POV-Ray : Newsgroups : povray.off-topic : VS Express editions? Server Time
10 Oct 2024 21:14:04 EDT (-0400)
  VS Express editions? (Message 1 to 10 of 23)
Subject: VS Express editions?
Date: 30 Jan 2008 13:36:23
Message: <47a0c3a7$1@news.povray.org>
Anybody played with them. I realize there are relatively few on here who
actually like MS products, but I want to hear other peoples opinions of
MS's free versions of their dev tools.
Subject: Re: VS Express editions?
Date: 30 Jan 2008 13:49:34
Message: <47a0c6be@news.povray.org>
about as shitty as their commercial offerings, only even more limited
and buggy. ;)
Date: 30 Jan 2008 14:02:40
Message: <47a0c9d0$1@news.povray.org>
> and buggy. ;)
Limited? yes. But, not terribly so. Buggy? Less so than prior versions.
Has some nice features. I sort of got forced into writing something for
VC# express because a library supplied by a vendor was using generics,
and we're still using ancient VS.NET. (Which is quite bug-ridden)
Their license is quite nice, the ability to just use it without having
to keep myself within the realm of "personal use only" is very nice.
Date: 30 Jan 2008 14:17:28
Message: <47a0cd48@news.povray.org>
I once tried it. Couldn't do anything useful with it during a whole
hour. I uninstalled it. Of course, despite recommendations made by
Microsoft itself to other developers, the uninstaller didn't remove
everything that was installed. I was months with lots of filetypes (like
.c) still associated to VS express.
I use gvim and a bash shell (yes, in Windows) for all my development
needs. Except for POV-Ray, where I use the internal editor, and for
Java, where I use Eclipse. MinGW as C compiler.
Date: 30 Jan 2008 14:18:46
Message: <47a0cd96@news.povray.org>
Ah, .not. I stay away from that. Even though some things look tempting.
But hey, Vista screenshots with Aero are tempting too (that's the whole
idea of marketing), and no way in hell I'll downgrade to it.
Date: 30 Jan 2008 14:32:49
Message: <47a0d0e1@news.povray.org>
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:47a0c3a7$1@news.povray.org...
I've used SQL Express, VS Express C# and web. They're fine for small
development projects. I wouldn't use them in a massive team on a large
commercial project, but for playing around or for smaller things, they're
fine.
Date: 30 Jan 2008 17:02:41
Message: <47a0f401@news.povray.org>
I installed VS C++ 2005, and immediately found that I could not set it
to assume that all strings were ASCII strings; I had to specifically
call the API function that is decorated with 'A' to specify that;
Bloodshed and OpenWatcom allow you to specify the string type with one
compiler setting, and the compiler automagically decorates them for you.
After editing all of the sources to put in what the compiler will not
let me assume, it then failed to recognize another API call during the
link phase.
I already have two C++ compilers that work just fine (Bloodshed and
OpenWatcom), so getting MS to work is just too much trouble.
John
Date: 30 Jan 2008 22:34:38
Message: <47a141ce@news.povray.org>
I used to like it, until I had a chance to see the professional version
in action.  For whatever reason, the free version is crippled beyond
belief, speed-wise.  It would literally take more than ten times as long
to open, load projects, or compile them.  The output would be identical,
though, so if you're OK with the wait, go for it.
...Ben Chambers
www.pacificwebguy.com
Date: 31 Jan 2008 00:40:15
Message: <47a15f3f$1@news.povray.org>
> fine.
What she said.  If it's a one-person project, it's sufficient.  Once you
start wanting source code control, automatic testing, etc., you'll want
the for-fee version. (Which, really, isn't that expensive. If your
employer can't afford a half-day of your pay to get you the tools you
need, you should be shopping your resume around.)
     On what day did God create the body thetans?
Date: 31 Jan 2008 04:34:36
Message: <47a1962c@news.povray.org>
  Really? There's a setting in the project properties for this.
