POV-Ray : Newsgroups : povray.off-topic : Bored? Server Time
9 Jun 2026 11:00:50 EDT (-0400)
  Bored? (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Bored?
Date: 9 Jan 2008 23:45:38
Message: <4785a2f2@news.povray.org>
All I see is the easter bunny :(
...Ben Chambers
www.pacificwebguy.com
Subject: Re: Bored?
Date: 10 Jan 2008 05:24:17
Message: <4785f251@news.povray.org>
> Now try to somehow incorporate the actual transcendental sequence into
> it :)
I was going to make it out of the digits of Pi - but the digit sequence
repeats too much, which screws up the illusion. (Actually, virtually
every digit sequence I tried repeats too much. Hence the letters...)
http://blog.orphi.me.uk/
Subject: Re: Bored?
Date: 10 Jan 2008 05:29:02
Message: <4785f36e$1@news.povray.org>
> Try staring cross-eyed at this image for a while...
I think I need a bigger font size (or a bigger monitor) for this one...
Actually, I find that after I've looked at these sort of images for a minute
or two, I cannot focus on anything for a few minutes - everything is blurred
unless I really strain to make it in focus.
Subject: Re: Bored?
Date: 10 Jan 2008 05:44:29
Message: <4785f70d@news.povray.org>
I found that looking at the output in a DOS window, the writing was just
too tiny for the illusion to work. I had to set it to Lucida 24 or
something. (I have a 14" monitor. Which also has an absurdly high gamma
setting BTW...)
Subject: Re: Bored?
Date: 10 Jan 2008 09:48:45
Message: <op.t4pxziuic3xi7v@news.povray.org>
And lo on Wed, 09 Jan 2008 16:42:03 -0000, Invisible <voi### [at] devnull> did
spake, saying:
<shrugs> I can't get any of those types of things to work, it's all a
bunch of characters/dots/squiggles to me.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Subject: Re: Bored?
Date: 10 Jan 2008 11:24:51
Message: <478646d3$1@news.povray.org>
> spake, saying:
I could never see anything on these. Both character-based and image-based.
Subject: Re: Bored?
Date: 10 Jan 2008 11:26:40
Message: <47864740$1@news.povray.org>
Rune wrote:
> Nice, though I prefer looking at it cock-eyed ("parallel eyed") to make the
> motive stand out rather than being sunken in.
Just for you, Rune: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#6795#6795A#695A#695A#695A#695A#695A#695
BCDEFBCDEFBCDEFBCDEFBCDEFBGCDFBGCDFBHGCDFBHGCDFBHGCDBHGCDBHGCDBHGC
IJKLMIJKLMIJKLMIJKLMIJKLMNIJLMNIJLMNOILMNOILMNOILMPNOLMPNOLMPNOLMP
QRSTUQRSTUQRSTUQRSTUQRSTUVQRTUVQRTUVQRTUVQRTUVQRTUVWQRUVWQRUVWQRUV
XYZabXYZabXYZacbXYacbXYadcbYadcbYadcbYadcbYadcbYadcebYdcebYdcebYdc
fghijfghijfgkhifglkhfglkmhflkmhflkmhflkmhflkmhflkmhnflmhnflmhnflmh
opqrsopqrsoptqroputqopuvtqpuvtqpuvtqpuvtqpuvtqpuvtqwputqwputqwputq
xyz01xyz01x2yz1x2y3z12y43z2y43z2y43z52y3z52y3z52y36z5y36z5y36z5y36
789#A789#A7B89A7B89AC7B8AC7B8AC7B8AC7DB8AC7DB8AC7DB8C7DB8C7DB8C7DB
EFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIE
JKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJ
Subject: Re: Bored?
Date: 10 Jan 2008 11:35:29
Message: <47864951$1@news.povray.org>
The idea is to simply look at the image cross-eyed, so you see double,
and make the repeats line up exactly.
The character-based ones are hard, because unless you have the right
size typeface, it's almost impossible to see. Also, you can only
generate fairly large steps in depth, which easily throws the illusion
off. FWIW, the algorithm for generating random dot images is identical
(but with colours instead of characters).
Try this:
KLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOKLMNOK
PQRSTPQRSTPQRSPQRSUPQRSUPQRUPQRVUPQRVUPQRVUPQRVUPQRVUPQRVUPQRVUPQR
WXYZaWXYZaWXYZWXYZbWXYZbWXYbWXYcbWXYcbWXYcbWXYcbWXYcbWXYcbWXYcbWXY
defghdefghdefgdefgidefgidefidefjidefjidefjidefjidefjidefjidefjidef
klmnoklmnoklmnklmnpklmnpklmpklmqpklmqpklmqpklmqpklmqpklmqpklmqpklm
rstuvrstuvrstuvstuvwstuvwsuvwsxuvwsxuvwsxuvwsxuvwsxuvwsxuvwsxuvwsx
yz012yz012yz012y012y031y031y4031y4031y4031y4031y4031y4031y4031y403
56789567895678956795679567#9567#9567#9567#9567#9567#9567#9567#9567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 right half is completely blank, the left half contains a simple image.
If you cross your eyes, each little star at the bottom becomes a *pair*
of stars. If you move your eyes such that the stars appear to exactly
overlap, then you've either returned to normal focus, or you've unlocked
the image. (The hard part is moving to look at other bits of it without
going back into normal focus.)
Do this for long enough, and you will develop a nasty headache. ;-)
Subject: Re: Bored?
Date: 10 Jan 2008 11:49:30
Message: <47864c9a$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:47864740$1@news.povray.org...
>> the motive stand out rather than being sunken in.
> Just for you, Rune:
Nice motive. :)
I think you didn't get my point though. I preferred the previous image,
because when I looked at it the way I prefer (parallel-eyed rather than
cross-eyed) then the motive appeared as I preferred (bulging out rather than
being carved in). There were two reversals, which meant I liked it just the
way it was, even though I used it a different way than intended. :)
Rune
http://runevision.com
Subject: Re: Bored?
Date: 10 Jan 2008 11:50:54
Message: <47864cee$1@news.povray.org>
>> image-based.
If you have one eye that behaves differently to the other, you will
never see one. You can be e.g. shortsighted, as long as both eyes are
equally shortsighted! If both your eyes are the same, practice is all
that's required...
