POV-Ray : Newsgroups : povray.off-topic : Really Cool TV idea Server Time
2 Mar 2026 09:19:05 EST (-0500)
  Really Cool TV idea (Message 1 to 10 of 16)
Subject: Really Cool TV idea
Date: 5 Feb 2008 01:13:02
Message: <47a7fe6e$1@news.povray.org>
I was at Best Buy the other day, and saw a TV that ran at 120hz.  It
didn't just refresh at that rate, though; it actually created new frames
to put in between the others.
This means that, for each of the 30 whole frames you get off the DVD,
you would get 3 additional frames interpolated between them.
It doesn't help still pictures any, but when anything is moving on it...
WOW.  I can not begin to describe how much more lifelike it is.
I would love to see that thing running a PS3 or something...
...Ben Chambers
ben at pacific web guy dot com (no spaces)
www.pacificwebguy.com
Subject: Re: Really Cool TV idea
Date: 5 Feb 2008 01:38:21
Message: <47a8045d$1@news.povray.org>
Cool. Does it just interpolate the colors, or does it actually try to detect
motion to make an educated guess about what should appear between two
frames?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 5 Feb 2008 03:59:42
Message: <47a8257e$1@news.povray.org>
> frames?
>  - Slime
Unfortunately, I don't have any more detailed information.  Remember,
this was a demo in a store.  They weren't trying to educate me, they
were trying to sell me on it.
In fact, the TV had a built-in function to provide the higher refresh to
one side, and play the standard picture on the other, so you could
compare more easily.  But not one bit of information about how the
intermediate frames were generated :(
I would assume a simple color interpolation, although other techniques
are, of course, possible.
...Ben Chambers
Date: 5 Feb 2008 04:12:23
Message: <47a82877$1@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:47a7fe6e$1@news.povray.org...
>I was at Best Buy the other day, and saw a TV that ran at 120hz.  It didn't
>just refresh at that rate, though; it actually created new frames to put in
>between the others.
> This means that, for each of the 30 whole frames you get off the DVD, you
Interesting, but how does it do that? I would think that analysing the
images at that speed would be extremely costly. In contrast, I'm curious if
the mpeg2 (or whatever DVDs are using) contain motion information in the
encoding, like some codecs do. If that is the case, it might just divide the
specified motion between frames by 4 and use that, still using pretty
standard decoding. This would require of course that the same divide is also
the one reading (decoding) the media.
Anyway, there will be things it can't do. For example, a small object moving
so fast that it's at one side of the screen in one frame, and in the other
side in the next frame will not be able to be correctly interpolated.
Basically, for the things that would benefit the very most, it won't work.
Can you show a youtube video of it? Just kidding...
Well, even if it's not using the codex method, it would at least have to
know both frames to interpolate between before starting interpolation. This
would mean a delay of one (normal) frame. That may not be very important
though, but perhaps expert players will be able to notice the decreased
responsiveness.
Rune
http://runevision.com
Date: 5 Feb 2008 04:15:58
Message: <47a8294e$1@news.povray.org>
"Chambers" wrote;
I just can't see how that would give extra lifelikeness. It's just a
blurring along the time-axis.
Rune
Date: 5 Feb 2008 04:27:36
Message: <47a82c08@news.povray.org>
> standard decoding.
  I doubt the *TV* gets any mpeg2 data. It just gets raw video.
Date: 5 Feb 2008 05:37:24
Message: <op.t51rsytuc3xi7v@news.povray.org>
And lo on Tue, 05 Feb 2008 06:12:52 -0000, Chambers
<ben### [at] pacificwebguycom> did spake, saying:
I thought all the EU 100Hz TVs already did that, and they've been around
for ages.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 5 Feb 2008 16:08:38
Message: <47a8d056$1@news.povray.org>
It also helps with the viewing of DVDs movies.  Movies generally go at
24 FPS, so the number of frames to be interpolated is constant.  With a
frame rate that is not a multiple of 24 (such as 60, which is more or
less the NTSC rate), some frames get played twice and some get played
three times.  The difference is noticeable to some observers.
John
Date: 5 Feb 2008 21:37:45
Message: <47a91d79$1@news.povray.org>
I've seen experiments where they filmed big-screen movies at 60fps, and
people would literally fall out of their chair when watching a movie
filmed from the seat of a rollercoaster.
     On what day did God create the body thetans?
Date: 5 Feb 2008 21:39:25
Message: <47a91ddd$1@news.povray.org>
> encoding,
They have at least "copy this part of the screen from here to there",
but I'm not sure if it's "motion" as such or just what is used to better
compress images with moving parts.
