POV-Ray : Newsgroups : povray.off-topic : photos Server Time
17 May 2026 06:46:12 EDT (-0400)
  photos (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: photos
Date: 3 Jan 2008 21:16:14
Message: <477d96ee$1@news.povray.org>
Jim Charter wrote:
> is there currently any solution | method | common practice for doing
I have heard very good things about a product called "ThumbsPlus" a
while back. You might want to look into that. It was cheap enough for a
friend to buy it for me without me asking. (Never actually installed it,
tho.)
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: photos
Date: 3 Jan 2008 21:31:32
Message: <477d9a84$1@news.povray.org>
> In a Windows environment,
> say I have a bunch of photographs stored on directories...
> suppose I want to store the photos and give them attributes such that
> I could retreive subsets of them using different filters on those
> attributes in a flexible, 'relational' way...
> this?
> assume I know nothing
> -Jim
I'm about to write a database-based application for the family holiday
pics. Maybe even something web-based on the LAN so that my sister can
add the tags when she's bored.
Subject: Re: photos
Date: 3 Jan 2008 22:05:01
Message: <web.477da2082a9bcdbb29e441010@news.povray.org>
> this?
> -Jim
Is this something like what you're looking for?...
http://www.albumburger.com/en/index.asp
I hope it helps.
Best Regards,
Mike C.
Subject: Re: photos
Date: 3 Jan 2008 23:53:51
Message: <477dbbdf$1@news.povray.org>
I did one (a while ago) that stored the information in parallel ".info"
files, and from which you could generate a whole web site to put on a
CD. You're welcome to it, if you want. :-)
There's also "JAlbum", which is free and apparently stores the comments
in a ID3-like tag in the JPEG file directly.
Subject: Re: photos
Date: 4 Jan 2008 06:45:22
Message: <477e1c52$1@news.povray.org>
> tho.)
I use ThumbsPlus, but not for its database feature.  It's just not
practical when it only gets stored on a file local to a particular
computer and you have over 200,000 images to tag.  And while you can add
information in the file itself with Explorer or such, it does change the
filedate, making *that* information irrelevant (always interesting to
check out the earliest images in whatever subset of your collection).
Tim Cook
http://empyrean.digitalartsuk.com
Version: 3.12
Subject: Re: photos
Date: 4 Jan 2008 09:51:44
Message: <477e4800$1@news.povray.org>
>>this?
>>-Jim
> I hope it helps.
> Best Regards,
> Mike C.
Thanks but no, this is a pleasing little app. but too limited.
Specifically there is not a way to assign attributes other than the
categories the album provides, also only resolutions up to 1024 are
supported.  Probably I don't really know what I am looking for.  Better
would be some sort of ad hoc way to store attributes about an existing
directory and have that directory be retrievable as a hyper-link.  Not
sure if such a thing would be possible.
Subject: Re: photos
Date: 4 Jan 2008 10:12:22
Message: <477e4cd6$1@news.povray.org>
Not sure what you are saying but it sounds closer to my purpose.
Parallel .info files?
This looks promising
Subject: Re: photos
Date: 4 Jan 2008 10:13:16
Message: <477e4d0c@news.povray.org>
>> this?
>> -Jim
How would it work?
Subject: Re: photos
Date: 4 Jan 2008 10:13:43
Message: <477e4d27$1@news.povray.org>
I use Adobe Photoshop Album, where I can put tags on photos, and combine
different tags to filter them. It is easy and flexible. But it is not
free (and it seems Adobe is no longer selling it, but photoshop elements
only...).
Otherwise, is not google Picassa able to do what you need ?
Thibaut
> this?
> -Jim
Subject: Re: photos
Date: 4 Jan 2008 10:18:25
Message: <477e4e41$1@news.povray.org>
product. This enables you to store each image in a row of a big table,
and you can then cross-reference any kind of metadata you desire in the
product that will enable you to build a HTML interface to query all this
data in a flexible way.
...I mean, if you're looking for the most OTT solution available, this
has got to be fairly close. ;-)
On a slightly *less* insane note, you could probably build some kind of
PHP thing where you submit photos, it gives each one a unique name, puts
it in a folder somewhere, and stores some metadata about it in a MySQL
database and gives you a web interface to query it. In fact, heck,
somebody has probably already made such a thing somewhere...
http://blog.orphi.me.uk/
