POV-Ray : Newsgroups : povray.off-topic : Video editing Server Time
9 Jun 2026 21:40:00 EDT (-0400)
  Video editing (Message 10 to 19 of 59)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Video editing
Date: 16 Jan 2008 10:23:37
Message: <op.t403l9q2c3xi7v@news.povray.org>
And lo on Wed, 16 Jan 2008 14:14:41 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> somebody wrote:
>> Editing is too generic a word. What exactly do you need to do?
> Take several chunks of video.
VirtualDub will only handle one file at a time.
> Cut 'em up. Stick them back together in a different order. Maybe remove
> bits or duplicate them. Repeat until it looks good.
Yep it'll do that for one 'chunk' of video. I use it mostly for rotating
video 90 degrees and/or re-encoding at 30fps, but you can select sections
cut/copy them out and paste them into a later or earlier point if that's
what you mean.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 16 Jan 2008 10:26:17
Message: <478e2218@news.povray.org>
> what you mean.
  VirtualDub is really awkward for that purpose. It's not a video editing
software, it never was.
Date: 16 Jan 2008 11:06:14
Message: <478e2b76$1@news.povray.org>
Cinelerra is what I've played with, not sure if there's a Windows version
though (but I think there is).  It's OSS and supposed to be quite good,
but the learning curve is pretty steep.
Jim
Date: 16 Jan 2008 11:06:46
Message: <478e2b96$1@news.povray.org>
On Wed, 16 Jan 2008 11:15:58 +0000, Invisible wrote:
> Well, *you* try finding software that will encode it. (Without paying
> money.) Plenty of decoders, no (free) encoders.
http://www.mplayerhq.hu
mencoder will create MPEG-2 files just fine.  IIRC, Windows version
available.
Jim
Date: 16 Jan 2008 11:24:16
Message: <op.t406eawic3xi7v@news.povray.org>
And lo on Wed, 16 Jan 2008 15:26:17 -0000, Warp <war### [at] tagpovrayorg> did
spake, saying:
>> what you mean.
No if it was you could work and mix multiple files, but if you just want
to trim the "Is it on?" at the beginning or take out that guy making rude
gestures at the camera or make it look like the Queen is storming out of a
photo session rather then into one; then it'll do that with relative ease.
For what it sounds like Andy wants to do I agree it won't work, but it
could be used to clean up his separate files first.
Phil Cook
Date: 16 Jan 2008 12:20:32
Message: <478e3ce0@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:478de76d$1@news.povray.org...
Yup. Very hard
http://www.google.com/search?hl=en&q=free+dvd+encoder&btnG=Google+Search&met
a=
http://www.google.com/search?hl=en&q=free+mpeg-2+encoder&btnG=Search&meta=
My laptop came with Roxio's MyDvd Basic installed. No idea how much it is to
but. I've only used it once (convert 2 DivX encoded videos to a DVD so my
parents could watch them)
Date: 16 Jan 2008 12:31:49
Message: <478e3f85$1@news.povray.org>
Invisible wrote:
> So, I've got something to turn frames into video, and something to turn
> video into a playable DVD. Anybody know of something good for editing
> inbetween?
For Windows, I use ULead Movie Factory. I tried about a dozen different
such programs (a few years back, mind), and ULead's software was the
only one that didn't give me artifacts. Everyone else's "best" quality
was worse than ulead's "smallest" quality - I suspect ulead was the only
one generating B frames.
Other than that, google around. Most of the programs have free demos
that'll only do like 5 minutes at a time.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 16 Jan 2008 12:33:52
Message: <478e4000$1@news.povray.org>
Invisible wrote:
> Take several chunks of video. Cut 'em up. Stick them back together in a
> different order. Maybe remove bits or duplicate them. Repeat until it
> looks good.
iMovie or iDVD or something like that on Macs. (Comes with?)
Windows Movie Maker (comes with Windows XP, IIRC, or is a free download).
Date: 16 Jan 2008 18:25:24
Message: <MPG.21f840249298482398a0e3@news.povray.org>
In article <478e2218@news.povray.org>, war### [at] tagpovrayorg says...
s
> > what you mean.
Hmm. In line with this, just wondering if there is some way to feed
something through it to fix a problem I have? My father, being a major
dope about video cameras, treated it like a picture camera and recorded
sections of videos sideways... I know in theory that you could pull the
audio out, strip the stream down to individual frames, rotate those to a
normal orientation, then restream it all, but I wasn't sure if there was
any way to use VirtualDub or one of the other free tools that exist to
manage that. Its certainly not something you are going to run into often
enough for them to have provided a way to fix this in the software that
came with it. Which isn't that bad, once you get past the confusion of
how to crop out bits you don't want (you have to select the part you
want to keep, not get rid of, which to me is completely backwards).
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 16 Jan 2008 18:37:28
Message: <op.t41qkqwecs6ysw@e6600.bredbandsbolaget.se>
On Thu, 17 Jan 2008 00:25:23 +0100, Patrick Elliott <sel### [at] rraznet>
> manage that.
I recall there being a 'rotate' filter in VirtualDub.
FE
