POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
1 Jun 2026 03:20:53 EDT (-0400)
  Adventures with digital painting (Message 51 to 60 of 197)
Subject: Re: Adventures with digital painting
Date: 8 Mar 2008 14:20:57
Message: <47d2e719$1@news.povray.org>
Nicolas Alvarez wrote:
>> ["This makes it read from a file. Unless the file is named '-', in
>> which case it reads from stdin." OK, so how do I make it read from a
>> file that's actually named '-' then? And other surprising ad-hoc
>> behaviours...]
OK. But it now means that if you write a script that does this, you need
to explicitly check whether the file you're going to process just
happens to be called "-" and manually escape it if it is. And just
think, if you didn't realise that, your script might be used for *years*
before somebody tries to use it in that specific way and makes it crash
spectacularly.
Urg. Anyways...
http://blog.orphi.me.uk/
Date: 8 Mar 2008 14:24:42
Message: <47d2e7fa$1@news.povray.org>
>>> behaviours...]
> spectacularly.
1. If the file is called -, you're calling for trouble anyway.
2. Whoever passes a filename to your script should be using the ./- thing.
Date: 8 Mar 2008 14:29:58
Message: <47d2e936@news.povray.org>
Orchid XP v7 <voi### [at] devnull> wrote:
> > I love the Unix philosophy of making specific, lightweight tools that
> > interoperate, rather than gargantuan monolithic beasts that do
> > everything rather poorly.
> See, now, personally I hate that. It annoys the hell out of me that the
> Unix way is to use 50,000 tiny tools with all have far too many
> backwards compatibility modes, bugs and "features".
  He was talking about the unix philosophy, not how this philosophy has
been implemented in some environments.
Date: 8 Mar 2008 14:50:20
Message: <47d2edfb@news.povray.org>
  Many shellscripts break with file names with spaces in them. This is
because surprisingly few unix geeks know that in shell scripts you have
to use "$@" to refer to all the command-line arguments, not $*.
Date: 8 Mar 2008 14:54:06
Message: <47d2eede$1@news.povray.org>
Actually, it's worse. There are surprisingly few utilities that don't
break on *any* possible file name.
Here's a contest. Given the directory /tmp/stuff, delete all the files
in that directory that end with ".tmp".
Let's see how many iterations it takes to get actually right.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 8 Mar 2008 14:59:54
Message: <47d2f03a@news.povray.org>
Then I guess rm /tmp/stuff/*.tmp isn't good enough? :)
Date: 8 Mar 2008 15:10:42
Message: <47d2f2c2$1@news.povray.org>
That doesn't even work if there *aren't* funky characters in the file name.
Date: 8 Mar 2008 15:19:15
Message: <47d2f4c2@news.povray.org>
  It *does* work, assuming you have a sufficiently modern shell (and not
a 20 years old sh). Modern shells are rather smart at escaping what needs
to be escaped when you write "*".
Date: 8 Mar 2008 15:32:33
Message: <47d2f7e1$1@news.povray.org>
Bull. Put 300,000 files to be deleted in /tmp/stuff, and watch it bomb.
Date: 8 Mar 2008 16:29:54
Message: <47d30552$1@news.povray.org>
So what you're really saying, is that we need a modern implementation of
traditional Unix style tools, distributed as a package.  It wouldn't
need a ton of that backwards-compatibility stuff, because all of the
included tools are fresh implementations that we know work together.
...Ben Chambers
www.pacificwebguy.com
