POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
1 Jun 2026 02:07:25 EDT (-0400)
  Adventures with digital painting (Message 61 to 70 of 197)
Subject: Re: Adventures with digital painting
Date: 8 Mar 2008 17:12:54
Message: <47d30f66@news.povray.org>
Chambers wrote:
> So what you're really saying, is that we need a modern implementation of
> traditional Unix style tools, distributed as a package.  It wouldn't
> need a ton of that backwards-compatibility stuff, because all of the
> included tools are fresh implementations that we know work together.
What I'm saying is that "Unix" isn't a single coherant design. It's
50,000 random people all doing their own seperate thing, and expecting
the result to actually function. Which, almost unbelievably, it does.
But *damn* is it messy...
http://blog.orphi.me.uk/
Date: 8 Mar 2008 17:24:10
Message: <47d3120a@news.povray.org>
  I really fail to see how that is at all different from Windows. ;)
Date: 8 Mar 2008 17:25:43
Message: <47d31267$1@news.povray.org>
On Sat, 08 Mar 2008 10:46:57 -0800, Chambers wrote:
> Nicolas Alvarez wrote:
>> Tim Cook escribió:
>>> Heck, I use version 7...even 8 was too bloatware for my taste.
>> http://stuff.povaddict.com.ar/psp5.png
>> I tried 8 or 9 and I was impressed at the amount of bloat.
> I love the Unix philosophy of making specific, lightweight tools that
> interoperate, rather than gargantuan monolithic beasts that do
> everything rather poorly.
Ditto.  When I do data manipulation now in oocalc, I often parse the data
first by piping it through a series of awk scripts and grep filters to
get the data I'm interested in, *then* import it.
Makes it easier to aggregate the stuff I look at.
Jim
Date: 8 Mar 2008 17:26:45
Message: <47d312a5$1@news.povray.org>
On Sat, 08 Mar 2008 19:16:28 +0000, Orchid XP v7 wrote:
> ["This makes it read from a file. Unless the file is named '-', in which
> case it reads from stdin." OK, so how do I make it read from a file
> that's actually named '-' then? And other surprising ad-hoc
> behaviours...]
(a) you don't name a file '-' because it's got a special meaning to the
shell, or
(b) you escape the filename.
Jim
Date: 8 Mar 2008 17:29:11
Message: <47d31337@news.povray.org>
On Sat, 08 Mar 2008 11:54:07 -0800, Darren New wrote:
> Here's a contest. Given the directory /tmp/stuff, delete all the files
> in that directory that end with ".tmp".
cd /tmp/stuff; find -type f | grep tmp$ | awk '{system("rm \"" $0 "\""))'
Jim
Date: 8 Mar 2008 17:44:45
Message: <47d316dc@news.povray.org>
  Why does it need to be so complicated?
  find /tmp/stuff -name "*.tmp" -exec rm {} \;
Date: 8 Mar 2008 17:51:02
Message: <47d31856$1@news.povray.org>
Great. Now try it on a directory with the following names in it:
-rf\n.tmp  (where the \n means newline, of course)
<.tmp
.xyz.tmp
hip"hop.tmp
hop'hip.tmp
this.tmp;that.tmp
this\bthat.tmp   (where the \b means bell)
this\bthat.tmp   (where the \b is two characters, backslash and b)
Two for zero... ;-)
Altho I expect 'find . -name '*.tmp' -exec rm {} \;" might work, but
only because you know the name ends in '.tmp'.  You might be able to
manage '-exec rm ./{}' and make it work too. I haven't tested that. I do
know it'll be an order of magnitude slower due to all the invocations of
/bin/rm.
For a real fun time, try "delete all the files in the directory without
deleting the directory".  Or "copy them to the /tmp/keep" directory
(which, as far as I can tell, xargs doesn't help with.)
(I work with big directories, and big files. Often I'll have a program
that runs 3 hours, then takes half an hour to delete its input files. Or
individual files that take 2 minutes of disk I/O to delete. Or empty
directories that take several minutes to delete because they used to
have six or seven million files in em.  And of course, the machine
becomes completely unusable during any sort of operation like that.)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 8 Mar 2008 18:46:26
Message: <47d32552$1@news.povray.org>
>   It *does* work, assuming you have a sufficiently modern shell (and not
> a 20 years old sh). Modern shells are rather smart at escaping what needs
> to be escaped when you write "*".
In other words, if you completely bypass the shell, it can be made easy
to work. Otherwise you get things like "no such user John.tmp" when you
try to delete "~John.tmp".  And if you want to delete all the files in
the directory, you have to add more escaping. And if you want to scp
them to a different server, you really don't want to be typing the
password for each one, so you either have to use xargs (with the -0
switch, which is why that's there!) or manage to tar them up somehow,
which has the same problems.
Anyway, my point was that it's kind of unobvious to get right, not that
it couldn't be done.  I generally just break out Tcl for such a task
(since Tcl doesn't reparse things repeatedly without you asking
explicitly), as it's easier than trying to come up with the right list
of flags to the various programs.
Yet every time I mention the kinds of problems it causes, the UNIX
dweebs *I* know will fight to the death their need to be able to put
backspaces and vertical tab characters into file names. You might as
well try to convince a FORTH programmer that it isn't necessary to have
the ability to start the name of a function with a closing parenthesis.
</rant>   :-)
Having the shell doing your expansion has caught me other times, too...
% cat a b c >d
Can't create d: permission denied
% sudo !!
Of course, the real line was much longer, so a simple "su" meant
retyping the line (or using copy-and-paste to retype it for you) instead
of just !! or up-arrow. :-)
However, I'm glad Windows finally forced people writing Unix shells to
start dealing with funky file names as a regular occurrence. ;-) I
noticed that the shells started learning to do proper quoting (like for
command-line completion) right around the time SAMBA shares with
MSWindows servers got popular. :-)
Date: 8 Mar 2008 19:04:18
Message: <47d32982@news.povray.org>
  Only if you write "~John.tmp" by hand instead of letting the shell do
the proper expansion.
  Well, if "rm *" works (ie. there aren't too many files), you don't.
If there are too many files, I suppose you'll have to use the 'find'
trick.
  If you do a "scp *" it won't ask the password for each one.
  What's the problem with tarring them? "tar -cvf . files.tar"
  Granted, the only problem I have seen so far is when there are way
too many files in the directory, in which case "*" expand to too many.
However, I haven't seen any problems with special characters so far.
  The only valid point you have presented is the too-many-files argument,
which can be a real problem for the * expansion. So far I haven't seen
any real problem with special characters.
> % cat a b c >d
> % sudo !!
  What's wrong with getting the command from the command history with
the up cursor, going to the beginning of the line with ctrl-a and then
adding the "sudo" there?
  Still many shell scripts fail to use the basic "$@" for the correct
expansion of all the parameters (and instead use $*, which is wrong).
Not all unix geeks know all the right tools either.
Date: 8 Mar 2008 19:14:37
Message: <47d32bed@news.povray.org>
  Isn't that a clear sign that a re-design of your programs is in place?-)
