POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
11 Jun 2026 22:03:52 EDT (-0400)
  Adventures with digital painting (Message 141 to 150 of 197)
Subject: Re: Adventures with digital painting
Date: 11 Mar 2008 15:55:36
Message: <47d6f1c8$1@news.povray.org>
Darren New wrote:
> I already have millions of files. That's the problem. :-)
Well yes, now, but possibly in the future? :)
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 11 Mar 2008 17:14:38
Message: <47d7044e@news.povray.org>
I am saying that I fail to see how split would *reduce* the number of
files I have, considering its functionality.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 11 Mar 2008 17:22:25
Message: <47d70621@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> The only way I can see it being slower is there's actually two different
> sets of code, based on what order things are in, such that (for example)
> one branch adds two numbers using "+" and the other does some magic to
> add 0xA000 and 0xA000 to get 0x4001 automatically without actually
> treating them as binary integers. Is that what you're referring to?
  If I remember correctly, what mplayer does (well, some of its video
filters, actually) is to build 4-byte pixels into words and then it
writes those pixels on a per-word basis to some output buffer. Naturally
the endianess of the architecture determines if the R channel goes to
the lower byte or the upper byte of the word.
  If endianess is not taken into account, in architectures with the other
endianess the color channels will be effectively swapped. (I know this
from actual experience.)
  Naturally it could write the bytes themselves, ie. on a per-channel
basis instead of a per-pixel basis, but those would be 4 writes instead
of 1. Another possibility would be to build the word always in the same
way and have the "compiler reverse it in architectures with the other
endianess" (if that's even possible in any compiler of any language),
but that would mean a bunch of extra steps in that other endianess
architecture, for no good reason.
Date: 11 Mar 2008 17:46:43
Message: <47d70bd3$1@news.povray.org>
On Tue, 11 Mar 2008 13:45:25 -0700, Darren New wrote:
> Jim Henderson wrote:
>> Our software testers used the trick you describe to make programs work
>> together that had this type of conflict.
> I wouldn't call it a *trick* as such. It's a part of the design in the
> OS to support exactly the situation you had. :-)
Well, you know what I mean - the standard installer wasn't smart enough
to leverage this "feature" of the OS so the conflict didn't happen.
Jim
Date: 11 Mar 2008 22:02:13
Message: <47d747b5$1@news.povray.org>
No, you'd declare a four-byte integer in native endianness, and a
four-byte word in the buffer in little (or big) endianness, and have the
compiler either generate code to directly copy (if the native
architecture's endianness matches the spec's endienness) or have it
generate the optimal machine code sequence to do the swap if they don't
match.
The "build four-byte pixels into words" works just fine too.
(I forget the exact syntax, but it's something like)
outint : new integer 0..2^32-1;
outint'endian = little;
buffer : array [0..N] of outint;
buffer[i] = r * 256*256*256 + g * 256 * 256 + b * 256 + a;
If outint is in native form, it does the shifts and stores it, or
assigns the bytes, or whatever the compiler can come up with.
If outint is in byte-swapped order, the compiler can *also* deduce it
needs to do the shifts differently, and just assign bytes to the
appropriate places in the word.
(Note that compilers aren't dumb enough to actually multiply when you
say r * 256 * 256 * 256.)
Makes it much clearer code, methinks, and no ifdefs.
Date: 12 Mar 2008 00:01:14
Message: <47d7639a$1@news.povray.org>
Composing with some of those 49,999 other tools it gives you the
possibility of eg. removing a part (beginning, ending or from the
middle) of a file.
"Now, if Linux supported the thing that NTFS supports where you can
delete the beginning of a file, maybe I'd use that."
Well ok, after that you wrote about chopping the file, which practically
is what split does, but it should be able to work without creating
millions of (temp)files in the middle of the process.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 12 Mar 2008 04:15:43
Message: <47d79f3f$1@news.povray.org>
>>> But if I wanted it to work all the time, I'd write it in C and be done
>>> with it - then the shell doesn't come into play. :-)
>> Yah, as I said, when it gets messy, I use Tcl. :-)
> Really the best option - remove the shell. :-)
Cool. I just hope your filenames don't contain any of the characters
that Tcl considers to be "special" either. :-P
http://blog.orphi.me.uk/
Date: 12 Mar 2008 04:34:42
Message: <47d7a3b2@news.povray.org>
  Exactly which language is this? And have you actually corroborated by
examining the resulting machine code that it indeed does as you say?
Date: 12 Mar 2008 13:27:31
Message: <47d82093$1@news.povray.org>
>>>> done with it - then the shell doesn't come into play. :-)
Well, I use C, and it deals with literal strings, but I suspect TCL is
the same in that regard.
Jim
Date: 12 Mar 2008 13:56:20
Message: <47d82754$1@news.povray.org>
Nicolas Alvarez wrote:
> And also one reason why command-line tools are better for many things.
> (image editing probably not one of them)
Funny, there's a set of commandline tools for just that called
ImageMagick. :D
