POV-Ray : Newsgroups : povray.off-topic : Another physical puzzle Server Time
9 Jun 2026 12:43:33 EDT (-0400)
  Another physical puzzle (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Another physical puzzle
Date: 2 Jan 2008 09:33:36
Message: <477ba0bf@news.povray.org>
Greg M. Johnson <pte### [at] thecommononethatstartswithycom> wrote:
> That's where I was headed. Does the cannonball displace more
> water "underwater" than in the boat
  No, it displaces less when underwater because its volume is "less" than
its weight, when compared to the water.
Date: 2 Jan 2008 11:31:23
Message: <477bbc5b$1@news.povray.org>
Right. And you know that *because* it sinks.  The water level wouldn't
change if the thing you threw over floated.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 2 Jan 2008 11:42:59
Message: <477bbf13$1@news.povray.org>
Darren New nous apporta ses lumieres en ce 2008/01/01 19:13:
> You are sitting in a canoe, in a swimming pool, holding a cannon ball in
> your lap. You throw the cannonball overboard, and it sinks to the
> bottom. Does the level of water in the pool go up, go down, or stay the
> same?
> (I've asked this of probably a dozen or more scuba dive instructors, and
> only one has gotten it right. The reasoning behind the correct answer is
> obvious once you hear it. I don't remember if I got it right when I
> heard it.)
The level will go down.
When in your hand, you displace a volume of water that have the mass of the
cannonball. When you drop it, the displace a volume of water egual to it's own
volume. The cannonball have a higher density than the water as it sink.
You know you've been raytracing too long when you wonder if ground fog or
athmosphere will look better for your company's market share pie chart.
Christoph Rieder
Date: 2 Jan 2008 12:35:00
Message: <web.477bcab13e72ddaf40d56c170@news.povray.org>
Rethinking.
Using symbols:
Ph20= density of water
Pfe= density of cannonball
Mball= mass of canonball
IN CANOE:
displacement = Mball /(Ph2o)
UNDERWATER:
displacement = Mball / (Pfe)
But I'm not even sure if that's completely right now.
Date: 2 Jan 2008 13:08:37
Message: <toknn3tcapecfo23qsmgj54ot9dfbmk2se@4ax.com>
In the boat the cannonball displaces its own mass of water. In the water the
cannonball displaces its own volume of water.
Do I need to go on? :)
Regards
Date: 2 Jan 2008 15:55:59
Message: <477bfa5f@news.povray.org>
gregjohn <pte### [at] yahoocom> wrote:
> IN CANOE:
  No. In the canoe the ball displaces an amount of water equal to the
weight of the ball.
> UNDERWATER:
  In the water the ball displaces an amount of water equal to the
volume of the ball.
  The amount of water which weights the same as the ball is larger than
the amount of water which has the same volume as the ball.
Date: 2 Jan 2008 19:05:00
Message: <web.477c262e3e72ddaf34d207310@news.povray.org>
> > IN CANOE:
> weight of the ball.
That's what I said, only more precisely.
Date: 2 Jan 2008 20:50:29
Message: <477c3f65@news.povray.org>
> same?
> heard it.)
It goes down as measured against the edge of the pool.  While in the
canoe, the cannonball displaces its mass in water, but in the water it
displaces only its volume.  Since the cannonball is denser than water,
it displaces more while in the canoe than in the water.  Since there is
less displaced water, the water level of the pool goes down.
John
Date: 3 Jan 2008 15:38:18
Message: <MPG.21e6f57f5d0ce9a698a0d6@news.povray.org>
In article <477b4045@news.povray.org>, pgf### [at] optusnetcomau says...
> Gail Shaw wrote:
> > "Darren New" <dne### [at] sanrrcom> wrote in message
> > news:477ad72c$1@news.povray.org...
in
e
> >> same?
> > I believe it should stay the same.
> Incorrect.  Hint - The cannon ball sinks to the bottom.  Think about
> what was preventing it doing so before.
Umm. I don't see how that would be incorrect. While in the boat the
*boat's* hull has to displace an amount of water sufficient to account
for the added weight of the ball... Ok, you have a point. The
displacement from the ball is going to be different "in" the boat than
in the water, since one depends on the *weight* being shifted, while the
other depends entirely on the *size* of the object. The question then
is, will the displacement of the boat, from the cannon balls weight, be
larger or smaller than the displacement of the cannon ball itself?
Without knowing the size of the boat, the actual weight of the ball, and
thus what the displacement will be from that, its not possible to
project if the water will be "more" or "less" displaced by the inclusion
of an entire cannon ball in the pool, versus a few millimeters of boat
sinking slightly more into the water from the weight.
I.e., insufficient information to make a ruling.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 3 Jan 2008 15:47:21
Message: <477d49d8@news.povray.org>
  The size of the boat nor the weight of the ball make any difference on
the original question: The original question didn't ask how much the water
level changes, it only asks if the water raises or lowers. To answer this
question the only information needed is whether the cannonball has higher
density than water or not. Since cannonballs are made of metal, the answer
is yes. Thus its weight displaces more water than its volume, and thus
the answer is that the water level lowers.
