POV-Ray : Newsgroups : povray.off-topic : Electric sheep Server Time
9 Jun 2026 18:32:57 EDT (-0400)
  Electric sheep (Message 16 to 25 of 65)
Subject: Re: More sheep
Date: 10 Jan 2008 11:23:19
Message: <47864677@news.povray.org>
> Now, if I could make it download some more sheep... (You'd think 350
> would be enough. However, it seems to be more like 15 actual images,
> plus 15! morphs between them. Which isn't so interesting.)
There aren't morphs for all possible combinations. Nowhere near that.
Date: 10 Jan 2008 11:23:34
Message: <47864686@news.povray.org>
Rune wrote:
> "Invisible" <voi### [at] devnull> wrote?
>> Now, if I could make it download some more sheep... (You'd think 350 would
>> be enough. However, it seems to be more like 15 actual images, plus 15!
> Why 15! ?
> For X images, wouldn't the necassary morphs between them be only X*(X-1)/2
> and not X! ?
Hmm. Your knowledge of combinatorics clearly exceeds mine
considerably... :-}
http://blog.orphi.me.uk/
Date: 10 Jan 2008 11:24:00
Message: <478646a0$1@news.povray.org>
> Why 15! ?
> and not X! ?
Note that morphs cannot be played backwards and make sense. A->B and
B->A videos are different, so both are needed if you wanted all possible
combinations.
Date: 10 Jan 2008 11:25:12
Message: <478646e8@news.povray.org>
My point is that there seem to be several morphs for each loop, meaning
that the number of morphs dawfs the number of actual loops...
Date: 10 Jan 2008 11:26:09
Message: <47864721$1@news.povray.org>
Yes they can. But MPEG-2 doesn't make that real easy...
> A->B and
> combinations.
They *can* be different, but no mathematical law that says they must be.
(However, ES seems to implement it this way.)
Date: 10 Jan 2008 11:36:29
Message: <4786498d$1@news.povray.org>
I know MPEG doesn't make it easy, but they wouldn't make sense anyway-
Try it. Make a video of A, A, B->A backwards, B, B. See if the morph
looks OK.
>> A->B and B->A videos are different, so both are needed if you wanted
In the way ES works, the loop is "rotating". The morph is interpolating
sheep A to sheep B and *also* rotating. If you play it backwards, it
would be rotating backwards, and the sudden jump in "direction" is
really noticeable.
Date: 10 Jan 2008 11:37:59
Message: <478649e7@news.povray.org>
> looks OK.
Actually, don't. I'll try to do it for you.
Date: 10 Jan 2008 11:38:23
Message: <478649ff$1@news.povray.org>
>> be. (However, ES seems to implement it this way.)
> really noticeable.
I see. So there's a discontinuity in the 1st derivative then? ;-)
Subject: Re: Electric sheep
Date: 10 Jan 2008 11:41:36
Message: <47864ac0$1@news.povray.org>
> I used to, but stopped because the MPEG video showing at fullscreen
> (plus the fact that you may end up rendering frames for them) needs some
> CPU time.
<I'm old>
I can remember when decoding MPEG-1 in realtime required specialised
hardware - and encoding required a very high-end computer system!
And today, my PC is decoding MPEG-2 in realtime using idle CPU cycles...
How times have changed!
</I'm old>
Date: 10 Jan 2008 11:42:20
Message: <47864aec@news.povray.org>
On the What?
o_0
