POV-Ray : Newsgroups : povray.off-topic : Strange PC behaviour Server Time
9 Jun 2026 08:02:56 EDT (-0400)
  Strange PC behaviour (Message 31 to 40 of 40)
Subject: Re: Strange PC behaviour
Date: 12 Feb 2008 03:11:10
Message: <op.t6ejovx27bxctx@e6600.bredbandsbolaget.se>
On Tue, 12 Feb 2008 07:58:14 +0100, Nekar Xenos <nek### [at] gmailcom>
wrote:
> The powersocket on my motherboard only has 20 pins. The new ones have 24
> pins so I'll have to see if I can get a 20pin powersupply.
The extra 4 pins are generally detachable for backwards compatibility.
> From everything I've gathered here it seems it was the power supply that
> damaged my motherboard.
Not necessarily. Some capacitors just go bad from age.
FE
Date: 12 Feb 2008 03:39:42
Message: <4mm2r3hlgef1gg9m8rhnilv8g0nil51jg9@4ax.com>
On Tue, 12 Feb 2008 08:51:41 +0200, "Nekar Xenos" <nek### [at] gmailcom> wrote:
>They are normal sized. maybe I should get a soldering iron...
And a solder sucker. Plastic tweezers from a medical pack are useful too.
Regards
Date: 12 Feb 2008 10:32:50
Message: <47b1bc22@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> wrote in message
news:47b141fc@news.povray.org...
Is worth a try. You do stand a chance of damaging the motherboard though, so
be careful.
Date: 12 Feb 2008 10:33:56
Message: <47b1bc64@news.povray.org>
news:47b14382@news.povray.org...
> damaged my motherboard. So I'm going to try and get a new power supply
with
> lots of Watts and see if I can replace those capacitors.
The power cuts could be the cause too. Do you have a UPS for the machine? If
not, may be worth ggetting one. Cheap one is around R400. Just needs to
filter the power a bit.
Date: 12 Feb 2008 20:27:57
Message: <47b2479d@news.povray.org>
There are power supplies that comes with a 20/24 plug.
> damaged my motherboard. So I'm going to try and get a new power supply with
> Thanx to everyone who threw in their bit.
remember to check the micro farads and voltage of the capacitor to be as
close as possible to the original ones, if theyare a little higher (20%
at most) they're ok.
Date: 12 Feb 2008 20:33:08
Message: <47b248d4$1@news.povray.org>
> with
If a UPS is to expensive a stabilizer would be good enough.
Date: 13 Feb 2008 13:24:05
Message: <47b335c5@news.povray.org>
"Saul Luizaga" <sau### [at] netscapenet> wrote in message
news:47b0de3f@news.povray.org...
>> news:47ad5bd1@news.povray.org...
>>> I have a Athlon XP 2400 Socket A using the onboard 128Mb SiS
>>> graphics card and a 250W power supply.
>> Power supply. Get a new one (I reccomend Sparkle brand) of at
>> least 300W.
>> This is an easy install you can do yourself.
> 550W Power Supplies are common these days, don't they? unless is
> not the case in your city.
I like the 1000W ones :)
The off thge shelf pcs are underpowered .. very likely will go
bonkers after
a couple of years producing all the symptoms the OP listed as
well as others.
Yeah - bump that minimum to 450W ...
Date: 13 Feb 2008 15:24:20
Message: <47b351f4$1@news.povray.org>
> bonkers after
My most powerful (2 of them) power supplys (on PC's, that is - we're not
counting Alpha/SGI -line here :p) are 300W both, without a single
problem. One is pushing my Opteron-based server with 6 harddisks and one
is pushing my Sempron-based workstation (or was - the mobo gave up).
Either computer shouldn't survive without 400+W (when listening to the
sale guys at stores) or without case fans (again, when listening to the
sale guys...). Even the ps power scale needed actually depends on the
user. AthlonXP with integrated graphics card and 1-2 HD's should be fine
with ok-conditioned 250W ps (my Opteron is worse electric drain than
AthlonXP and 300W is easily enough for
Opteron+G550+6HD+2optical+sound+nic+etc).
... if you're going to upgrade your machine and think about gaming (some
beast-level 3D-GFX -card, that is) at the future. Low-energy
-electronics (especially processors) are spreading already.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 14 Feb 2008 05:35:07
Message: <47b4195b@news.povray.org>
>>> least 300W.
Sucker.
Date: 14 Feb 2008 15:17:29
Message: <47b4a1d9$1@news.povray.org>
"scott" <sco### [at] laptopcom> wrote in message
news:47b4195b@news.povray.org...
>>>> least 300W.
>>> is not the case in your city.
> Sucker.
Are we having an octopoid remembrance?
