POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
31 May 2026 22:16:14 EDT (-0400)
  Adventures with digital painting (Message 151 to 160 of 197)
Subject: Re: Adventures with digital painting
Date: 12 Mar 2008 14:00:30
Message: <47d8284e$1@news.povray.org>
Mike Raiford wrote:
> Nicolas Alvarez wrote:
>> And also one reason why command-line tools are better for many things.
>> (image editing probably not one of them)
> Funny, there's a set of commandline tools for just that called
> ImageMagick. :D
Image "editing"? Or simple image transformation operations?
http://blog.orphi.me.uk/
Date: 12 Mar 2008 14:01:59
Message: <47d828a7@news.povray.org>
>> Cool. I just hope your filenames don't contain any of the characters
>> that Tcl considers to be "special" either. :-P
> Well, I use C, and it deals with literal strings, but I suspect TCL is
> the same in that regard.
Tcl encodes all data types as strings. I've been bitten by this
before... You write a Tcl script, it works fine, and then it encounters
some input that happens to contain a curly-bracket or a dollar sign and
Weird Crap happens...
[I'm sure there's a way to avoid this. It's just tricky, and it makes me
nervous.]
Date: 12 Mar 2008 14:36:23
Message: <47d830b7$1@news.povray.org>
> ImageMagick. :D
Well yeah. But you can't do as much as you can in photoshop.
Can you make a good-looking POV-Ray scene *without ever looking at the
result*? :)
Date: 12 Mar 2008 18:58:17
Message: <47d86e19$1@news.povray.org>
That's one of the potential pitfalls with most scripting languages.
Jim
Date: 12 Mar 2008 22:05:24
Message: <47d899f4$1@news.povray.org>
Eero Ahonen wrote:
> Well ok, after that you wrote about chopping the file, which practically
> is what split does, but it should be able to work without creating
> millions of (temp)files in the middle of the process.
The problem is the size of the file. If I split it after the fact, I now
have *two* files, the original and the new one. So now instead of half
an hour of deleting directory entries, I have three hours of copying
data, followed by five minutes of deleting one directory entry.
Split doesn't split a file. It writes new files, each of which contain
pieces of the previous file.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 12 Mar 2008 22:06:11
Message: <47d89a23$1@news.povray.org>
I have, on occasion, got caught by a file whose name starts with ~. But
none of the other characters are special in Tcl file names. In
particular, spaces and brackets and such just don't come into play.
Date: 12 Mar 2008 22:07:52
Message: <47d89a88$1@news.povray.org>
Only if you don't treat your lists as lists and your strings as strings.
Otherwise, the rules are extremely straightforward.
> nervous.]
I never get bitten by this. The only time this happens is when you pass
a string to something that indexes into a list, without first splitting
the string into lists appropriately.
Date: 12 Mar 2008 22:09:00
Message: <47d89acc$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> outint'endian = little;
>   Exactly which language is this?
Ada.  I am pretty sure it supports this.
> And have you actually corroborated by
> examining the resulting machine code that it indeed does as you say?
No. Never needed to. It's not the sort of thing you leave out of a
language you're programming flight control software in.
Date: 12 Mar 2008 22:44:29
Message: <47d8a31d$1@news.povray.org>
It turns out the syntax is
(The ' indicates a compile-time value, in much the same sense that
sizeof() is a compile-time function in C. Ada lets you read dozens of
these and set others, like the address, volitility, atomicity, etc.)
It also turns out it's not *quite* so straightforward especially for .
But clearly it's better to let the compiler do it in cases where it can
than to code different routines with #ifdef in there.  Autoconf doesn't
make C portable - it rewrites your code to be non-portable to that
specific machine. :-)
Date: 13 Mar 2008 04:27:07
Message: <47d8f36b@news.povray.org>
>> encounters some input that happens to contain a curly-bracket or a
>> dollar sign and Weird Crap happens...
>> me nervous.]
I'm pretty sure I remember several occasions where if a certain
expression happened to return only 1 item, it tried to interpret the
item as a list. IOW, when the expression finds multiple matches,
everything works fine, but when it finds exactly 1 match it malfunctions
horribly. Took me ages to figure out why...
