POV-Ray : Newsgroups : povray.off-topic : Game opinions Server Time
17 May 2026 18:02:07 EDT (-0400)
  Game opinions (Message 91 to 100 of 112)
Subject: Re: Game opinions
Date: 5 Feb 2008 20:56:36
Message: <47a913d4$1@news.povray.org>
Invisible wrote:
> Really?
> You're telling me a human being can survive falling from more than 12 feet?
I've jumped 12 feet off a building, not even a bruise from it.
And no, I didn't land on a trampoline :)
> Isn't that rather like siting how many people have climbed Everest, thus
> *proving* that it's not impossibly difficult?
Climbing Everest *isn't* impossibly difficult.  Extremely hard, yes, but
not impossible, nor even unthinkable.
...Ben Chambers
www.pacificwebguy.com
Date: 5 Feb 2008 21:19:28
Message: <47a91930$1@news.povray.org>
Warp wrote:
>   If FPS games were about realism,
... then you'd be out of the game the first time you got shot, and you
wouldn't get to start over any more either.  ;-)
     On what day did God create the body thetans?
Date: 5 Feb 2008 23:38:23
Message: <MPG.2212e7a837abc5d198a0fa@news.povray.org>
In article <47a82845@news.povray.org>, war### [at] tagpovrayorg says...
> Patrick Elliott <sel### [at] rraznet> wrote:
> > Bah.. This is why I hate bloody acronyms...
>   I don't see how "HL" would be an acronym for "Halo".
You never know.. You get some damn stupid acronyms some times. What
would it be then "H"? lol
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 6 Feb 2008 03:22:43
Message: <47a96e53@news.povray.org>
> (Obviously the "simplest" thing to do would be to assume one level of
> DirectX and fail if any other level is present. It also seems likely that
> it wouldn't be that hard to check and use until available features - I was
> just checking whether that is what they actually did.)
It is complicated to make a DX9 game work with a large variety of hardware.
For every single "technique" you use in your game code you must check the
driver to see if the installed hardware supports it, and if it doesn't
whether DX can supply some software emulation at a reasonable enough speed
to support it.  It very quickly gets very messy as you need to code
different ways to do the same effect.  Add to that you'll probably need
several different versions of your shader code for each "generation" of
graphics card.  It's a mess and almost impossible to get things working 100%
correctly on 100% of "DX9-compatible" hardware.
DX10 on the other hand is much simpler.  If a card supports DX10 then it
supports DX10.  There are a list of things that the card must support to be
DX10 compatible, and you can just use them all without going through any
stupid checking procedures or having 4 different code versions.  There is no
such thing as running DX10 on a card with limited functionality (like you
can with DX9).  DX10 also makes lots of common things (like rendering
cube-maps, shadows etc) much simpler and faster than on DX9.
As you can imagine, writing a game that supports DX10 *and* DX9 is even
worse.  It's a shame that DX10 doesn't work on XP or older GFX cards, but
they had to make it that way so that in future things will be way simpler.
Just wait a year or two and you'll probably start seeing games that are DX10
only.
Date: 6 Feb 2008 03:26:07
Message: <47a96f1f$1@news.povray.org>
>>       FarCry, Crysis - great games!  :)
I played FarCry 3 or 4 times now through to the finish.  If you play it on
easy and have even an ounce of FPS experience you'll be fine.  The only
problem for me was the very last level in that circular arena place - took
several tries to get through that one alive.
> I only have a lowly 2.2 GHz dual-core AMD Athlon X2 4200+ with 3 GB
> DDR-400 RAM and an nVidia GeForce 7900GTX 512 MB. It'll probably not run
> at all...
FarCry will run fine - Crysis will struggle sometimes even at mid graphics
options.  I have a pretty similar rig to you (except Intel Core2Duo and only
2GB RAM) and it was certainly playable.
> BTW, I'm a little confused here. Benny seems to think that DirectX 10 is
> available for WinXP, while I was under the impression that it's for Vista
> only. [Part of of the M$ plan to force everybody to upgrade.] However,
> Wikipedia at least seems to suggest that Crysis works on XP, despite using
> DirectX 10... so... er... wuh?
DX10 will only run on Vista, the Vista display driver model is totally
different to XP so there is now way it will ever work on XP.
Games can be written to use DX9 or DX10 if they want...
Date: 6 Feb 2008 04:57:06
Message: <47a98472@news.povray.org>
> only.
  Which is a pitty, really, because I won't be able to play them.
Date: 6 Feb 2008 04:58:41
Message: <47a984d1@news.povray.org>
  "Halo" doesn't need to be acronymified because it's short already.
Date: 6 Feb 2008 05:01:30
Message: <47a9857a$1@news.povray.org>
>> thus *proving* that it's not impossibly difficult?
Hmm, let me see now... And how many people have actually achieved this
in all of human history? 6? 8? It's a pretty small number, given how
many millions of humans are out there. ;-)
http://blog.orphi.me.uk/
Date: 6 Feb 2008 05:03:10
Message: <47a985de$1@news.povray.org>
I rephrase:
There are people who have eaten broken glass and lived. There are people
who have been drowned for 35 minutes and survived without brain damage.
And there are people who have survived cyanide poisoning. However,
*normally* all of these are fatal.
Are you telling me it's *normal* for a human being to survive a 4-story
drop?
Date: 6 Feb 2008 05:22:35
Message: <47a98a6b@news.povray.org>
>> DX10
>> only.
Yeh, I wish I could play games like Crysis on my 386 running DOS too :-)
Would never need to upgrade then!
