POV-Ray : Newsgroups : povray.off-topic : Just wondering Server Time
4 Jul 2026 12:26:56 EDT (-0400)
  Just wondering (Message 21 to 30 of 42)
Subject: Re: reverse
Date: 17 Jan 2008 03:57:51
Message: <478f188f$1@news.povray.org>
> While we're on the subject... If you wanted to, how hard is it to connect
> a PC to a normal TV? (Obviously, PCs normally run at vastly different
> scanrates and lack the propper connectors...)
If you have a DVI output and a modern TV with HDMI input, then you simply
buy the correct cable which is about 10 quid.  DVI and HDMI are electrically
the same, just different connectors (plus HDMI can include digital audio).
Subject: Re: Just wondering
Date: 17 Jan 2008 04:01:14
Message: <478f195a$1@news.povray.org>
> So, given a typical PC, how much would it actually cost to equip it such
> that you can record and play back TV with it? What actual hardware and
> software does this require?
Search Amazon.co.uk for "DVB-T".  That will sort you out in the UK at least
for the hardware.
Date: 17 Jan 2008 04:13:52
Message: <478f1c50$1@news.povray.org>
>> connect a PC to a normal TV? (Obviously, PCs normally run at vastly
>> different scanrates and lack the propper connectors...)
> simply buy the correct cable which is about 10 quid.  DVI and HDMI are
> electrically the same, just different connectors (plus HDMI can include
> digital audio).
Nobody I know of has a TV this new. However, my latest video card does
have DVI output. (Fortunately it comes with a DVI to VGA adaptor, so I
can still plug it in to my monitor and get a picture...)
Actually, for that matter, my dad can use DVI or VGA with his PC, and
there doesn't appear to be a significant difference...
http://blog.orphi.me.uk/
Date: 17 Jan 2008 04:28:36
Message: <op.t42hwp00c3xi7v@news.povray.org>
And lo on Wed, 16 Jan 2008 19:09:08 -0000, Orchid XP v7 <voi### [at] devnull>
did spake, saying:
>> Yeah, often times there is a key combination to get it turned on.
> But usually it's clearly marked.
Yeah IIRC a picture of two squares representing monitors. Fine if
understand that. Though saying that someone I know has a laptop with an
unmarked Bluetooth toggle which he has to remember.
> And, usually, you can do it from the video driver settings too...
Provided you know how to get into the video driver settings.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 17 Jan 2008 04:37:52
Message: <478f21f0$1@news.povray.org>
Most laptops I've seen have a big icon in the system tray that won't go
away. When you click it, it gives you a menu that lets you instantly
change resolution, colour depth, etc., without going through the whole
settings dialog. Usually switching output is one of the very big,
unmissable options.
Date: 17 Jan 2008 07:58:15
Message: <op.t42rl9ugc3xi7v@news.povray.org>
And lo on Wed, 16 Jan 2008 18:40:37 -0000, Warp <war### [at] tagpovrayorg> did
spake, saying:
> Jim Henderson <nos### [at] nospamcom> wrote:
>> I have to disagree with Warp - I don't believe this is not an NTSC vs.
>> PAL issue
>   I didn't mean to say it's an NTSC vs PAL issue, but that the NTSC/PAL
> standards suck for high-definition images.
Good job they don't use them for true-HD broadcasts then.
Phil Cook
Date: 17 Jan 2008 08:07:45
Message: <478f5321$1@news.povray.org>
> (My dad claims his TV has a VGA input socket. But then, I suppose it is an
> LCD, so multiple scanrates probably isn't an issue...)
Well actually an LCD only uses 1 or 2 scanrates (usually 50 and/or 60 Hz),
the difference is that an LCD will include sophisticated DSP functionality
and a frame-buffer anyway, so scan-rate conversion comes almost for free.
Date: 17 Jan 2008 08:40:03
Message: <478f5ab3$1@news.povray.org>
>> is an LCD, so multiple scanrates probably isn't an issue...)
> Hz),
Well, that's true...
> functionality and a frame-buffer anyway, so scan-rate conversion comes
> almost for free.
...which is the part I was getting at.
BTW, is it true that an LCD is matrix addressible? (i.e., all the pixels
can be changed exactly simultaneously.)
Date: 17 Jan 2008 09:04:27
Message: <478f606b$1@news.povray.org>
You can only change a line at a time.  You charge up all the "column" wires
to what voltage you want, then power up the row line which opens all the
transistors inside every sub-pixel on that row, hence they all the get the
voltage you wanted.  You then turn off that row (and hence the transistors
close) and the sub-pixels remember their voltages until you come round next
frame.  You can only do this process one row at a time.
So yes, it's matrix addressable, but no you can't change all the pixels
exactly at the same time.
Date: 17 Jan 2008 09:18:58
Message: <478f63d2$1@news.povray.org>
>> pixels can be changed exactly simultaneously.)
> wires to what voltage you want, then power up the row line which opens
> all the transistors inside every sub-pixel on that row, hence they all
> the get the voltage you wanted.  You then turn off that row (and hence
> the transistors close) and the sub-pixels remember their voltages until
> you come round next frame.  You can only do this process one row at a time.
I see...
For what it's worth, does "TFT" actually mean something? Or is it just a
marketing term that means "hey, this screen is great!!!1!1 please buy
me!!1"?
