POV-Ray : Newsgroups : povray.off-topic : And today, C# Server Time
1 Jul 2026 08:07:51 EDT (-0400)
  And today, C# (Message 41 to 50 of 82)
Subject: Re: And today, C#
Date: 13 Feb 2008 06:03:16
Message: <47b2ce74$1@news.povray.org>
Warp wrote:
> Orchid XP v7 <voi### [at] devnull> wrote:
>> Me, I dislike anything that says "Lisp" in it. :-S
>   Says the person who is infatuated with functional languages such as
> Haskell...
Aren't you that guy who loves C++ but hates C? ;-)
http://blog.orphi.me.uk/
Date: 13 Feb 2008 06:13:04
Message: <47b2d0c0@news.povray.org>
> > Haskell...
  C isn't object-oriented.
Date: 13 Feb 2008 06:15:35
Message: <47b2d157$1@news.povray.org>
>>> Haskell...
True. But C and C++ are vastly more closely related than Haskell and Lisp.
[And if you wanted to split hairs, Haskell is a pure-functional
language, while Lisp isn't.]
Date: 13 Feb 2008 06:17:15
Message: <47b2d1bb@news.povray.org>
  A pure-functional language which has things like indexable arrays and
assignment? Hardly.
Date: 13 Feb 2008 06:20:45
Message: <47b2d28d@news.povray.org>
> assignment? Hardly.
Really? And indexable arrays are impure because...?
Similarly, all side-effecting operations are implemented using
referentially-transparent monadic constructs. In Lisp, if you want a
side-effect, you just do it. That's the difference.
Date: 13 Feb 2008 07:09:19
Message: <47b2ddef@news.povray.org>
> > assignment? Hardly.
  Because it's not a feature of the functional programming paradigm,
but the imperative programming paradigm.
  Purely functional languages are mostly impractical.
Date: 13 Feb 2008 07:11:47
Message: <47b2de83$1@news.povray.org>
Tell me Warp, do you actually understand what "functional programming"
means?
You seem to think it means "programming with lists", which isn't correct.
Date: 13 Feb 2008 08:47:36
Message: <47b2f4f7@news.povray.org>
> means?
  A purely functional programming language doesn't have side-effects.
If I'm not mistaken, for example assignment produces a side-effect.
Even I/O causes side-effects.
  Thus a purely functional language is mostly impractical. Quoting
wikipedia:
"Purely functional programs have no side effects. This makes it easier
to reason about their behavior. However, almost no programmers bother
to write purely functional programs, since, by definition, a program
with no side effects (one that accepts no input, produces no output,
and interfaces with no external devices ) is formally equivalent to a
program that does nothing; typically, purity is used to enforce a
separation of concerns where one clearly-delineated section of the
program does impure operations like I/O, and calls pure functions and
libraries as needed to compute answers."
Date: 13 Feb 2008 08:58:15
Message: <47b2f777$1@news.povray.org>
> wikipedia:
Quoting wikipedia is not always that useful:  that section is most
likely vandalism by some angry COBOL programmer.
Surely separation of concerns is good as is reducing side-effects to a
minimum.  To say a purely functional program is incapable of accepting
input or generating output is not correct:  if anything, a purely
functional program is able to, in shared memory, take a list as input
and generate a list as output.  An outside program can write the input
list in memory, call the pure program on it and read its output and
write to file.  That's, AFAIK, is what was done in the old days of
Haskell:  delayed list IO.
More practically, functional language compilers and runtimes carry out
the ugly side-effect bits while the purely functional programs do their
stuff and get written as if acting on purely side-effect free
datastructures.  That's monadic IO today.
Date: 13 Feb 2008 09:08:17
Message: <47b2f9d1$1@news.povray.org>
>> means?
Indeed.
Assignment and I/O are both side-effects. Accessing an indexed array
does not. There is absolutely no reason why a pure functional language
cannot have arrays.
Depends on your definition of "practical".
> Quoting wikipedia:
> with no side effects is formally equivalent to a program that
> does nothing."
Indeed, a program with absolutely no side effects at all is rather
pointless. (!) There are several approaches to this apparent problem.
One approach is to *allow* side-effects, but say "hey, don't use this
unless you have to". This is the Lisp approach. (And Erlang. And a few
others.)
The Haskell approach is different. A Haskell "program" just returns a
list of instructions to the Haskell runtime, and the Haskell runtime
actually "does" the instructions on the program's behalf.
Why is that different? Well, it means that the entire program remains
referentially transparent. And *that* is the defining characteristic of
functional programs.
In Haskell, *every* expression can be replaced by the value it returns
without altering the result of the program. [Indeed, this is notionally
how you execute a Haskell program.] The same statement does *not* apply
to Lisp. Hence, Haskell is pure, and Lisp is not. QED.
Note that you *could* write referentially transparent code in just about
any programming language, if you wanted to. It's just that in Haskell
you can't write code that isn't. ;-)
