POV-Ray : Newsgroups : povray.off-topic : My mouse Server Time
24 Dec 2025 07:14:59 EST (-0500)
  My mouse (Message 1 to 10 of 43)
Subject: My mouse
Date: 14 Jan 2008 04:55:35
Message: <478b3197@news.povray.org>
OK, so check this out... At home I have a wireless optical mouse. I've
had it for several years now, and it has always worked perfectly.
However, a few weeks ago I reinstalled Windoze. And ever since that
point in time, the mouse hasn't worked properly. Most of the time it
works normally, but every now and then it suddenly stops working
completely. The light on the base station still twinkles when I move it
or press the buttons, but the computer fails to respond. (Keyboard
commands work, just not mouse commands.)
The *only* thing that fixes this condition is a reboot. No amount of
reconnecting the USB cable has any effect.
Obviously, this is intensely frustrating, far beyond my powers of
description. Last night I was playing an official TF2 match, and my
mouse quit working. That means I now can't shoot, steer, look around, or
talk to my teammates over Ventrillo.
[In spite of this - and much to my amusement - I managed to actually
capture a control point. Basically I staggered in there sideways and
nobody tried to stop me. And my teammates had done almost all the work
first... Basically the two teams clashed, everybody died, and then I
stumbled in. What fluke!]
Anyway, does *anybody* have *any* idea why reinstalling Windoze has made
my mouse malfunction so badly??
http://blog.orphi.me.uk/
Subject: Re: My mouse
Date: 14 Jan 2008 06:30:27
Message: <478b47d3$1@news.povray.org>
I would check the drivers for the mouse, USB ports and any other "mainboard"
type drivers.  There might be some different version now than before the
reinstall.
Then I'd try a different mouse, just to see.
When it stops working, is the mouse still "there" (ie in device manager) or
does Windows think it has gone?
Date: 14 Jan 2008 06:51:49
Message: <478b4cd5$1@news.povray.org>
>> made my mouse malfunction so badly??
> "mainboard" type drivers.  There might be some different version now
> than before the reinstall.
When I originally installed Windoze, I used the CDs that came in the
box. However, I now have a dual-core CPU, and [I forget exactly what
happened] I couldn't get Windoze to work properly without using the
latest motherboard drivers. Go figure.
So, new motherboard drivers. (The mouse itself doesn't have any drivers
- or rather, it does, but I've never used them. The drivers are to
activate the 15 buttons that I don't use. 3 buttons is enough for me...)
Yeah, if I had one...
> or does Windows think it has gone?
It's very hard to check.
10 years ago, I used a sophisticated operating system called AmigaOS. It
was possible to operate this without a mouse, because there was a set of
keyboard shortcuts for moving the mouse pointer and clicking mouse
buttons. However, to my absolute frustration [indeed, near rage],
Windoze doesn't appear to support such a feature. So you have to guess
what keyboard shortcuts every individual program uses [assuming it
provides any at all]. Grrr!!
I do have a very vague recallection that maybe I had the mouse plugged
into the PS/2 port before, whereas now it's in a USB port. However, I
*cannot* find the USB-PS/2 adaptor anywhere, so...
Date: 14 Jan 2008 07:02:56
Message: <478b4f70$1@news.povray.org>
> 10 years ago, I used a sophisticated operating system called AmigaOS...
Try this:
Windows + Break/Pause (or go through My Computer to control panel)
Right arrow key twice
Tab
Space
Tab
Then use the arrow keys (right is expand) to search through.
It's the same in all windows programs that use standard forms.
Date: 14 Jan 2008 07:16:33
Message: <478b52a1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:478b4cd5$1@news.povray.org...
> buttons. However, to my absolute frustration [indeed, near rage], Windoze
> doesn't appear to support such a feature. So you have to guess what
> keyboard shortcuts every individual program uses [assuming it provides any
> at all]. Grrr!!
The keybaord shortcuts are the letters that are underlined when you press
the "Alt" key.
Fyi You can always use "Tab" and the arrow keys to scroll between
highlighted options and Space-Bar to select.
To get Windows to always underline the shortcuts without using a mouse:
press the Windows button (between L-Ctrl and L-Alt)
Navigate to Control-Panel with the arrow keys.
Navigate to "Appearance and Themes" and then "Display"
Press "Tab" until the top tabs is highlighted.
Now use your < > arrow keys to navigate to "Appearance"
Press "Tab" untill "Effects" is highlighted and press the Space Bar.
Press "Tab" untill "Hide underlined letters for keyboard navigation untill I
press the Alt key"
I hope this helps...
-Nekar Xenos-
Date: 14 Jan 2008 16:19:57
Message: <478bd1fd@news.povray.org>
Because Windows is as buggy as an outhouse in the summer?
John
Date: 14 Jan 2008 17:40:29
Message: <op.t4xyl1l2nzu7ad@tdd20.home>
Tried new batteries?
Date: 14 Jan 2008 17:46:14
Message: <478be636$1@news.povray.org>
If it was the batteries,
1. The receive light wouldn't be twinkling.
2. Rebooting the PC wouldn't fix the problem.
3. It wouldn't have suddenly started happening at exactly the time I
changed some software.
FWIW, yes, I have changed the batteries several times. However, usually
when the batteries fail, the mouse starts to gradually move slower than
usual before actually stopping. This is quite different...
Date: 14 Jan 2008 23:55:52
Message: <478c3cd8@news.povray.org>
Why does that surprise you?
"Hi, I'd like you to run on this motherboard, but I'm not going to tell you
what it does or how to make it do anything"
Try installing them anyway. It might be that the default drivers aren't
totally compatible with your mouse.
Windows isn't that hard to run without a mouse. Some apps have poor
shortcuts, but most do have them. I recall the fun of using my university
machine (win 98) for a week without a mouse, after I poured coffee over the
mouse.
I just tried to get to the device manager without using the mouse, Took
around 20 keystrokes.
There are just a few useful shortcuts that you need to remember
Ctrl-Esc opens the start menu. (as does the win key if you have that)
Alt-spacebar brings up the move/resize menu for any window
Tab moves you from pane to pane in things like device manager or explorer
and from one anchor to another in a web browser
Date: 15 Jan 2008 03:20:41
Message: <478c6cd9$1@news.povray.org>
Why not?
