POV-Ray : Newsgroups : povray.off-topic : Differential equations FTW! Server Time
17 May 2026 05:33:20 EDT (-0400)
  Differential equations FTW! (Message 11 to 20 of 31)
Subject: Re: Differential equations FTW!
Date: 8 Jan 2008 11:00:51
Message: <47839e33$1@news.povray.org>
>> Ouch.
> Well I'm sure you know what the gradient is.  But how is it defined in
> more than one dimension?  And the divergence function?  It's all taught
> in vector calculus...
Try to remember: I have never taken any course in any mathematical
subject of any description. I have a GCSE in mathematics (grade C), but
that only covers addition, subtraction, multiplication, division and a
few other bits and pieces. Everything else I know is what I have managed
to figure out from reading books and surfing the net. ;-)
It's a wonder I know anything about mathematics at all... heh.
>> Wikipedia - a great reference source, a rubbish way to learn brand new
>> concepts. (Indeed, I've seen articles marked for revision *because*
>> "Wikipedia is not a how-to". Hmm, what *is* Wikipedia then?)
> Wikipedia is a reference, not a website full of tutorials.  Still, they
> should link at the bottom of the "vector calculus" page to some good
> online tutorial as it's really not very hard if you have a basic
> understanding of normal calculus.
I agree there.
Certainly the page on digital filters makes them seem like an utterly
incomprehensible topic. But a short read of a good book reveals that
it's all actually quite simple. [Assuming you want linear,
time-invariant filters of course.]
Ah well, never mind.
http://blog.orphi.me.uk/
Date: 8 Jan 2008 19:52:33
Message: <47841ad1@news.povray.org>
>> Cellula Automata - Each cell (pixel) follows some simple rules based
>> on its current state and that of its neighbours to determine its state
>> in the next generation.
> I thought a cellula automaton is where each cell has a *finite* number
> of possible states? In this example, we have (conceptually) continuous
> rather than discrete states.
I don't see anything in this case to say that the number of states of a
cell is infinite :)
OK - this is more properly called a 'continuous automata' or a
'continuous spatial automata' than a CA.  Very similar except that the
future state is determined by functions rather than a state table.
Still if you had a large enough state table...
Still the states here seem to converge to certain preferred values and
patterns.  Like 'attractors' in a fractal.
>> This particular example looks like it implements some equations that
>> model the reaction of chemicals in 2D.  There are real mixtures that
>> exhibit the pulsating and alternating patterns that some settings
>> reproduce.
> Indeed. That's how I found the link. ;-) I saw a TV program mention that
> the patterns of animal skins can be described by a single mathematical
> formula. Searching for this formula, I came across a document claiming
> it's due to reaction diffusion - and hence the second link, which is a
> simulation of the reaction diffusion differential equation.
> Now, if I could figure out what the equation is and how it works, I
> might be able to simulate it...
Don't the references provided by the site give details ?
"It is based on the Gray-Scott model, and was taken from John E.
Pearson's Complex Patterns in a Simple System - Science, 261, 189, 9
July 1993.
More details about the type of system used can be found at the [Xmorphia
web site].
>> Fiddling around with the parameters gives some behaviours that are
>> interesting and some that quickly lead to all dead, all alive or
>> something else.
>> The number of possible combinations of the parameters is huge but
>> there are typically a small number of interesting classes of behaviour
>> on the boundaries between boring and chaotic.
> Indeed, this is the case with a lot of fractals. A simple set of rules,
> iterated a sufficient number of times, gives rise to complicated and
> unpredictable behaviour, which is often quite pretty to look at. :-)
True.
>> Fun stuff.  Thanks for the link.
> It's not quite as much fun, but do a search for "boids" to see some
> interesting flocking behaviour...
Been there.  Done that.  We have similar interests.
I first saw Chris Langton's work on Boids described in Scientific
American.  Maybe 20 years ago (?).  Back then I wrote a version (in 2D)
on the Apple ][ and it worked but very slowly.  There are many
simulators out there to play around with now and machine performance is
so much better that it is just ridiculous.
Ditto with fractals BTW.  I still have the August 1985 Scientific
American with the Mandelbrot Set cover and article by AK Dewdney in his
Computer Recreations column.  Talk about a bombshell !  Unfortunately at
1MHz the old Apple was a little slow and the graphics a bit primitive.
It wasn't until I wrote a multi-tasking version in assembler on a
mainframe with output rendered to a laser printer that I was happy.
'Artificial Life' by Steven Levy is a good popular science book on the
A-Life field including CAs, Boids and Genetic Algorithms.  It was
published in 1992 so things have progressed a bit and there is a lot of
more recent work available on the Web.  Still a good read though.
Date: 9 Jan 2008 05:01:12
Message: <47849b68$1@news.povray.org>
> cell is infinite :)
> future state is determined by functions rather than a state table. Still
Indeed, yes.
> July 1993.
> web site].
The Xmorphia web site apparently no longer exists. (Firefox tells me the
server cannot be found.)
As for "Science, 261, 189, 9 July 1993", what does that actually *mean*?
I could have chosen this for my final year project in my degree.
(Actually I chose distributed MVC, because I figured OpenGL would be
*way* too hard. You have to use C for a start...)
I first came across the M set in an edition of the Guinness Book of
Records. It held the record for "most complicated mathematical object".
Not entirely sure how they arrived at that conclusion... ;-) The text
accompanying it mumbled something about real and imaginary numbers,
fluid dynamics and the stock market. It didn't make a lot of sense.
Later I found books such as The Beauty of Fractals and so on in the
local library. Most of these consisted of miles of very advanced
mathematics, most of it concerning the statistical properties of the
coastline or something, and almost none of it to do with drawing these
fantastic images that I longed for. The tiny selection of actual
*pictures* present usually included only the vaguest suggestion of what
the image *is*, and absolutely no suggestion about HOW TO MAKE IT. It
was an extremely frustrating time...
Eventually, by dint of wading through many, many textbooks on advanced
mathematical techniques, I was eventually able to grok the concept of
complex numbers, and eventually to comprehend *why* the apparently
unrelated formulas Z = Z^2 + C and (X,Y) = (X^2 - Y^2 + A, 2XY + B) are
actually the same thing. This happened while I was at college, where
they actually *had* math books on the shelves. Progress was much more
rapid after that...
Date: 9 Jan 2008 06:13:21
Message: <4784ac51$1@news.povray.org>
I dug around and found the equations in some PDF paper:
http://citeseer.ist.psu.edu/45188.html
They're on page two, and if you understood how the wave equation worked then
it should be pretty trivial to implement.
If I get time I would like to try and implement this in a pixel shader, it's
exactly the thing that GPUs are good at - performing the same code on a huge
number of different pixels.
> Later I found books such as The Beauty of Fractals and so on in the local
> library. Most of these consisted of miles of very advanced mathematics,
> most of it concerning the statistical properties of the coastline or
> something, and almost none of it to do with drawing these fantastic images
> that I longed for. The tiny selection of actual *pictures* present usually
> included only the vaguest suggestion of what the image *is*, and
> absolutely no suggestion about HOW TO MAKE IT. It was an extremely
> frustrating time...
I think I looked at a BASIC implementation and figured out what the core
loop was doing.  It was pretty cool that such a small simple bit of code
made such nice pictures.  I tried writing a version in assembler, it worked
but using fixed point numbers meant you could only zoom in about 3 or 4
times until it all went wrong (no FPU on that machine!).
Date: 9 Jan 2008 06:31:27
Message: <4784b08f$1@news.povray.org>
>> the server cannot be found.)
> then it should be pretty trivial to implement.
I see. So we have two chemicals, who's concentrations are governed by a
new, more complicated pair of differential equations. Is that basically
what it means?
> it's exactly the thing that GPUs are good at - performing the same code
> on a huge number of different pixels.
More precisely, doing the some thing on a huge number of different
pixels *independently*. ;-) All goes horribly wrong with lots of data
dependencies. Still, for this, only neighboring pixels matter, so it
should still move like lightning...
>> what the image *is*, and absolutely no suggestion about HOW TO MAKE
>> IT. It was an extremely frustrating time...
> loop was doing.
Me too.
When my dad purchased AMOS Professional (look it up), it came with a
5-disk set of example programs. One was a thing that drew a litle
jellyfish. (I now realise that this was the quadratic Julia set C = 0.26
or so.) And another program drew the Mandelbrot set. Slowly. Very
slowly. (Hello? Interpretted language on an 8 MHz CPU with no FPU?)
The program in question had lots of different colouring options and so
forth. It took a while to dig out the core loop. I was especially
surprised to find that it does all these complicated calculations, and
then THROWS THE ANSWER AWAY and only counts HOW MANY TIMES it's been
round the loop. That was quite unexpected!
Indeed yes! I found this to be quite amazing...
Eventually I came to know the Mandelbrot algorithm like the back of my
hand. But how to make that "cubic Mandelbrot" you see in all the books?
Various simple manipulations of the loop formula failed to produce the
correct image. Compare:
   X = X*X - Y*Y + A
   Y = 2*X*Y + B
Obviously (?!), the correct formula is in fact
   X = X*X*X - 3*X*Y*Y + A
   Y = 3*X*X*Y - Y*Y*Y + B
I would never have thought of that in a million years. At least, not
until I finally worked out what a "complex number" actually is and how
to do arithmetic with them...
> worked but using fixed point numbers meant you could only zoom in about
> 3 or 4 times until it all went wrong (no FPU on that machine!).
Took 2 hours at 320x240 on my Amiga 1200 with a 20 MHz FPU.
Took 6 hours on the RM Nimbus we had at school, with a 286 and a copy of
RMBASIC. Damn that was slow...!
By the time I got to college, I was writing programs in Pascal with
random dithering, multiple colouring algorithms and other bells and
whistles.
[Other examples that came with AMOS included an L-system that draws
plants. I never did figure out how. Later I saw a Blitz Basic example
that uses the Chaos Game to draw lots of interesting stuff in realtime.
On, and that's also where I first figured out how to do the infinite
trails trick...]
Date: 9 Jan 2008 06:45:15
Message: <4784b3cb$1@news.povray.org>
> what it means?
I think the equations are actually *simpler* than the wave equation because
it gives you the velocity of the concentrations directly (not the
acceleration).  One less integration step to perform, and no need to keep an
array of velocity information.
> More precisely, doing the some thing on a huge number of different pixels
Doesn't matter, because you cannot read pixels from a texture you are
rendering to currently.  So you need to have one texture that shows the
previous state, and then your pixel shader will write the new state into a
new texture, performing as many look-ups from the old texture as you like.
After you've created the new states then obviously you can swap the textures
around for the next generation.
I'd then write another pixel shader that read form the two state textures
and outputted to the screen back-buffer some colours, possibly using a 3rd
texture as a look-up-table for speed.
Oh I was down to about a minute or two at 640x480 on my 12 MHz Acorn (no
FPU).  Limited zooming possibilities though.  Actually someone had written a
much more complicated version in assembler that got around the accuracy
limitations of 32-bit ints somehow and also ran faster than mine...
Date: 9 Jan 2008 06:53:14
Message: <4784b5aa@news.povray.org>
> written a much more complicated version in assembler that got around the
> accuracy limitations of 32-bit ints somehow and also ran faster than
> mine...
I had a really good Mandelbrot/Julia generator on the Acorn called
!Mandy. That was bloody fast, and you could go really deep.
Date: 9 Jan 2008 06:57:56
Message: <4784b6c4$1@news.povray.org>
> mine...
Well, it was written in interpretted BASIC, what do you expect? ;-)
[Also written very simply, with no evidence of any attempt at
optimisation... And lots of configurable options which slow rendering
down even if you don't use 'em.]
Date: 9 Jan 2008 07:46:38
Message: <4784c22e$1@news.povray.org>
Invisible wrote:
> Then again, when I was a child, I used to sit for hours watching the
> washing machine. [Remember that when I was a child, "TV" was only
> available for a few hours a day...]
Hmm... That does explain some things ...
> Does anybody know how either of these simulations actually work?
Sort of ... They're both cellular automata systems, I believe.
On a side note, the page that has the wave simulator has my favorite
waste of time:
http://www.falstad.com/circuit/
Date: 9 Jan 2008 08:00:47
Message: <4784c57f$1@news.povray.org>
._.
> waste of time:
Ah yes, another interesting toy. If only I knew what it all means...
Actually, that site has a whole heap of seriously interesting stuff. I
also enjoy playing with the digital filters and so forth.
