POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
4 Jul 2026 02:40:11 EDT (-0400)
  Adventures with digital painting (Message 88 to 97 of 197)
Subject: Re: Adventures with digital painting
Date: 10 Mar 2008 08:00:18
Message: <47d530e2@news.povray.org>
Invisible <voi### [at] devnull> wrote:
> Ah yes, but in Unix land, a device driver is counted as part of the
> kernel. ;-)
  There are many pros in monolithic kernels. Of course there are cons,
but many people believe that the pros outweight the cons in this case.
Date: 10 Mar 2008 08:03:16
Message: <47d53194@news.povray.org>
> Also: autoconf exists. Need I say more?
  Autoconf exists because not all systems have the same tools or libraries
installed, nor all systems have the same versions of those tools/libraries.
  Autoconf also exists because computer architectures are different.
For instance, some architectures may be little-endian while others are
big-endian. Some architectures may be 32-bit while others are 64-bit.
  Portability is a key feature of unix-like systems.
Date: 10 Mar 2008 08:05:54
Message: <47d53232$1@news.povray.org>
When trying to compile POV-Ray for the iPod touch, I had trouble with
two libraries. JPEG, which used a very old version of autoconf, and
TIFF, which used a half-assed written-by-hand configure script.
Date: 10 Mar 2008 08:06:54
Message: <47d5326e$1@news.povray.org>
> In what universe is this a "simple tool" with "well defined inputs and
> outputs"?
ls is a good example of a program that *doesn't* have well-defined
outputs, in the sense that scripts should never rely on parsing ls
output. ls is supposed to have *human-readable* output.
Date: 10 Mar 2008 08:13:11
Message: <47d533e7$1@news.povray.org>
>> kernel. ;-)
I just prefer being able to add new drivers without having to recompile
the kernel and reboot the machine - but that's just me...
OOC, what are the benefits?
http://blog.orphi.me.uk/
Date: 10 Mar 2008 08:18:24
Message: <47d53520$1@news.povray.org>
As far as I can tell, autoconf exists because some systems use BSD awk
and others use GNU awk, and the two aren't precisely compatible.
Multiply this by the 50,000 other tiny utilities you may or may not need
to set up this program and you have a configuration nightmare so bad it
requires an automated tool to make things remotely tractable.
And it seems to me that most of this has happened because the entire
system has been poked and prodded by so many different people over time
that you now have a huge tangled mass of different implementations all
of which are only semi-compatible.
Shouldn't the compiler be dealing with those issues?
That I don't have a problem with... ;-)
Date: 10 Mar 2008 08:40:35
Message: <47d53a53$1@news.povray.org>
No. If the compiler "dealt" with little endian and big endian, by making
the C code always see one or the other, it would make the other
architecture much slower.
Also, the C standard only mentions minimum sizes for data types. A
compliant C implementation may have 64-bit bytes if it wants to.
Date: 10 Mar 2008 08:47:37
Message: <47d53bf9$1@news.povray.org>
What I meant was, shouldn't the programmer be able to just write their
program, and let the compiler generate the correct code depending on the
actual processor architecture?
But then, since C is little more than semi-portable machine code, I
guess that would be quite hard to do.
IOW, the C standard is insane. ;-)
Date: 10 Mar 2008 08:53:13
Message: <47d53d49$1@news.povray.org>
>> making the C code always see one or the other, it would make the other
Of course there is a lot of code that can be written without caring
about endianness. In which case you wouldn't tell autoconf to do that check.
Date: 10 Mar 2008 08:54:23
Message: <47d53d8f@news.povray.org>
  I have never had to recompile the kernel or reboot the machine because
of requiring a new driver.
  man modprobe
  For example, the interfaces and protocols between the kernel and the
drivers can be modified easily without having to worry about backwards
compatibility. If an existing interface or protocol results to be a bad
design choice, or it results to have some inefficiencies in a newer
architecture, they can all be changed without problems. Basically, the
kernel is not burdened with backwards compatibility issues with regard
to drivers.
