation for
everything you program on Windows that comes from Microsoft?
Date: 13 Mar 2008 04:23:12
Message: <47d8f280$1@news.povray.org>
No. I'm aware it documents the really low-level Win32 API stuff that
only C programmers understand. I wasn't aware it contains anything
useful to normal people...
Date: 13 Mar 2008 06:20:29
Message: <op.t7ychevkc3xi7v@news.povray.org>
And lo on Wed, 12 Mar 2008 14:41:20 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>>  Rubbish!
>>  Try looking up "range" or "cells" or "worksheet" in the object brows
er
>> and reading the help.
> What is the "object browser"?
>> Worksheets(1).Cells(1, 1).Value = 24
>>  ActiveSheet.Cells(2, 1).Formula = "=Sum(B1:B5)"
>>  How could it be any more clear what to do?
> That seems reasonably clear.
or even MyValue = Worksheets("Results").Range("A1:D5").Value
> Now, if you call a macro with a cell range as its argument, how does
> that work?
Not sure what you mean, you can pass arguments on in the normal manner
i.e. Call Macro1(MyRange) from within another macro, or do you mean how
do
I pass what you've selected in the worksheet to the macro you're running
Which would be
ActiveWorksheet.ActiveCell or better ActiveWorksheet.Selection
so the date function could be
Sub InsertDate()
On Error Goto Handler
ActiveWorksheet.ActiveCell.Value = Format(Date, "Medium Date")
Exit Sub
Handler: MsgBox ("No cell selected")
End Sub
Depends on what you're exactly trying to do though, if you're trying to
ensure that everytime a sheet is accessed a date/time stamp is appended
to
a list on a sheet then
Sub AddStamp()
NoOfEntries = Worksheets("Date").UsedRange.Rows.Count
Worksheets("Date").Cells(NoOfEntries + 1, 1).Value = Format(Date, "Med
ium
Date")
End Sub
Just stick the word "Date" in A1 on the sheet "Date" then hide the sheet
then run it at startup from ThisWorkbook with
Private Sub Workbook_Open()
Call AddStamp()
End Sub
It also has the advantage that UsedRange counts every cell that *has* be
en
used, so if some sneaky soul just deletes the date (rather then the enti
re
row) it'll be left blank when the next stamp is placed.
>> Or, as Gilles said, record a macro and then look at the code (and the
>> help related to the code generated) - a nice trick for learning how t
o
>> do lots of things in Excel (like creating charts, changing borders,
>> sorting etc).
> I'm still at the level of not really knowing how to work the VB editor
> and not understanding basic VB syntax constructs...
Recording stuff and picking it apart really helps, just pick the command
and hit F1 for a meaning and example.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 13 Mar 2008 07:23:48
Message: <47d91cd4$1@news.povray.org>
>> that work?
> do I pass what you've selected in the worksheet to the macro you're
> running? Which would be
Actually I meant "how do I make it so I can write =MyMacro(A4:C9) in a
cell formula and have it actually work properly?"
Date: 13 Mar 2008 08:00:45
Message: <47d9257d$1@news.povray.org>
>>> that work?
>> how do I pass what you've selected in the worksheet to the macro
>> you're running? Which would be
Ah, so you want to convert your macro into a formula function? I would
look at the manual for you... but I uninstalled M$ Office a while ago :)
Date: 13 Mar 2008 08:03:29
Message: <op.t7yg83rac3xi7v@news.povray.org>
And lo on Thu, 13 Mar 2008 12:23:47 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>>> that work?
er
ow
 a
You can't with macros you need to use a function instead so add a module
to your worksheet and try
Public Function Temperature(Degrees As Double, ConvertType)
     If ConvertType = "C" Then
     Temperature = (Degrees - 32) * (5 / 9)
     Else
         If ConvertType = "F" Then
         Temperature = (Degrees / 5 / 9) + 32
         Else
         Temperature = CVErr(xlErrNA)
     End If
End Function
Now go to your worksheet and enter =Temperature(32, "C") and you'll ge
t a 0
Phil Cook
Date: 13 Mar 2008 13:10:21
Message: <47d96e0d$1@news.povray.org>
Right. So I picked a bad example. :-P
