POV-Ray : Newsgroups : povray.off-topic : Maybe? Server Time
10 Feb 2026 12:22:31 EST (-0500)
  Maybe? (Message 1 to 9 of 9)
Subject: Maybe?
Date: 2 Jan 2008 15:45:42
Message: <477bf7f6@news.povray.org>
http://www.youtube.com/watch?v=PwvIRuCLbyg
"20 easy right maybe 30 low left maybe"
Maybe? WTF :O
Eero "Aero" Ahonen
   http://www.zbxt.net
Subject: Re: Maybe?
Date: 2 Jan 2008 17:22:28
Message: <lj3on35v2lggtqimpbh770csehue53jkgq@4ax.com>
Wow, that was intense!  LOL @ maybe.
Subject: Re: Maybe?
Date: 2 Jan 2008 21:42:41
Message: <477c4ba1@news.povray.org>
Eero Ahonen nous apporta ses lumieres en ce 2008/01/02 14:26:
> Maybe? WTF :O
That navigator is to "maybe"...
What happens if you get scared half to death twice?
Subject: Re: Maybe?
Date: 2 Jan 2008 22:02:09
Message: <477c5031$1@news.povray.org>
> Maybe? WTF :O
I suspect it's a technical term. In this sort of rally race, you get a
set of instructions to follow (often intentionally obscure) and a time
to get there in. The closer you come to getting there in the right
number of seconds, the better your score. Too early or too late costs
you. So perhaps "maybe" was one of the instructions, saying "maybe you
turn right, maybe you don't" or some such, and you're expected to be
able to react to whether there's a right turn there or not.
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: Maybe?
Date: 3 Jan 2008 00:02:25
Message: <477c6c61@news.povray.org>
That's what we thought of with couple of other car (not rally-, just
car) enthustians, but any of us still haven't got a clue, what it
_really_ means. It still sounds hilarious - and I hoped that someone
here could know.
Yep, if they haven't made the notes themselves, there is always a
possibility for an actual "maybe".
Eero "Aero" Ahonen
   http://www.zbxt.net
Subject: Re: Maybe?
Date: 4 Jan 2008 07:02:55
Message: <op.t4eme8jwc3xi7v@news.povray.org>
And lo on Wed, 02 Jan 2008 19:26:46 -0000, Eero Ahonen
<aer### [at] removethiszbxtnetinvalid> did spake, saying:
> Maybe? WTF :O
Normally a variable - may be slippery, may be wet; it depends.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Subject: Re: Maybe?
Date: 4 Jan 2008 13:44:57
Message: <477e7ea9$1@news.povray.org>
Ahhh. Thank you.
Eero "Aero" Ahonen
   http://www.zbxt.net
Subject: Re: Maybe?
Date: 7 Jan 2008 03:46:22
Message: <4781e6de$1@news.povray.org>
> Ahhh. Thank you.
I thought it was usually short for "maybe cut", ie there might be a
possibility to cut off some part of the turn (eg by putting two wheels onto
the grass).  It's because the conditions might have changed since the recce,
spectators, rocks, debris, mud or anything could be there which wasn't there
earlier.  I haven't watched that specific clip though so could be wrong.
Vaguely related, I remember watching Colin McRae and his co-driver to the
pre-run recce of a rally stage once, they were approaching an "S" bend that
had flat grass all around it so decided that in the rally they would
completely cut off the two turns and drive through the middle across the
grass, allowing that section to be taken at a much higher speed and saving
valuable time.
Come the real rally, they approach this same section at considerable speed
expecting to simply cut through the middle, only to find a course official
standing directly in their path!  Some extreme sideways driving (and a lot
of lost time) got them around ok in the end IIRC.
Subject: Re: Maybe?
Date: 7 Jan 2008 04:41:58
Message: <op.t4jzrus6c3xi7v@news.povray.org>
And lo on Mon, 07 Jan 2008 08:46:32 -0000, scott <sco### [at] laptopcom> did
spake, saying:
>> Ahhh. Thank you.
> onto the grass).  It's because the conditions might have changed since
> the recce, spectators, rocks, debris, mud or anything could be there
> which wasn't there earlier.  I haven't watched that specific clip though
> so could be wrong.
Well I didn't get it from the clip, got it from some rally driving friends
:-) Apparently it's part of some standard terminology in the pace notes.
> the pre-run recce of a rally stage once, they were approaching an "S"
> bend that had flat grass all around it so decided that in the rally they
> would completely cut off the two turns and drive through the middle
> across the grass, allowing that section to be taken at a much higher
> speed and saving valuable time.
Again apparently there isn't a "cut" standard term, but there is a "no cut"
> speed expecting to simply cut through the middle, only to find a course
> official standing directly in their path!  Some extreme sideways driving
> (and a lot of lost time) got them around ok in the end IIRC.
As above if they didn't want anyone to cut it should have been labelled as
such, otherwise it's fair game.
Phil Cook
