POV-Ray : Newsgroups : povray.off-topic : Question for SQLers out there Server Time
16 May 2026 22:57:37 EDT (-0400)
  Question for SQLers out there (Message 1 to 10 of 27)
Subject: Question for SQLers out there
Date: 12 Feb 2008 08:52:18
Message: <47b1a492$1@news.povray.org>
OK, I've heard a lot about inner joins and outer joins but don't really
know them or how to use them.
I've actually been using SQL for 10 years now, but never managed to
completely figure this out.
Lets say I have (2) tables - (2) column each
Person				Limbs
Index	Name			PersonIndex	Type
Now, I would normally write a SQL statement like this:
select L.Type from Person P, Limbs L where L.PersonIndex = P.Index and
P.Name = 'Bones'
This *works*, but somehow I feel that this is where the JOIN should come in.
Should a JOIN be used here?
Does it matter?
Thanky..... Tom
Subject: Re: Question for SQLers out there
Date: 12 Feb 2008 09:32:52
Message: <47b1ae14$1@news.povray.org>
47b1a492$1@news.povray.org...
> Person Limbs
I'd do it a little differently ;)
Table:Persons
Person_code
Person_name
Table:Limbs
Limb_code
Limb_type
Table:Person_limbs
Person_code
Limb_code
The Person_limbs table make it possible to give a person a variable list of
limb types.
Now you want to list the names of persons who have limbs of the type "legs"
SELECT Person.Person_name
FROM (Limbs INNER JOIN Person_limbs ON Limbs.Limb_code =
Person_limbs.Limb_code) INNER JOIN Person ON Person_limbs.Person_code =
Person.Person_code
WHERE (((Limbs.Limb_name)="legs"));
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer images
- Posters
Date: 12 Feb 2008 09:40:00
Message: <web.47b1af39e388923da8d0b25a0@news.povray.org>
> Person    Limbs
> P.Name = 'Bones'
> Does it matter?
> Thanky..... Tom
Inner Join equivalent:
SELECT  L.TYPE
FROM    PERSON P INNER JOIN LIMBS L ON
             P.INDEX = L.PERSONINDEX
WHERE   P.NAME = 'Bones'
Your example would be fine, although supposedly M$ frowns on that and is trying
to steer people away from it.
An Inner Join will only pull where there's a match in both tables.
The left outer join pulls all the records on the left side of the join and any
matching records from the right side table, or NULL if no matches are made.  A
right outer join works in the opposite direction (but I've never used it, so I
don't know for sure).
This is an outer join example:
SELECT  P.NAME, L.TYPE
FROM    PERSON P LEFT OUTER JOIN LIMBS L ON
Here, I want to pull all the P.NAMES from PERSON, regardless if they have limbs
or not.
Hopethishelps...
Dan
GoofyGraffix.com
Date: 12 Feb 2008 09:55:14
Message: <47b1b352$1@news.povray.org>
isn't the join syntax ANSI SQL? I thought the simpler syntax was
actually a feature of Transact SQL, (Though I think other RDBMS engines
use it, too...)
Date: 12 Feb 2008 10:00:36
Message: <47b1b494@news.povray.org>
>> is trying
> use it, too...)
I think what Dan meant is that Tom's original example is frowned upon,
and people should use JOINs instead.
Date: 12 Feb 2008 10:03:39
Message: <47b1b54b@news.povray.org>
Nicolas Alvarez wrote:
>>> is trying
>> engines use it, too...)
But, frowned upon in the general sense?
Date: 12 Feb 2008 10:25:00
Message: <web.47b1b9a1e388923da8d0b25a0@news.povray.org>
> >>> is trying
Actually, it's frowned upon where outer joins are concerned.  This is from the
online manual (SQL Server 2000 - I haven't checked SQL Server 2005 yet):
"The rows selected by a query are filtered first by the FROM clause join
conditions, then the WHERE clause search conditions, and then the HAVING clause
search conditions. Inner joins can be specified in either the FROM or WHERE
clause without affecting the final result.
Outer join conditions, however, may interact differently with the WHERE clause
search conditions, depending on whether the join conditions are in the FROM or
WHERE clause. Therefore, the ability to specify Transact-SQL outer joins in the
WHERE clause is not recommended, is no longer documented, and will be dropped in
a future release."
What this translates to is the following code produces vastly different results:
             AND P.NAME = 'Bones'
The first example pulls everyone in PERSON and any limbs they have, provided the
P.NAME = 'Bones'.  If there are no matches, L.TYPE will be null.  Exactly how
it's supposed to work.  In example number 2, the WHERE clause acts like a
global filter, so it will throw out any record that doesn't equal 'Bones' in
the P.NAME field, therefore acting like an INNER JOIN.
Dan
GoofyGraffix.com
Date: 12 Feb 2008 11:03:23
Message: <47b1c34b@news.povray.org>
"Dan Byers" <goofygraffix_at_geemail_dot_com> wrote in message
news:web.47b1b9a1e388923da8d0b25a0@news.povray.org...
the
The older outer join syntax doesn't work at all in SQL 2005. Dunno about the
other DB engines.
(Does Oracle know what a join is yet?) <g>
This works in SQL 2005
SELECT tbl1.Col1, tbl2.col2 from tbl1 LEFT OUTER JOIN tbl2 on tbl1.Col1 =
tbl2.Col1
This doesn't
SELECT tbl1.Col1, tbl2.col2 from tbl1, tbl2 WHERE tbl1.Col1 *= tbl2.Col1
Date: 12 Feb 2008 11:07:33
Message: <47b1c445@news.povray.org>
> other DB engines.
I should probably poke you for that. :-P
Considering that I was playing with the different join types in an old
version of Oracle 6 years ago when I was still at uni, I think we can
safely say it knows about joins...
http://blog.orphi.me.uk/
Date: 12 Feb 2008 11:25:26
Message: <47b1c876$1@news.povray.org>
Gail Shaw wrote:
> This doesn't
Thank goodness they dropped the *= and =* operators.
